MOT
JodieWodie
Reflective Banana
PostPosted: 17:18 - 29 Jun 2006    Post subject: MOT Reply with quote
Bike's just failed it's bluddy MOT Rolling Eyes
The bloke wouldn't say on the phone..wanted to say what is wrong with it in person
Is this generally a bad sign ?
Would happen when I am stoney broke too Rolling Eyes
How long do I have to get whatever it is fixed ? I am guessing until the date of what my original MOT is,... which would be in a weeks time Shocked
Courage doesn't always roar. Sometimes courage is the quiet voice at the end of the day saying, "I will try again tomorrow"
carvell
Scuttler
PostPosted: 17:24 - 29 Jun 2006    Post subject: Reply with quote
Indeed, up until the expiry of your current MOT.
If you leave it with them, they'll have it fixed and re MOT'd before a week I imagine. It'll cost you though.
Yamaha TDM 850
mattish
PostPosted: 17:27 - 29 Jun 2006    Post subject: Reply with quote
I was told that with the digital database registered MOT's that if it fails, even if its tested before the expirey date of the old MOT, you can not legally take the vehicle on the road as it will flag up as no MOT to mr fuzz?.
Could well be complete BS!, but thats what I was told Rolling Eyes
JodieWodie
Reflective Banana
PostPosted: 17:28 - 29 Jun 2006    Post subject: Reply with quote
Gutted Neutral
Give me mi bike back ya thieving bast*rds! Sad
sob
I bet there's nothing wrong with it
They just want money
But how the hell would you know ?
Ah..poo... I am a bit sad
0ddball
PostPosted: 17:33 - 29 Jun 2006    Post subject: Reply with quote
You can legally ride to and from a test station without an mot so don't worry, you'll be able to ride it home if you want.
carvell
Scuttler
PostPosted: 17:36 - 29 Jun 2006    Post subject: Reply with quote
Wot he said.
Yamaha TDM 850
JodieWodie
Reflective Banana
PostPosted: 17:37 - 29 Jun 2006    Post subject: Reply with quote
Great
Cheers all
Will find out what the hell it's failed on in about half an hour
*fingers crossed*
May only be a £20 repair Wink
Yeah, it will be...
thinks positively
carvell
Scuttler
PostPosted: 17:42 - 29 Jun 2006    Post subject: Reply with quote
How old is the bike?
Yamaha TDM 850
JodieWodie
Reflective Banana
PostPosted: 17:43 - 29 Jun 2006    Post subject: Reply with quote
1995
map
Mr Calendar
PostPosted: 17:46 - 29 Jun 2006    Post subject: Reply with quote
Hope you get it sorted and it's not expensive.
FWIW the VOSA admits an MOT certificate is just a snapshot of the vehicle's condition (which is right!).
VOSA leaflet wrote:
An MOT certificate confirms that at the time of the test, without dismantling, the vehicle met the minimum acceptable environmental and road safety standards required by law. It does not mean that the vehicle is roadworthy for the life of the certificate. The test does not cover the condition of the engine, clutch or gearbox.
JodieWodie
Reflective Banana
PostPosted: 18:45 - 29 Jun 2006    Post subject: Reply with quote
Damn and blast,
gona cost £500+ to fix
and I only get a free re-test if I get the repairs done in 7 days
No chance dude ! Shocked
Points picked up on:
No rear reflector
Rear position lamp does not illuminate immediately
Front bearing have excessive play
Rear suspension stiff
Rear tyre valve stem damaged
Rear tyre needs replacing
Drive chain excessively tight
Absolutely gutted
I genuinely don't know what to do
Going to keep it locked up in the garage
I only have £400 to keep the entire family and stuff going for the next 2 weeks. There is no way I can find that money
Bah
JodieWodie
Reflective Banana
PostPosted: 18:50 - 29 Jun 2006    Post subject: Reply with quote
They said that the rear shock would probably need replacing, but they couldn't tell until it was all stripped down
But they are almost certain it will
God, I wish I knew how to fix bikes !
brooky
PostPosted: 18:51 - 29 Jun 2006    Post subject: Reply with quote
Exactly what I was going to say. Either you have left other bits out or the mech is bullshitting you. Mate, I'd reccomend going to another garage and seing what they quote.
Good luck Thumbs Up
Suzuki GSX-R 750 K6.
JodieWodie
Reflective Banana
PostPosted: 18:55 - 29 Jun 2006    Post subject: Reply with quote
I think I am being had!
On the mot failure it only lists what i first put... thenhe said the shock would 'probably need doing'
And that is about £220 on it's own
Can they tell this purely from 'stiff rear suspension' ?
flat spot
PostPosted: 19:04 - 29 Jun 2006    Post subject: Reply with quote
Can't some one go round and help her?
Reflector £2
Rear position lamp? charge battery, clean connectors. £0
Front wheel bearin replaced £20 for 2 if it's them. Headrace tighten £0
Oil all linkages for rear suspension or replace shock with aftermarket M+P job. Dunno what bike it is. But £200 probably.
Rear tyre + stem dunno ring round for a quote.
Loosen and oil chain £0.
I reckon £250 all in if it need a new shock.
instigator
PostPosted: 19:06 - 29 Jun 2006    Post subject: Reply with quote
JodieWodie wrote:
No rear reflector - £4
Rear position lamp does not illuminate immediately - New lamp or switch - £5?
Front bearing have excessive play - Fuck knows.
Rear suspension stiff - Replacement shock - £30 if that off ebay? Kickstart would know
Rear tyre needs replacing - £85, probably £110 ride in ride out.
Drive chain excessively tight - £0 - Get hubbie to slacken it
Or perhaps a slightly used tyre for maybe £50 or less off ebay. Shocks for the FZR seem to be relatively common, look to find if any alternatives fit as that will mean you have more at your disposal on ebay.
Is hubby mechanically minded? Most of that doesn't really require much knowledge. No idea on the tyre valve or front bearing though.
Tiems like this you can't give it to a garage for them to do the work. Any BCF'ers near you?
JodieWodie
Reflective Banana
PostPosted: 19:10 - 29 Jun 2006    Post subject: Reply with quote
Hubby does bits, but doesn't really want to delve and then get stuck!
I don't know if there are any mechaniccal minded people near me Confused
instigator
PostPosted: 19:12 - 29 Jun 2006    Post subject: Reply with quote
Time to ask. Smile I'd help but I'm nowhere near you. Laughing Surprised theres not more offers of physical help on this forum, kind of disappoints me in a way I guess.
0ddball
PostPosted: 20:08 - 29 Jun 2006    Post subject: Reply with quote
You sounded surprised that it failed. Surely you knew it would if the tyre needs replacing. Confused
Then again, with the BS list (or at least BS prices) they have knocked up i'd get a second opinion on the tyre too if it looks ok.
I don't know if they do bikes but i take my cars to the local ambulance service station. They just do mot's not repairs, so have no incentive to make up jobs or fail it on silly little things.
PostPosted: 21:03 - 29 Jun 2006    Post subject: Reply with quote
Another vote for that price being way too high. Rear linkages can be a pain, but 90% of the time you will be fine just stripping them and greasing them.
And you can get a rear shock rebuilt for under £100 (even the ones that are not meant to be rebuildable).
tonyyzf
PostPosted: 22:42 - 29 Jun 2006    Post subject: Reply with quote
Sounds too much like a rip-off to me, saw you coming, get it looked at somewhere else and flag up the name of the first place so we can all avoid it.
Something dark reddish with two wheels and cagiva written on the side
SS50, CB175, CB250N, CB350, CB750K2, DT250, CB750K1, CB750F1, XS1100, CB750F2, FJ1200, FZR1000, YZF1000, GSXR1000, Cagiva Navigator, Triumph Tiger 1050
https://www.cliqueyclanmcc.co.uk/
Whosthedaddy
PostPosted: 22:45 - 29 Jun 2006    Post subject: Reply with quote
I'd recommend going somewhere else.
You could always get the cheapies fixed and take for retest at a different centre and see if they have the same comments. I have heard of failures passing withiout the work being carried out as the testers are not being such assholes.
Jack_Cheese
PostPosted: 23:10 - 29 Jun 2006    Post subject: Reply with quote
Do the work yourself and get your hands dirty Thumbs Up
I have no mechanical experience prior to owning this bike, and i've chenged the fork seals myself, and fully derestricted it myself.
Bearings are cheap and easily replaced. Get the exhaust off, get a trolley jack under the engine and lift the bike (making sure the centre of mass is behind the jack, then put axle stands either side of the engine, and a plank or two of solid wood across them.
Then it's off with the front wheel to change the bearings.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
map
Mr Calendar
PostPosted: 23:38 - 29 Jun 2006    Post subject: Reply with quote
brooky wrote:
...the mech is bullshitting you....
Couldn't be the stereotype and upping the prices for all this technical stuff because you're a little girlie and as you're obviously so far away from the kitchen you'll not know what a socket set looks like Rolling Eyes
Nah, this is the 21st century, garages can't do stuff like that anymore Wink
...note to self, must turn off cynic mode before talking to the little woman Very Happy (damn, patronising mode still on Brick Wall)
yambabe
PostPosted: 01:20 - 30 Jun 2006    Post subject: Reply with quote
Yes you do. In Rugby, the house where we had the BBQ after your rideout all that time ago. I'm sure Pete would be happy to help you sort it out - if you don't still have contact details drop me a PM but don't expect a reply til Sunday cos I'm off to the MotoGP in about 5 hours time!
The last post was made 20 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 133.23 Kb
