Clutch Basket
lee125
PostPosted: 21:08 - 05 Jun 2006    Post subject: Clutch Basket Reply with quote
hi,as you can see one of the things has broken of the outer clutch basket but it seems to have been specially welded and i was just woundering how much you would expect this to cost to be done again
cbt passed Smile 01/07/2006 bike:92 dt 125 and 96 honda cr 250
theory:PASSED! A2 test:PASSED 08/11/2006 restricted to 33bhp for 2 years
PostPosted: 00:52 - 06 Jun 2006    Post subject: Reply with quote
From what I can see on those pictures (which are fairly small) it looks like it has been bodged back together using lumiweld (low temperature, aluminium solder). That was frankly, never going to work in that application.
Your clutch basket is fucked. Buy a new one.
lee125
PostPosted: 10:32 - 06 Jun 2006    Post subject: Reply with quote
before i snapped that piece off the clutch was fine with that weld on so do you not think it will be ok to do again Thumbs Up
mr jamez
PostPosted: 10:38 - 06 Jun 2006    Post subject: Reply with quote
If it fails whilst it is running, it will be messy. Get a clutch basket off ebay and change it, not a hard job. If you can't lock the clutch basket to undo the nut take the lump down to a bike shop. I got two rotors removed for a tenner.
NSR 125F > BROS 400 > NC30 > BROS 400 > Trumpet S4 > '97 VFR 750
lee125
PostPosted: 11:06 - 06 Jun 2006    Post subject: Reply with quote
ok thanks mate
Rit
PostPosted: 18:19 - 06 Jun 2006    Post subject: Reply with quote
Surely even if you had it welded back on the balance would be all over the place , which is prolly why it snapped after welding anyway.
Best get a real one else that bit of metal is gonna fly off again and you may not be so lucky.
You watching this rubbish?
Naaaa, switch over, Neighbours is on in a minute!
www.ritzbitz.co.uk
PostPosted: 18:37 - 06 Jun 2006    Post subject: Reply with quote
If it was TIG welded by someone who knows what they are doing, it would probably fix.
Issues being (as mentioned by Rit) balancing the thing, finding someone who is good at TIG welding and the fact that someone appears to have attempted a repair already using a metal solder which will all need to be cleaned off before you can weld it.
All in all, replacing the part would be better and probably cheaper unless you know a good welder (welding alloy well is a tricky skill).
lee125
PostPosted: 20:27 - 06 Jun 2006    Post subject: Reply with quote
ok thanks for the advise i will keep an eye out on ebay Thumbs Up Thumbs Up
kn76cbr
PostPosted: 20:38 - 06 Jun 2006    Post subject: Reply with quote
I've got C&G in welding and thats just plan silly thinking thats going to hold
PostPosted: 20:50 - 06 Jun 2006    Post subject: Reply with quote
This your NSR?
Give david silvers a phone. You might get a surprise, some stuff is pretty cheap.
https://www.davidsilverspares.co.uk
lee125
PostPosted: 21:35 - 06 Jun 2006    Post subject: Reply with quote
This your NSR?
no,its off one of my dtr's
lee125
PostPosted: 21:39 - 06 Jun 2006    Post subject: Reply with quote
ive had the bike for 2 years now and its holded fine until now and thats with riding on mx tracks,the only reason it snaped off is because i used grips on it whilst i was trying to remove the clutch basket Thumbs Up ,but i will try and get a different one anyway
The last post was made 19 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 73.79 Kb
