Quick question on revs
coolfox1
PostPosted: 11:16 - 20 Jul 2006    Post subject: Quick question on revs Reply with quote
Just a quick question
doing 70/80 on motorway and bike is revving at 8000 revs is this normal
Feels high, almost like there should be another gear to drop it down.
When I take the throttle off the bike it doesnt coast/role, it engine brakes and I slow down a lot faster than expected or required.
on a ZX6R 600CC
or is it just me ?
Hex
Party Boy
PostPosted: 11:25 - 20 Jul 2006    Post subject: Reply with quote
Has it been down geared at all?
My CBR is standard gearing and I think its at about 6000-7000 for 70-80mph.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
akaDAVE
I have a ZXR-400 which does about 8000 at 80mph. I would have thought the 600 would be cruising alot easier at that speed!?
My 400 is only just getting started at 8k though so even though it sounds like it needs another gear it doesn't. It weren't built for cruisin'.
I was thinking about getting a 600 purely for making it a bit less hectic cruising on the motorway, is this not the case, anyone?
GSXR600
coolfox1
PostPosted: 11:44 - 20 Jul 2006    Post subject: Reply with quote
Embarassed not sure what down geared is or how to tell if it has, tbh I doubt it.
firefox
PostPosted: 11:48 - 20 Jul 2006    Post subject: Reply with quote
more teeth on the back sprocket and less on the front i think Confused
Rookie
PostPosted: 11:51 - 20 Jul 2006    Post subject: Reply with quote
Which gives it faster acceleration, but higher revs at high speeds, so consequently a lower top speed.
If you've never changed the chain and sprockets, there's a chance it is.
david916
PostPosted: 11:53 - 20 Jul 2006    Post subject: Reply with quote
A ZX6R is a high revving bike anyway, but 8000 revs does sound too high at 70 mph if you are in top gear! I would have thought it would be several thousand revs lower than that. Is the bike stuck in too low a gear? Kawasaki engines are pretty good, but they don't make the best gearboxes in the world. Suzuki gearboxes are definately much better! I had a ZX6R F3 some years ago and loved the bike. Had to use the gears a lot to make the bike work though and sometimes when changing up a gear it felt like I'd changed up, but in fact I hadn't. Also, it was easy to forget what gear you were in with all the changing up and down because the bike was designed to be very high revving so changing up to top gear was sometimes missed, not that it would hurt the engine just the fuel consumption maybe!
There should be some engine braking when rolling off the throttle in top gear at 70 mph, but not a huge amount. Obviously there would be a lot more engine braking if you were in a lower gear!! Making sure you are definately in top gear by counting through the gears as you change up and actually feel them engage might solve your problem or otherwise the problem be with the gearbox itself - not good? Sad
Cool
Currently own/regularly ride :
Suzuki SV1000S K4
Rookie
PostPosted: 11:56 - 20 Jul 2006    Post subject: Reply with quote
Confused Just thinking about this - would clutch slip cause this? If it was a sustained slippage instead of the on/off it usually presents itself as, it would cause the high revs/low speed issue, not sure about the increased engine braking.
Bendy
Mrs Sensible
My bike's been downgeared and sits at about that in 6th.
Take a pic of your rear sprocket and folk on here'll probably tell you straight away if it's a standard sprock or not.
extreme3d
PostPosted: 12:35 - 20 Jul 2006    Post subject: Reply with quote
It's to high and rpm. Dodsi's zx6r J1 and my SV have the same gear ratios as standard and both do 7000rpm at 90mph.
Count the gears, is it 6 before it stops?? If it's not then it's not reaching 6, if it is then the sproket's been changed.
Paul@125power
PostPosted: 12:46 - 20 Jul 2006    Post subject: Reply with quote
For standard gearing on the CBR125R the bike does 60mph @ 8000rpm in 6th.
Paul Thumbs Up
If at first you don't succeed.....destroy all evidence that you tried.
Yamaha YQ100 (RIP)......Honda CBR125R
BigChris
PostPosted: 13:10 - 20 Jul 2006    Post subject: Reply with quote
I reckon yer missing a couple of teeth on the back cog only. 8k rpm should have you sitting somewhere about 90-95. If you're saying that yer only about 80'ish, then I would doubt that the front cog has been changed - would result in too much of a change?
btw, 70mph on my zx12 is about 4k rpm...hirrhirr
Middle Finger Mr. Green Middle Finger
Quote Me Happy
PostPosted: 14:14 - 20 Jul 2006    Post subject: Reply with quote
My 636 revs at 9k I think at 100mph if that's any use to you Confused
Johnny GSX-R
PostPosted: 16:04 - 20 Jul 2006    Post subject: Reply with quote
COGS!!! Windmills have COGS....
Gears run against each other
Sprockets are moved by chains (as in the bike)
COGS are big wooden items with pegs powered by a water wheel driving a millstone to grind wheat into flour.
COGS Rolling Eyes
BigChris
PostPosted: 17:23 - 20 Jul 2006    Post subject: Reply with quote
Rolling Eyes
8316
PostPosted: 18:25 - 20 Jul 2006    Post subject: Reply with quote
a standard geared 400 does that revs at the speed...
Now own a Fireblade!! Speed Limits? Bah!
veeeffarr
PostPosted: 18:31 - 20 Jul 2006    Post subject: Reply with quote
COGS Rolling Eyes
Haha, that's why I always laugh when I see "Cog Head" on the boards...
JonB
Afraid of Mileage
PostPosted: 18:46 - 20 Jul 2006    Post subject: Reply with quote
Does seem rather high.
Bandit cruises at 75MPH at 6,000 revs.
tonyyzf
PostPosted: 18:50 - 20 Jul 2006    Post subject: Reply with quote
Wrong gearing on sprockets or..........speedo not reading correctly??
Something dark reddish with two wheels and cagiva written on the side
SS50, CB175, CB250N, CB350, CB750K2, DT250, CB750K1, CB750F1, XS1100, CB750F2, FJ1200, FZR1000, YZF1000, GSXR1000, Cagiva Navigator, Triumph Tiger 1050
https://www.cliqueyclanmcc.co.uk/
The last post was made 20 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 103.12 Kb
