Restricted NSR Wheelie?
Geordie - NSR
PostPosted: 09:30 - 31 May 2006    Post subject: Restricted NSR Wheelie? Reply with quote
Just wondering is it posible to wheelie a restricted NSR? if so anyone give me some advice plz....as i'd really like to get the front end up on some "private" roads Very Happy
shaun_04
PostPosted: 09:42 - 31 May 2006    Post subject: Reply with quote
yes, just ride slowly in 1st gear, increasing your speed gently until you get into the powerband, then pull up on the bars and nail it simultaneously. Voila.
Oh, but remember to keep your rear brake covered otherwise you risk flipping it.
PostPosted: 09:43 - 31 May 2006    Post subject: Reply with quote
Suspsect you'll need to use the clutch on a restricted NSR, but even drestricted, it's not really worth it as you have to be /very/ good to keep it going.
bennyboy
PostPosted: 11:44 - 31 May 2006    Post subject: Reply with quote
i sense another fucked clutch on a 125
2000 peugeot speedfight....1999 RS125....2001 RS125....1997 GSXR600 srad
Jenks
PostPosted: 12:36 - 31 May 2006    Post subject: Reply with quote
Probubily not advisable...
But yes, get going, then give it some..
But be damn carefull.
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
Aikman666
PostPosted: 12:39 - 31 May 2006    Post subject: Reply with quote
If i can wheelie an RX50, you should be able to do it on an NSR125.
But because of the gearing on my hog i can only do it from a standstill. Just give the bike plenty of revs and dump the clutch in 1st, will take a few trys to get the clutch right (as your mind will be telling you DONT DO THAT!!) Also you'll need to shift your weight around the bike pretty fast. Try it at different revs each time for a better height, just dont flip it, you might even be able to keep it up because you have a more powerful engine than me! I wouldent make a habit of it either, it puts quite a strain on your clutch and gearbox!
Will work for petrol
My Design Blog
Geordie - NSR
PostPosted: 16:44 - 31 May 2006    Post subject: Reply with quote
cheers guys....i look forward to tryin out ur tips Very Happy
bidman
PostPosted: 17:25 - 31 May 2006    Post subject: Reply with quote
Hi, as I say on almost all the wheelie threads, you can wheelie ANY BIKE! its all about your body positioning. If you hang off the back like a monkey sot he front end is light before you even set off then open the throttle it should come up nice and easy and you can control it and find your balancing point with th rear brake, Thumbs Up Dan
Don't ride it, RAG IT!!
PostPosted: 18:21 - 31 May 2006    Post subject: Reply with quote
bidman - you really think that's likely for someone that can't wheelie on a peaky 2stroke that's relatively heavy?
Not all bikes /will/ wheelie without some modifications, for instance better tyres.
Why?
The restricted NSR may be a bit more powerful, but it also weighs a lot more and is geared for around 100mph probably.
element
PostPosted: 22:27 - 31 May 2006    Post subject: Reply with quote
my speedfight 100 doesnt wheelie and its got a little bit more power than most 50's id imagine. Too damn front end heavy. And ive tried loads to get the front up includint hanging off the back almost. The most ive got is a few inches for about a metre.
unless I got a PM tuning exhaust (£240 for a scooter pipe wtf?!) which gives I think its 14bhp over the stock 9bhp I dont think you could wheelie one of these.
Ive not managed to wheelie my DT yet although I havent tried but I have slipped the clutch to fast before and it hasnt lifted the front. Damn I cant wait to derestric it and get a tuned exhaust Smile
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
Josh|RD125LC
PostPosted: 22:30 - 31 May 2006    Post subject: Reply with quote
I doubt you'd be able to get the front wheel up through power and a bit of clutch slip, as its quite a heavy bike. It'd come up by dumping the clutch, but thats just shit and pointless. If you want a 125 that will wheely without dumping the clutch, get an RD125LC like me, front wheel comes up with some clutch slip, all the crosser style bikes will be the same, as their power to weight ratios are better than the likes of RS's etc.
Not really worth wheelying a 125 though. Confused
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
NSR Mick
PostPosted: 22:44 - 31 May 2006    Post subject: Reply with quote
It gets pretty painful on the wallet and body if it goes wrong. I'd keep both wheels on the floor if i was you. Embarassed Shocked Doh! Whistle
https://i8.photobucket.com/albums/a50/micklivesey/gsxr/MVC-004F.jpg
Josh|RD125LC
PostPosted: 22:58 - 31 May 2006    Post subject: Reply with quote
Ouch. Shocked
RD125LC Pictures
Sephiroth
PostPosted: 23:01 - 31 May 2006    Post subject: Reply with quote
WTF Shocked
edd
PostPosted: 23:27 - 31 May 2006    Post subject: Reply with quote
thats some serious maulage Shocked
Bluespark Automotive - Diesel Tuning for Performance and Economy
ncrn
PostPosted: 23:32 - 31 May 2006    Post subject: Reply with quote
just out of curiosity, why do you keep a can of boddingtons fixed by the exhaust?
Finglonga
PostPosted: 23:33 - 31 May 2006    Post subject: Reply with quote
Better to learn on a 125 and bin it than anything bigger as it hurts the wallet more. Plus 125's are alot easier to find the balance point at lower speeds than on bigger bikes.
Andy Sez....
F.Y.Y.F.F.
tatters
Exxon Valdez
PostPosted: 23:37 - 31 May 2006    Post subject: Reply with quote
Its covering the rear shock remote reservoir (for a tarty look).
plugger147
PostPosted: 23:39 - 31 May 2006    Post subject: Reply with quote
Shocked flat tyres are pretty common not often you see a flat wheel though.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
Geordie - NSR
PostPosted: 00:01 - 01 Jun 2006    Post subject: Reply with quote
too be honest guys....been out on it tonite and generally its like tryin to get blood from a stone gettin that thing off the ground!!! think i'll wait until maybe a bigger bike/wage lol....and really after that picture im not sure i want my bike to end up like that! lol Shocked
shaun_04
PostPosted: 09:51 - 01 Jun 2006    Post subject: Reply with quote
geordie-nsr you can easily get it up, you have to do some work and not rely on the bikes power, but if you no longer want to learn to wheelie...
PostPosted: 09:58 - 01 Jun 2006    Post subject: Reply with quote
Not really better to learn on a 125. Personally I would say that a 125 is massively harder to find and keep the balance point than on a bike with more power.
Because you have very little power to play with, you have to get it very high, very quickly, which is the sort of thing that is likely to lead to flipping it. You also don't have the engine braking to shut the throttle off and bring it down with that decently.
Shaun_04:
Yes, you can get it up if you try, but it will come back down again pretty quickly in most cases, making it a rather futile exercise.
bennyboy
PostPosted: 10:00 - 01 Jun 2006    Post subject: Reply with quote
Shaun_04:
stevo as b4
PostPosted: 00:35 - 02 Jun 2006    Post subject: Reply with quote
i have found that a kmx200 with a kmx125 gearbox sprocket will wheelie just a little bit, in 1st/2nd and sometimes in 3rd, quite nicely!
bearwood.beckham
PostPosted: 00:55 - 02 Jun 2006    Post subject: Reply with quote
Think you can get them for round the front forks aswell..
The last post was made 20 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 128.67 Kb
