had a accident this morning- chain fitting?
shaba2000
PostPosted: 14:48 - 08 Jul 2006    Post subject: had a accident this morning- chain fitting? Reply with quote
I was riding on dual carridgeway this morning on way to work in middle lane car in right lane suddenly realised he was in wrong lane and pulled his car into mine causing me to brake and the bike went down with me on it acorss the dual carridgeway.
lucky for me the cars behind stopped in time so didnt get run over!
my bike is in suprisingly good condition, its more me who is more damaged.
the chain on it came off and now is bent, and gear lever bent with broken side indicator.. was wondering if i get a new chain how easy is it to fit it?
0ddball
PostPosted: 15:00 - 08 Jul 2006    Post subject: Reply with quote
It depends if you have a chain riveter (£40 for a cheapo, £100 for the best). If you have it's straight forward.
If not you can get the new chain riveted at a bike shop (only about £3) and slip the swing arm out enough to get the chain on. Not as straight forward but still pretty easy.
shaba2000
PostPosted: 15:14 - 08 Jul 2006    Post subject: Reply with quote
sorry to sound stupid but what the swing arm? is it teh metal frame near the small cog in middle of bike?
MattHirst
PostPosted: 17:25 - 08 Jul 2006    Post subject: Reply with quote
Its the part that your rear wheel fastens to and roughly just behind the engine it will be on a pivot...with a rear shock attatched to the frame and swinging arm.
Depending on what bike you have, your rear shock will be enclosed up in the frame, or exposed towards the rear of the bike.
Here is a pic of a swinging arm
https://www.worldendurance.co.uk/05/albacete/alba05051902.jpg
Just a random piccy i found on the net...
HTH
Matt
Rit
PostPosted: 17:41 - 08 Jul 2006    Post subject: Reply with quote
Not having actually bought a new chain yet and as it is only a couple of quid or so to get one riveted together, do they also come with a split link so you could at least ride down to the shop?
You watching this rubbish?
Naaaa, switch over, Neighbours is on in a minute!
www.ritzbitz.co.uk
MattHirst
PostPosted: 17:52 - 08 Jul 2006    Post subject: Reply with quote
I think just about every chain has a split link because no matter how hard you tried, you'd never get it on.
The people that can rivet them will only shorted it down and rivet it back to the split link, then you use the split link to get it on your sprockets and then fix it together via a removable rivot in the split link.
Please correct me if i am wrong Smile
Matt
0ddball
PostPosted: 18:20 - 08 Jul 2006    Post subject: Reply with quote
New chains come as one long length which is unjoined. You can either join both ends with
a split link
https://www.gussetbikes.com/gusset/product_images/thumbs/chgu-316-slink.jpg
or a rivet link.
https://www.reginachain.it/eng/use_and_maintenance/images/trasmissione_04.jpg
The rivet link is said to be stronger and recommended for powerful bikes.
shaba2000
PostPosted: 18:28 - 08 Jul 2006    Post subject: Reply with quote
thanks for replies..
my chain has actually bent it sits on the cogs but is not straight, so will deffo need a new chain..
have been quoted £150 by shop for chain, sprockets, and fitting?
this sound fair?
mr jamez
PostPosted: 18:52 - 08 Jul 2006    Post subject: Reply with quote
If the chain has snapped and doesn't sit 'straight' I would be concerned that the swing arm or frame has been bent in some way. What bike is it? the cost of a kit varies from about £20 to £100, £150 seems a bit steep to me even if it is a large sporstbike.
0ddball
PostPosted: 19:04 - 08 Jul 2006    Post subject: Reply with quote
Depends on the make and type of the chain. They range (starting with the cheapest lowest quality)
standard < heavy duty < O ring < X ring.
I replaced mine a few months back and paid £70 for a D.I.D O ring chain and JT sprockets. Then £3 for the chain joining and i used the swingarm moving method.
So it's possible to do it for half that quoted price if you get you hands dirty.
Looks like thay are charging at least £80 labour which seems a bit much. The biggest bike shop in my area which are well known for being expensive only charge £45 fitting. But i don't know what London rates are like.
Ichy
PostPosted: 19:24 - 08 Jul 2006    Post subject: Reply with quote
Can't see how a chain can bend, there are many things that will break well before the chain shows any sign of damage. Are you sure its not the rear wheel alignment? Do you have a photo?
Vin
PostPosted: 19:31 - 08 Jul 2006    Post subject: Reply with quote
While not wishing to upset/have a go at anyone see this pic of a split link. Most of you know already but I didn't want anyone to look at the prevoius picture and get confused about what is included in a split link.
Karma
edd
PostPosted: 19:48 - 08 Jul 2006    Post subject: Reply with quote
I dont see how you can have bent your chain really, they move an awful lot across the whole travel. Not that its not possible mind. Id check that your rear end alignment is right before shelling out for a chain of that price.
Also this might sound like a stupid question, but if some blind cager wiped you out, why arent you riding a nice shiny courtesy bike while his insurance company repairs your bike at their cost? Confused
Bluespark Automotive - Diesel Tuning for Performance and Economy
shaba2000
PostPosted: 22:20 - 08 Jul 2006    Post subject: Reply with quote
the guy that cut me just drove off without a worry. the cars behind saw it but no one got his plate, he was driving so fast.
the chain came off the sprocket and got stuck in the swing arm, and as me and some helpful driver were trying to move the bike off the carridgeway it just made the chain worse.
then the recovery driver came and we had to pic the back end up and push onto recovery truck which made it even worse cause the chain was stick in the swingarm bit..
the rear wheel is aligned okay but chain is pysically bent kind of twiseted. it has not snapped. will take a pic tom once i get the feelings back in my hands! Neutral
can i just buy a chain and fit it or do they all comes with the sprockets?
it is a 1996 kawasaki gpz500s by the way.
kawasaki Ninja-zx6r 1997 (f3)
THCi
PostPosted: 01:36 - 09 Jul 2006    Post subject: Reply with quote
Id personally recommend replacing sprokets with a new chain.
Simply because normally it comes to be that chains and sprockets wear at a similar rate-a wearing chain will cause the front spoket to 'hook' (see this pic). Ive had one where the actual spines on the sprocket ended in a sharp point (I wondered why my new chain only lasted a month Whistle )
Look in your owners manual for a more exacting spec for your sprockets, they should have nice and smooth edges.
Total pricing for DIYing it:
Front Sprocket: M&P JT Sprocket £7.00
Rear Sprocket: M&P JT Sprocket £11.25
Chain: Here I draw a blank, M&P have got a Gold X-Ring for £70 (I wouldnt pay that much!) Here
Chain Riveter: M&P 'Heavy Duty Chain Splitter' £19.99 (questionable quality for that kind of money, but should do the job)
As you can see, even if you went for the Gold X-Ring chain, it would cost you a LOT less than you were quoted. Bear in mind that you would need a rather large (24+ mm) socket and 1/2" drive to get the front sprocket off, and the rear will be a bitch as well. Probably coated with enough chain lube that any tool you apply will just come straight off.
DIY-it, battle scars are always fun! Thumbs Up Laughing
Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
"We're not gonna die. We can't die, Bendis. You know why? Because we are so...very...pretty. We are just too pretty for God to let us die."
0ddball
PostPosted: 01:59 - 09 Jul 2006    Post subject: Reply with quote
Iirc the 2 front sprocket bolts are 8mm and it's literaly less than a 2 min job.
The rear is 6 13mm nuts and is easy too providing the threads are in good condition.
THCi
PostPosted: 02:05 - 09 Jul 2006    Post subject: Reply with quote
No need for 24mm+ socket then. Why was he quoted £150 for fitment and supply of ~£70 worth of metal?
I want to be a bike mechanic for 15 mins work earning £80! Cash in hand some of it as well! Laughing
ZRX61
Victor Meldrew
PostPosted: 02:59 - 09 Jul 2006    Post subject: Reply with quote
Anyone else hearing alarm bells here? The guy not only has a Kaw 500 & doesn't have the first bloody clue what a swingarm is, but the chain was apparently so bloody slack it "fell off" the rear sprocket from a minor prang??? Shocked
0ddball
PostPosted: 03:15 - 09 Jul 2006    Post subject: Reply with quote
I guess so but if someone's going to learn, it's best they do so on a cheapish simple bike. And hands on is the best experience.
syl
PostPosted: 03:22 - 09 Jul 2006    Post subject: Reply with quote
If you can't just fix it yourself for less than a hundred quid, then don't forget about the insurer of last resort, the MIB.
MIB was established in 1946 as a private company limited by guarantee for the purpose of entering into Agreements with the Government to compensate the victims of negligent uninsured and untraced motorists. Every insurer underwriting compulsory motor insurance is obliged, by virtue of the Road Traffic Act 1988, to be a member of MIB and to contribute to its funding
What are the Untraced Drivers' Agreements?
These agreements between the Secretary of State for the Environment and Transport and MIB explain the precise circumstances under which an application from a victim of untraced motorist will be paid.
In general terms, the 1972 agreement specifies that MIB will make an award for compensation to the victim of a negligent untraced motorist in respect of personal injuries only, where such injuries are caused by the use of a vehicle which is required to be insured by law.
The 1977 agreement simplifies, for certain cases, the procedures detailed under the 1972 agreement.
The 1996 agreement consolidates the 1972 and 1977 agreements, updates references to statute and introduces a further requirement that to be eligible for compensation the applicant must have reported the accident to the police within a reasonable period. The 1996 agreement applies in respect of accidents occurring on or after 1 July 1996. The 2003 agreement applies in respect of accidents on or after 14 February 2003 and consideration will be given to property damage subject to the accident being reported to the police within 5 days or as soon as reasonably possible and the offending vehicle is identified. Claims will be subject to a £300 excess
As well as damage to your bike, remember to claim for each and every painful scratch or bruise. I'm sure something must hurt, just a little bit at least. People often dismiss a slight muscular ache a short time after the accident but it often gets worse before it gets better. That way you will get enough back to pay for your bike after the excess - the MIB don't like paying for property damage anyway but will fork out for injuries. Remember to tell the police about the accident (preferably within 24 hours) and let them know about any (potential) injuries you have. Get your legal cover working for you, if you have it, otherwise try one of the free sites such as Rider Support.
Current bike: Kawasaki Z750S
tonyyzf
PostPosted: 09:57 - 09 Jul 2006    Post subject: Reply with quote
Matt
Wot da fuk?? Does anyone understand this? Confused
Something dark reddish with two wheels and cagiva written on the side
SS50, CB175, CB250N, CB350, CB750K2, DT250, CB750K1, CB750F1, XS1100, CB750F2, FJ1200, FZR1000, YZF1000, GSXR1000, Cagiva Navigator, Triumph Tiger 1050
https://www.cliqueyclanmcc.co.uk/
Teaman
PostPosted: 10:27 - 09 Jul 2006    Post subject: Reply with quote
you sure the rear wheel wasnt knocked, when you put the chain on did you push a bit onto the rear cog and push the bike backwards? if so your a numpty,
if you were able to slot it back on Id check the rear wheel alignment, Ive not heared of a crash and nothing other than a bent chain has happend, take a long hard look over your bike, or preferably if your not exactly sure on what to look for , get someone who does (not just says they do) know what there looking for, tiz your life at the end of the day.
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
shaba2000
PostPosted: 16:10 - 09 Jul 2006    Post subject: Reply with quote
no the rear wheel was not knocked. A car just came right into my lane causing me to swirve and brake at same time doing aorund 50 mph which caused the bike to fall to ground.
the chain is deffo bent it does not sit straight on the sprockets at all. i think i will do the job myself from calculating the costs it will be around £150 for chain, sprockets, tool, rear stand etc but at least i get to keep the tool for future use.
i apprecaite al advice guys sorry to keep buggin everone this bike has been nothing but bad luck and every time i try to get it to selling standards something happens!! but hey only been riding around 4 months so i guess its a learning experience. spent more on my bikee then my car!
THCi
PostPosted: 17:31 - 09 Jul 2006    Post subject: Reply with quote
The GPZ not got a centre stand? Thats all you really need.
It WONT cost you £150, as I pointed out total cost for sprockets, chain & tool was 90, which included £70 of chain-over board IMHO, unless its a sportsbike I wouldnt put a Gold XRing on my bike! Standard XRing yes, gold no.
Your local bike shop should do chain-on-a-roll at a much better price, roll chain tends to be stronger as well. Thumbs Up
ZRX61
Victor Meldrew
PostPosted: 18:45 - 09 Jul 2006    Post subject: Reply with quote
Didn't get one bloody word of it, is he Albanian? Shocked
The last post was made 20 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 134.44 Kb
