nsr forks
lee125
PostPosted: 23:01 - 30 May 2006    Post subject: nsr forks Reply with quote
hi i took the top bit off my forks so that i could see inside and one of the forks was full of oil and on the other one it looked like there wasnt any oil is this ok or is something wrong any help will be appreciated thanks Thumbs Up
(the bike is a 93 nsr125)
cbt passed Smile 01/07/2006 bike:92 dt 125 and 96 honda cr 250
theory:PASSED! A2 test:PASSED 08/11/2006 restricted to 33bhp for 2 years
alains
PostPosted: 00:50 - 31 May 2006    Post subject: Reply with quote
the quantity to put in each is 280cc of oil . if one is low or dry it's because your seals or the tube is worn . pass your finger along the chrome part , if your finger is oily it's time to change seals even the tube (which is very expensive) . you can also buy some on ebay any model from 1993 until 2001 will fit your's (if it's a JC22 , serial numbers begining by ZDCJC22.....)
lee125
PostPosted: 01:24 - 31 May 2006    Post subject: Reply with quote
thanks for the help alains so are my forks nackered then or could they just need topping up cause they werent leaking on the outside?my bike is a jc20 Thumbs Up
code guru
PostPosted: 01:53 - 31 May 2006    Post subject: Reply with quote
u have 2 change the fork oil every so often. this is wot i would do if i woz u.
take one fork and take the top off and take all the oil out ( all the stuff inside will come out like the spring and metal tube) re fit the stuff inside and fill it up with 280cc grade 10 or 20 wot ever one u whant and fit the top back on and do the same with the other fork. its best 2 do one fork at the time ect
alains
PostPosted: 02:29 - 31 May 2006    Post subject: Reply with quote
it's not as simple as you said . the problem with these forks is that you must take them off then had a strong vice to take off the tubes . what you should do is to find some second hand (in good condition) and then change oil on them . if your forks need tube change , it will be very expensive . waiting to find those you can fill the empty tube , it will go for a while
lee125
PostPosted: 12:50 - 31 May 2006    Post subject: Reply with quote
how can i tell if it is the tube nackered not the seal?cheers
alains
PostPosted: 13:22 - 31 May 2006    Post subject: Reply with quote
impossible ! this is why i suggested to fill the fork and to watch what will happen . but chase forks on ebay , this will be the best solution
lee125
ok will do thanks Thumbs Up
alains
PostPosted: 13:28 - 31 May 2006    Post subject: Reply with quote
i've just been visiting david silver spares stock list and your tubes (51410 KY4 305) are £59 each ex VAT Sad
lee125
PostPosted: 13:34 - 31 May 2006    Post subject: Reply with quote
Shocked Sad
The last post was made 20 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 63.57 Kb
