if a hard drive gets noisy, is it gonna fail ?
colin1
Captain Safety
PostPosted: 02:45 - 02 Jun 2006    Post subject: if a hard drive gets noisy, is it gonna fail ? Reply with quote
my hard drive has started making a fairly high pitched whirring rattling noise
a week ago it only did this on start up but now its pretty continuous
does this means the bearings on it are gonna fail or something ?
its about 2 years old, is used everyday and often on more than 6 hours a day
sickpup
Old Timer
PostPosted: 02:59 - 02 Jun 2006    Post subject: Reply with quote
Probably. It's considered one of the signs.
djr
PostPosted: 03:32 - 02 Jun 2006    Post subject: Re: if a hard drive gets noisy, is it gonna fail ? Reply with quote
yep - before long you'll just get a clicking sound from it... been there done that... back up your data NOW HTH.
daz|n00by
The Internet
PostPosted: 11:26 - 02 Jun 2006    Post subject: Reply with quote
Time to make a back up !
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
bazza
PostPosted: 13:10 - 02 Jun 2006    Post subject: Reply with quote
Make 100% sure it's the HD. I replaced a noisy power supply recently only to discover it was the fan on the gfx card right next to it that was the problem... Doh!
iCraig
PostPosted: 13:49 - 02 Jun 2006    Post subject: Reply with quote
Doesn't Windows support SMART?
If it does get a utility like Sisoft Sandra or something else that can read the SMART status and that will tell you indefinately if its failing.
senna_f4
PostPosted: 13:52 - 02 Jun 2006    Post subject: Reply with quote
Colin, do the following,
1. Backup your data now!!
2. Defragment your hardisk, may be your disk is badly fragmented, so lots of seeking for data.
3. Download https://www.snapfiles.com/get/hddhealth.html or some other utility from your hdd manufacturer to see the smart messages.
What spoils a hardisk is;
1. Frequent stop/starts
2. High temperatures
My hardisks on some pcs, have run for 6 years non stop, with adequate cooling 39oC average temperature. High temperatures and it fails like in 6 months.
Hope it helps
"You don't know the power of the dark side."
Itchy
PostPosted: 13:56 - 02 Jun 2006    Post subject: Reply with quote
don't worry about it too much in any event , cus HDDs are much simpler to install than say with win95 , format the HDD , put it in with the jumper as master and stick in your (hooky) win2K CD and ta da it jump starts the CD drive and installs just like that , no messing with shite like the MSCD.exe thingie to have to jump start the CD drive.
yambabe
PostPosted: 14:23 - 02 Jun 2006    Post subject: Reply with quote
So if this noise was happening with a laptop too (probably caused by an overheating problem as the battery died a couple months ago and has been run as mains-only since and gets pretty warm underneath) and the user has had 2 blue screens of death within days of each other (and has not used the laptop since because she wants to back some stuff up next time she switches it on) is it time to buy a new laptop? Whistle
senna_f4
PostPosted: 14:46 - 02 Jun 2006    Post subject: Reply with quote
babyyam No!
1.Change hard disk £60 ish
2. new battery
3. blow out all dust
Mr. Green
If you need help ask
Skunkcap Freddie
PostPosted: 18:08 - 02 Jun 2006    Post subject: Reply with quote
depends, i had a harddrive that went noisy and kept runnin for a further year .
i had a noisy harddrive but its a seagate. and thats nothin new there.
Northern Irish Biker? www.nibikers.com
NSR Mick
PostPosted: 12:22 - 03 Jun 2006    Post subject: Reply with quote
Some hard drives are naturally noisy. Its if the noise changes you should worry.
Also laptop hard drives will rattle when not in use if you shake them gently, this is normal.
SCSI Hard drive on the other hand make a bleeding racket all the time. Laughing
The last post was made 20 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 73.81 Kb
