Derestricting an import!!!…HELP!!!…
Viper
Get off my bloody bike!
PostPosted: 20:40 - 31 Mar 2002    Post subject: Derestricting an import!!!…HELP!!!… Reply with quote
After a year of agony riding a restricted NSR, this weekend I FINALLY took out the intake and exhaust restrictors!
Finally I thought I would have a bit of power...great.. 8)
So imagine my severe dissapointment, when I took it for a test ride to find that my top speed had only improved by about 3mph!!!! :o
I'm now only hitting about 65mph(on a flat), and cant get any more than 11,000rpm. Crying or Very sad
So to detect whether the servo was moving, me and me otherhalf stuck some insulation tape between the servo cable-pulley-wheel-thing, and the servo body.
I then took the bike out to 10,500rpm, and got back to find the tape hadn't moved!! Crying or Very sad
So as my servo not moving AT ALL, we assume it must be restricted via the CDI.
So is it possible to get the servo moving without replacing the CDI, otherwise why would they have fitted the damn servo to the bike in the first place!!!?!?!! Confused
On an RD125 it is possible to pin the exhaust valve open, so could you do this on an NSR???? Confused
Or is it possible to move the servo manually?
If we connect a 12V reverse polarity current, will this move the servo in the other direction?!?!? Confused
Basically . . . H E L P ! !
Has anyone here derestricted an import?
Anyone have any advice!! Confused
Please!!
Viper
PostPosted: 21:01 - 31 Mar 2002    Post subject: Reply with quote
Also....
does anyone know where i can get hold of a wiring diagram for a 2001 model??
Dylan
PostPosted: 21:19 - 31 Mar 2002    Post subject: Reply with quote
https://translate.google.com/translate_c?hl=en&u=https://www.devader.de/&prev=/search%3Fq%3Dnsronline%26hl%3Den
and
https://translate.google.com/translate_c?hl=en&sl=de&u=https://mitglied.lycos.de/nsronline/&prev=/search%3Fq%3Dnsronline%26hl%3Den
Wish i could read pigeon German!!!!
Dylan
Text from a previous post that no one read Crying or Very sad hope its more use to you!!! Smile Are you sure its an import, becasue it sounds strange that it would have the standered uk restrictions on an import. Could it just be a broken CDI???? Can test this with a strobe light, best get a garage to do it.
Hope it helps
Dylan
PostPosted: 15:43 - 01 Apr 2002    Post subject: Reply with quote
Does the valve open and close when the ignition is turned on? My guess would be the control unit for the valve is either disconnected or fried (happens on the Cagiva Freccia and Mito, and they could well use the same control unit).
Also has the valve seized up from running round at low revs for the past year/s
scabzilla
PostPosted: 19:04 - 01 Apr 2002    Post subject: Reply with quote
Hey viper, u buy your import from new ?? if ya did what company you buy it from plz ???
Viper
PostPosted: 21:15 - 01 Apr 2002    Post subject: Reply with quote
yeah, i did buy it new, last March.
Cost me £2700, but that price was a "friends discount".
It came from Tony Moto nr Southampton. (they advertise in biketrader)
scabzilla
PostPosted: 21:22 - 01 Apr 2002    Post subject: Reply with quote
yeah i know em there well cheap !
Hibby
Guest
PostPosted: 20:12 - 02 Apr 2002    Post subject: Import Reply with quote
Hi,
Look for a link wire on the black box under the tank possibly red / white if you find one remove it this should enable the power valve. also look for a white and orange link at the back of the bike (under cowl) if found remove.
Hibby
Viper
PostPosted: 00:53 - 07 Apr 2002    Post subject: Reply with quote
Thankyou Hibby for that crucial info!!!
You are a lifesaver, and i am eternally grateful!! Razz
Now have derestricted bike!!
Yippeee!! Laughing
Doddmaster
PostPosted: 10:40 - 07 Apr 2002    Post subject: Top speed? Reply with quote
So how fast does it go now? Is it 85mph like other imports?
Viper
PostPosted: 11:23 - 07 Apr 2002    Post subject: Reply with quote
Yeah, 85. But i suppose that will have to do!!
GasGas
PostPosted: 15:58 - 07 Apr 2002    Post subject: 85? Reply with quote
85????? why do imports only do 85 tops? any techno bods got the answer? I am sure we imp.owners would love to know. Confused is it something to do with the cdi, could a Uk bike owner give me identification marks from their cdi cos i`m gonna check to see if mine is the same. Has anyone tried to change an import cdi for a uk one?
TiN
Pocket Tin
PostPosted: 16:54 - 07 Apr 2002    Post subject: Reply with quote
but is the acceleration the same as a UK bike?
I personally think that acceleration is more important than top speed...
Tin
Dylan
PostPosted: 17:13 - 07 Apr 2002    Post subject: Reply with quote
Has any one readlined there import in top???? If so what is top speed?? Mine does about 90mph, but its got only a 13 front sproket.
Dyl
jim-1-2-5
Guest
PostPosted: 18:00 - 07 Apr 2002    Post subject: 2001 Import Reply with quote
I have a 2001 nsr125 that is restricted, I have checked for restrictors in the exhaust and inlet manifold, none of which are present, when I start the bike the servo motor that controls the power valve moves so I don't think that has been bypassed, any other idea's, someone mentioned about an orange and white wire near the back of the bike, what does this do?
Any help would be appreciated.
jim
PostPosted: 18:52 - 07 Apr 2002    Post subject: Reply with quote
Could be worth trying to dyno an import and check the power they are producing. Also try it in several gears, and if you can do it try using a stobe light to check what the timing is doing as the speed goes up.
My guess is one of the following:-
Ignition is retarded above certain revs, maybe only in high / top gear.
The power valve shuts at high revs
Other possibilities are lower compression, different porting, etc
Dylan
PostPosted: 19:22 - 07 Apr 2002    Post subject: Reply with quote
Ime gonna take my bike for a dyno run next a week saturday. Do u do a run only in one gear then?? Mine does so 90mph, only has a 13 tooth front, shoud do 97mph with the 14 tooth. Its redlining at that point. Mine was made in 1989 though so i think that was before they restricted them. Could someone count the number of teeth on the front sproket on an import plz??? Is 14 standered on the newer ones???
Thanks
Dyl
Hibby
Guest
PostPosted: 20:58 - 07 Apr 2002    Post subject: Import Reply with quote
HI,
The acceleration is the same as a UK spec bike, the problem starts when you are in 5th, from memory it wont fully go through the red line up into sixth and your buggered barely enters the red line zone 88mph tops!!!.
I dont know of any one who has fully deristricted an import, but im guessing the best way is to change the cdi unit for a uk spec bike bought from a breaker. Failling that some one like Stan Stephens might be able to help as they are specialists in 2 stroke tuning, I think they have a help line (check the net).
Regards....Hibby.
Ps I hate to say it but my solution was to sell it and buy a 600.
Claes, sweden
Guest
PostPosted: 22:32 - 07 Apr 2002    Post subject: Reply with quote
the imports have 22hp cylinder, the uk bikes have 28-30hp cylinder
Dylan
PostPosted: 18:54 - 08 Apr 2002    Post subject: Reply with quote
No point in replaceing cylinders, rc units and and CDI's untill youre sure its one of them, I still think it has a lot to do with the gearing.
Dyl
ps Anyone know if you can cylinder scavenge on these barrels by fileing away at the ports, i wouldnt do it myself, but is the nicasil coating too hard???
GasGas
PostPosted: 22:42 - 08 Apr 2002    Post subject: gearing/cdi??? Reply with quote
Hibby, https://www.stanstephens.com/index.htm been there already but me thinks I wont bother tuning the bike, just move up like you did.
Dylan, 13 on the front and cannot redline it in sixth gear, reaches top speed of about 145 kmh downhill to about 9500 rpm. I too reckon the 14 sprocket would help but probably need high revs just to pull away.
Let me know how you get on with the change of gearing.
Gasgas
The last post was made 24 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 105.93 Kb
