Couple quick questions......
TOM M
PostPosted: 22:25 - 02 Jun 2006    Post subject: Couple quick questions...... Reply with quote
Firstly, whats the difference between an o ring and x ring chain?
And the chain i had put on me old rs125 had like a split link thing, are they all like this?
What type chain does a zxr 400 use, o or x ring?
Now owner of a 1200 Bandit
ash t
PostPosted: 22:29 - 02 Jun 2006    Post subject: Reply with quote
The ZXR can use either O ring or X ring. The rings are the little rubber bits in between each link,
When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical
ram_doom
PostPosted: 22:31 - 02 Jun 2006    Post subject: Reply with quote
I chose an O-ring did chain for my zxr, dont think the X is worth 20 odd quid more Mr. Green
TL1000s, KDX200
base
PostPosted: 22:54 - 02 Jun 2006    Post subject: Reply with quote
x rings are supposed to last longer.............so i am led to believe
TOM M
PostPosted: 23:15 - 02 Jun 2006    Post subject: Reply with quote
Cheers for that Thumbs Up
Walloper
PostPosted: 01:12 - 03 Jun 2006    Post subject: Reply with quote
Some chains are sealed and lubricated to prolong the internal 'fit' of the pins and bushes. This maintains the chains overall pin/bush sprocket pitch.
If you cut through the rubber lube seals. You will find some have a round 'O' section and some have an 'X' section. X seal sections effectivly provide a double seal lip. Which keeps lube in longer and shit out better.
Shit can't push past a seal in good condition and vice versa for oil.
Paul@125power
PostPosted: 01:25 - 03 Jun 2006    Post subject: Reply with quote
Here is the physical difference. Sorry for it not being english but I think you'll get the point. The indicated parts are little rubber bands.
https://plotkorea.com/images/product_info/did/did1-1b.jpg
If at first you don't succeed.....destroy all evidence that you tried.
Yamaha YQ100 (RIP)......Honda CBR125R
Method
PostPosted: 11:19 - 03 Jun 2006    Post subject: Reply with quote
and as for "Split link" chains,
That refers to the link that holds the chain together, you dont have a nice smooth link that goes through both ends of the chain, and then has the pins rounded off at the other end,
The back plate with the pins goes through the ends of the chain to hold it tight, then the plate goes on and there is a form of clip, that holds that link in place. Holding the chain together Thumbs Up
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
The last post was made 20 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 55.58 Kb
