Quick Question
Marcg868
PostPosted: 22:25 - 01 Jun 2006    Post subject: Quick Question Reply with quote
Right basically, ive just got my bike back from 7500 mile service, did the oil change myself so only cost me for new air filter and Spark plug, and cost me £75.68 including labour, so not earth shatteringly painful as i thought.
But one thing that concerns me is, i asked to have a fairing bolt drilled out so i could put the new one in, but ive got it back and its like they've fucked the hole up. Now can i put a smaller bolt in or what? Just i dont want my fairing flapping about like a Prostitutes Flange.
JACK, MISS YOU LOADS YOU LEGEND.
PostPosted: 22:31 - 01 Jun 2006    Post subject: Reply with quote
Use a longer bolt and put a nut on the back of it?
Marcg868
PostPosted: 22:59 - 01 Jun 2006    Post subject: Reply with quote
Where can i get a load of Bolts from Any suggestions?
veeeffarr
PostPosted: 23:00 - 01 Jun 2006    Post subject: Reply with quote
You didn't just ask that did you?
And you paid £75 for a plug and airfilter!!!
PostPosted: 23:03 - 01 Jun 2006    Post subject: Reply with quote
Search out the proprietorship of one who mongs iron. Herein you will find the items you seek.
veeeffarr
PostPosted: 23:04 - 01 Jun 2006    Post subject: Reply with quote
Or B&Q, Homebase any other DIY store ever created ever?
Rob W
PostPosted: 23:05 - 01 Jun 2006    Post subject: Reply with quote
lol
divuk83
If you can change the oil and filter you could have easily done the plug and air filter yourself.
As for bolts, ask the garage for one. You asked them to do it and they didn't do it right, I'm sure they can spare a bolt if you have just spent 75 quid on a service.
Dave
Marcg868
PostPosted: 23:38 - 01 Jun 2006    Post subject: Reply with quote
Most of the £75 as labour and VAT. 53 quid per hour labour at E.S.B in Bolton.
Oil's Easy to change, just getting to the spark plug i dont have time to, whereas, oil is just take fairing half off, plastic box undo, let it drain for 2 mins, then bang a litre of oil in. 5 Min job.
I'll ask my breaker friend, sureley with all the bits of bike shit he has, he could spare a bolt.
veeeffarr
PostPosted: 23:41 - 01 Jun 2006    Post subject: Reply with quote
Ask him if he's got a carb cover from a 2000ish CG125 as well please Very Happy
PostPosted: 23:47 - 01 Jun 2006    Post subject: Reply with quote
Is it just me, or did anybody else notice the total lack of "remove and clean/change the oil filter" in that sentance?
doggone
PostPosted: 00:08 - 02 Jun 2006    Post subject: Reply with quote
Maybe the service schedule says only change filter every other time.
I do that anyway but tend to change the oil more frequent than they say.
veeeffarr
PostPosted: 00:09 - 02 Jun 2006    Post subject: Reply with quote
or the removal of the dipstick, or the warming up of the bike, or the leaving it longer than 2 minutes, or the CAREFULLY filling up intermittantly checking with the dipstick.
Itchy
PostPosted: 00:11 - 02 Jun 2006    Post subject: Reply with quote
on that note stink what advice do you have for undoing an utterly buggered (too tight and the coolant pump is in the way to get deep sockets in to try) oil sump plug? ,
I'm iffy about trying drilling or what not cus its me only transport , best let me cheapo mechanic try (its only £8 to change oil , though you have to get yer own 10-40W)
PostPosted: 00:25 - 02 Jun 2006    Post subject: Reply with quote
Can you get a socket on it at all because I would suggest that using a good quality 1/2" drive socket on it would have the best chance of success? Tried tapping an imperial socket that is slightly smaller down onto it?
You get wobble extension bars for socket sets that are a deliberately loose fit on the drive to help you get into tight corners, maybe borrow some of these off someone?
Itchy
PostPosted: 14:07 - 02 Jun 2006    Post subject: Reply with quote
thanks for the advice stink , I'll have a go , heh as even if I bugger it up its only a couple quid (and ego points) to go to a local mechanic who is cheap (who seems to do bike repairs more as a hobby than a business).
Nath
PostPosted: 19:16 - 02 Jun 2006    Post subject: Reply with quote
That on your ntv650? Assuming it's the same as the bros, I can only get a 3/8ths socket it on it using a universal joint. If you're sure you can't get a spanner on it then perhaps try moleys?
Hard livin', hard luck.
Itchy
PostPosted: 21:39 - 02 Jun 2006    Post subject: Reply with quote
yes its me NTV650
I can get a closed ended (box?) spanner on it , and it fits fine , I can't get any sockets on it though well I can but just the socket by itself which isn't very useful.
, the spanner is almost like a socket its one of those with lots of teeth almost the same as the socket and it won't budge even a tiny bit
and I worry about trying too hard and rounding off the bolt which I'd rather be annoyed at.
Nath
PostPosted: 21:45 - 02 Jun 2006    Post subject: Reply with quote
As I said, try 3/8ths rather than 1/2" and see if you can get a universal joint on it.
However if you can get a ring spanner on it I don't see what the problem is. Sit down on the floor next to the front wheel and stick the spanner on pointing vertically down. After double checking that it is on the bolt head properly, give it a big kick. If it won't come undone then you're not kicking it hard enough Razz The spanner will only round it off if you don't have it on the bolt head properly.
Itchy
PostPosted: 21:53 - 02 Jun 2006    Post subject: Reply with quote
I'm shite at football and my accuracy is piss poor , I keep having images of kicking it with a run up missing hitting the side stand and having all 200kilos fall on me trapping me under neath.
Mr. Green
maybe I ought to try extend the ring spanner with some tubular steel to get more leverage , thanks anyway.
Nath
PostPosted: 23:35 - 02 Jun 2006    Post subject: Reply with quote
You kick it with your heel whilst sat on the floor. Kicking it like a football would result only in you severly hurting your foot.
The last post was made 20 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 114.36 Kb
