Electric problems doing my head in
MarkJ
PostPosted: 14:11 - 07 Jun 2006    Post subject: Electric problems doing my head in Reply with quote
From what I've gathered, the bloke who had the Hornet before me did a few DIY jobs on it, one of which being the twin headlights. As some of you may remember I had a few problems with the bike at first, one of which was the elctrics with the lights and tacho, where when you turned the lights on the tacho needle would drop to 0. Turn the lights off and you get the needle back. I took it to a dealers who fixed it and I was a happy chappy.
Until today, when it started doing it again.
From what I could see its doing the same, except when I turn the lights on I now also get both the indicator lights on my dash on all the time!
What do you guys reccommend I do? If I phone the dealers that fixed the elctrics the first time round would to sort it again for free since it hasn't worked or would they argue it's worked fine for ages and it's my problem now? The bikes going in for an 8k Mile service at another shop next Thursday, should I ask them to do it, and if so how much would they charge extra?
Also on a side note, my front left indicator bulb keeps going, could this be due to the same problem, or is it something different, like the sealant I found? Link here.
PostPosted: 18:34 - 07 Jun 2006    Post subject: Reply with quote
Sounds very like the symptoms of a bad earth connection, the current from the headlights can't get to earth easily and so it trying to earth itself backwards through some of the other bulbs.
Bet you whoever fitted the lights has tried to earth them onto the front subframe or yokes. These are only tenuously in contact with the rest of the frame due to insulation from rubber bushes and bearing grease. In other words, not a good place to earth an electrical circuit.
Check this out and if I am right, just run an earth wire right the way back to the battery or a proper frame earth point (like under one of the ignition coil bolts).
doggone
PostPosted: 19:04 - 07 Jun 2006    Post subject: Reply with quote
Yes ^ it's definitely to do with a bad earth so I think you may be best to investigate yourself.
MarkJ
PostPosted: 23:10 - 07 Jun 2006    Post subject: Reply with quote
I imagined it was a bad earth, but I never even thought about that. Cheers mate, I'll have a gander in a minute Thumbs Up
Edit: Just had a look, there wasn't anything fixed to the yokes, but all the wires bugger off under the tank, which I'll take off at the weekend for closer inspection. Definitely food for thought though.
If I can't get it fixed, would the place that originally "fixed" the problem do it for free? Or will they just tell me to pay for them to do it again?
Also, how should I test for the tacho needle working when the tank is off (hence no petrol)? I'd imagine I'll just have to turn it over with the starter motor and no petrol, but let me know of any other ways Thumbs Up
PostPosted: 01:54 - 08 Jun 2006    Post subject: Reply with quote
There is usually enough fuel lurking about in the float bowls to run the engine on tickover for a few minutes.
I have on old lawnmower petrol tank I can hang on the handlebars with a long bit of fuel line. Very handy if you are balancing carbs.
The last post was made 20 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 46.27 Kb
