| Hotdog |
 Hotdog Nearly there...
| mr.z |
 mr.z World Chat Champion
 Posted: 13:04 - 19 Jun 2006 Post subject: |
The best are moulded to your inner ear and very expensive (£150+?)
I had great results out of my sony in ear ones, not as good as earplugs but not bad, only thing is they aren't overly comfortable with the helmet i have at the moment... ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Hotdog |
| mr.z |
| Hotdog |
 Posted: 13:36 - 19 Jun 2006 Post subject: |
The Koss ones look like this:
https://i26.photobucket.com/albums/c117/hotdog451/Koss.jpg
They sure do look comfy, don't they ?
Unfortunately they are vented, they have drillings in the back to allow the diaphragm to respond, I'm pretty sure this is why they are useless at attenuating noise.
Hotdog. ____________________ He's a gentleman, a scholar, he's an-acrobat, he's the one and only truly original.......
Hotdog....(Defender of the weak, the poor and the innocent)
He's The Ace - He's Amazing...He's the Strongest... He's The Quickest.... He's The Best! |
| NicM |
 NicM World Chat Champion
| Hotdog |
| JonB |
 JonB Afraid of Mileage
 Posted: 14:14 - 19 Jun 2006 Post subject: |
Yeah they are good, brilliant bass but mine blew up within 3 months. ____________________ Be careful whose advice you buy, but, be patient with those who supply it. Advice is a form of nostalgia, dispensing it is a way of fishing the past from the disposal, wiping it off, painting over the ugly parts and recycling it for more than it?s worth. |
| Rookie |
 Rookie World Chat Champion
If you really want to block out background noise, you need noise-cancelling ones. They cancel out the frequency of the background noise, I'm not going into the science of it again, because I get it wrong.
The standard Sony in-ear noise cancellers cost from about £80.
The best non-cancelling, budget earphones on the market as far as I'm concerned are the Sony in-ears. The old model was the MD-EX71, and the new model is MD-EX81. The 71s are absolutely superb, however I'm yet to try them on a bike. I can't imagine any problems, however. |
| G |
 G The Voice of Reason
 Posted: 14:16 - 19 Jun 2006 Post subject: Re: Headphones/earphones..... |
I believe the earphones you have got can be 'modded' to use a standard ear plug, which may provide a bit quieter enviroment.
This place might be worth a look....
https://www.diycustomplugs.com/
They are moulded ear plugs which you can do yourself at home. They can be moulded around headphones as well, it seems.
Tempted to give them a try sometime myself. |
| Hotdog |
| G |
| Hotdog |
 Posted: 15:20 - 19 Jun 2006 Post subject: Re: Headphones/earphones..... |
| G wrote: | | Hotdog wrote: |
Earphones 'who' has ? |
You.
May have been a different model/brand, but pretty sure it was Koss ones at least.
Try a search for 'koss' on here, maybe? |
Hi G,
Unfortunately, they are vented, they have drillings in the back to allow the diaphragm to respond, I'm pretty sure this is why they are useless at attenuating noise.
I've found advice on replacing the rubber 'plug' part with foam (from a different brand) or making your own foam plugs out of earplugs, but I really don't think this will make any difference (other than comfort).
| d8ncer |
 d8ncer L Plate Warrior
| Hotdog |
 Posted: 18:10 - 19 Jun 2006 Post subject: |
| d8ncer wrote: | The best are moulded to your inner ear and very expensive (£150+?)
Have a look at www.diycustomplugs.com
Link to fitting videos for the products on product pages. | Quote: | The best are moulded to your inner ear and very expensive (£150+?) |
I can't find any working video...... ____________________ He's a gentleman, a scholar, he's an-acrobat, he's the one and only truly original.......
| d8ncer |
 Posted: 18:13 - 19 Jun 2006 Post subject: |
| Velocifero |
 Velocifero Borekit Bruiser
 Posted: 18:17 - 19 Jun 2006 Post subject: |
| Hotdog |
 Posted: 18:18 - 19 Jun 2006 Post subject: |
Quicktime is missing software required to perform this operation. ____________________ He's a gentleman, a scholar, he's an-acrobat, he's the one and only truly original.......
| Andy C |
 Andy C Tree Seeking Missile
 Posted: 18:33 - 19 Jun 2006 Post subject: |
The headphones i used (ones Mr Z have posted) to have (sony £30 ones) good for the money but i have some and wouldnt get another pair within a month the rubber on the wire same off, still work fine but taking a helmey off near them makes it happen. a friend of mine had the same problem. They are good for 90mph though and dont let the wind in much
Heres is what mine look like now, also the wire tingles on the back of your neck and mean i needed a neck warmer on while off the bike to listen to them
https://i32.photobucket.com/albums/d20/andy13_uk/DSC00091.jpg
https://i32.photobucket.com/albums/d20/andy13_uk/DSC00092.jpg
https://i32.photobucket.com/albums/d20/andy13_uk/DSC00093.jpg
I now have Etymotic Research ER6 headphones and there much better, cheapest they go for is £65+ but im into my headphone so pay this much. If i could go back i would have brought the Etymotic ER6i ones, very simular but smaller ear pods and the range of aftermarket bud are wider for the smaller ear cannal. The ER6 only has foam but ER6i had foam and 2 different rubber one
I brought new small foam filter which were quite expensive (£10 for 4-5 pairs)
I the pic is the carry case, medium + small foam earbuds, Rubber medium bed, filter changing tool, earphones
https://i32.photobucket.com/albums/d20/andy13_uk/DSC00094.jpg
The foam is what i use, the rubber is how they come. easy to change over
https://i32.photobucket.com/albums/d20/andy13_uk/DSC00095.jpg
In my ear
https://i32.photobucket.com/albums/d20/andy13_uk/DSC00096.jpg
These are my recommendation if you have the money, i know a fair about headphones so any questions that you have i try to answer ____________________ 99 RS125 --> 02 SV650s --> 03 Speed Four --> 92 RXS100 --> 93 CB400sf --> 01 CB600f Hornet |
| Hotdog |
 Posted: 18:46 - 19 Jun 2006 Post subject: |
| Andy C wrote: | The headphones i used (ones Mr Z have posted) to have (sony £30 ones) good for the money but i have some and wouldnt get another pair  within a month the rubber on the wire same off, still work fine but taking a helmey off near them makes it happen. a friend of mine had the same problem. They are good for 90mph though and dont let the wind in much
( Pictures snipped)
( Pictures snipped)
These are my recommendation if you have the money, i know a fair about headphones so any questions that you have i try to answer |
Hi Andy,
I'm now considering the ER6i or the Shure E4c or E3c.
Obviously a real world test is worth it's weight in gold.
Have you tried them just for attenuation ?
How much background noise do they block out ?
Cheers.
Get on with your recovery !!
Mike. ____________________ He's a gentleman, a scholar, he's an-acrobat, he's the one and only truly original.......
| Andy C |
 Posted: 18:53 - 19 Jun 2006 Post subject: |
afriad these were brought after the crash so havnt used them on the bike but used the sonys a lot and think the ER6 would stand up better as go deeper into the ear.
HOWEVER, if i could buy them again i would defernetly get the ER6i, i have small ear cannals so had to get small ear buds and ER6i's have small rubber ones but ER6 dont.
The ER6i are also smaller as think they would be much better for biking . They also say on the site they have better bass response than the ER6 which will make the difference at high speed as treble is very hard to hear high speed IMO.
I would go for ER6i if i was you, i think the ER6 are excellent sound insolators so im sure the ER6i would be just as good. But remember with earbud earphones they are only good if you get them to fit into your ear really snug and well
Also, dont get them in white, black defernetly. White go off-white very quickly and just look horible
And im pritty sure the ER6i's will be great at speed ____________________ 99 RS125 --> 02 SV650s --> 03 Speed Four --> 92 RXS100 --> 93 CB400sf --> 01 CB600f Hornet |
| Hotdog |
| Andy C |
 Posted: 19:30 - 19 Jun 2006 Post subject: |
i dont know, all i can say if the sony ones were pritty good as keeping the music ok till 90mph. ER6's are better (as hear less when walking etc) and better fit so think they will be great. My helmet wasnt quiet so think they did a good job
The ER6i's are my recommendation. I was also close to getting the Share E2c aswell as look good.
I deferenetly think earphones that go into your ear at £50-70 price range are what work well for riding. Of course more expensive would be even better but not needed  ____________________ 99 RS125 --> 02 SV650s --> 03 Speed Four --> 92 RXS100 --> 93 CB400sf --> 01 CB600f Hornet |
| Hotdog |
| Andy C |
 Posted: 20:17 - 19 Jun 2006 Post subject: |
yes this is a major problem i found but i dont have music that loud that is why i have tried so many headphones (about 6th pair). The sonys didnt need to be turned up to much at all and still hear the music at higher speeds. Though it wasnt as good quility as i wanted so invested in these headphones.
I think they wont need turning up and filter all the noise on the bus that im currently having to catch to get to college and very good sound quility, noticing parts of songs i havnt noticed before as reproduces the sound so well
It a shame you cant borrow mine for the day, if you were nearer  ____________________ 99 RS125 --> 02 SV650s --> 03 Speed Four --> 92 RXS100 --> 93 CB400sf --> 01 CB600f Hornet |
The last post was made 20 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
