Z1000 (2003) Front sprocket change
Micron
PostPosted: 14:45 - 04 Jun 2006    Post subject: Z1000 (2003) Front sprocket change Reply with quote
Hi,
can someone tell me what I need to change the front sprocket on a Z thou?
do I need an extractor, or just a good socket?
thanks
Trev
instigator
PostPosted: 15:52 - 04 Jun 2006    Post subject: Reply with quote
Trev,
First google search wrote:
27mm and some muscle. I used my large torque wrench, if your by yourself use a zip tie to hold your front brake on. You also have to bend the washer down that holds the nut in place. Loosen the axle and the chain adjusters so the wheel can move all the way forward. It just takes a little strength and some maneuvering to get the sprocket out.
https://www.riderforums.com/archive/index.php/t-5208.html
Half way down the page or so.
I take it we are downgearing?
Micron
PostPosted: 17:08 - 04 Jun 2006    Post subject: Reply with quote
No, just renewing the sprockets, it's done a few miles, all those trips abroad soon mount up.
thank's for the information will give it a go.
Trev
PostPosted: 17:24 - 04 Jun 2006    Post subject: Reply with quote
Personally I don't like using the chain to hold the sprocket - you can easily stick 1000ft-lb or so of torque through it.
Often you will find that using the rear brake to hold the wheel isn't enough - I've snapped a wooden hammer shaft using it to block the rear wheel up.
Personally, I try and use an impact wrench of some kind (air/electric) as it generally makes it a lot less hassle and with a lot less likely-hood of damaging the bike.
Finglonga
PostPosted: 21:16 - 04 Jun 2006    Post subject: Reply with quote
Trev
Aren't you replacing the chain too?
Andy Sez....
F.Y.Y.F.F.
Micron
PostPosted: 22:55 - 04 Jun 2006    Post subject: Reply with quote
Yes, complete chain and sprocket change, manged to do the rear one, just having probs with the front Wink
ZRX61
Victor Meldrew
PostPosted: 00:50 - 05 Jun 2006    Post subject: Reply with quote
3ft breaker bar, put the front wheel against a wall, 2x4 thru the rear wheel & have someone of the other side of the bike to steady it as you will probably lift the rear of the bike off the ground.
Micron
PostPosted: 17:41 - 05 Jun 2006    Post subject: Reply with quote
All sorted now, thanks everyone Wink
The last post was made 19 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 55.06 Kb
