Rusty Stainless Steel?
DynaMight
PostPosted: 18:23 - 20 Jul 2006    Post subject: Rusty Stainless Steel? Reply with quote
Went to look at a Honda SP1 yesterday which has been sat in a shed for a year, the downpipes were pretty rusty. I assume these are stainless steel but can stainless steel rust through like mild steel or is it likely to be just surface rust? any long term effects?
Thanks
craigs23
Mr Muscle
PostPosted: 18:26 - 20 Jul 2006    Post subject: Reply with quote
Hmmm, sounds like a job for a dab of wet'n'dry.
dave1rs
PostPosted: 18:27 - 20 Jul 2006    Post subject: Reply with quote
can rust through eventually,but takes along time,the better the steel grade the longer it will last.
should just be surface on an sp1,wet n dry and a bit of polish should bring them back up to standard(or better).
tatters
Exxon Valdez
PostPosted: 18:32 - 20 Jul 2006    Post subject: Reply with quote
Will be just surface rust, for serouis rust on stainless steel it would have to be exposed to salt water.
DynaMight
PostPosted: 19:17 - 20 Jul 2006    Post subject: Reply with quote
I was hoping as much, it didnt feel like nasty rust (if that makes sense) it was very smooth still.
mchaggis
PostPosted: 19:38 - 20 Jul 2006    Post subject: Reply with quote
Stainless steel rusts beautifully. You should see the exhausts on my GPZ! Shocked
I must not be a troll...
Mmmm, Guinness
SoND
PostPosted: 20:08 - 20 Jul 2006    Post subject: Re: Rusty Stainless Steel? Reply with quote
Thanks
It only happens because it gets heated up so much and makes it vulnerable, if you keep them polished it would stop it happening.
Itchy
PostPosted: 20:10 - 20 Jul 2006    Post subject: Reply with quote
I wonder why companies still use steel and not thicker aluminium instead which doesn't rust would maybe save weight (if the tubes were made thicker but not so thick that it weighed more than steel).
SoND
PostPosted: 20:12 - 20 Jul 2006    Post subject: Reply with quote
Harder to work with, would be a lot bigger than steel to get the same strength. One small knock could bend the pipes out of shape easily.
Jack_Cheese
PostPosted: 23:05 - 20 Jul 2006    Post subject: Reply with quote
Aluminium is soft, expensive to make awkward to weld and just generally not as good as stainless. Duralium would work, though Thinking
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
craigs23
Mr Muscle
PostPosted: 23:35 - 20 Jul 2006    Post subject: Reply with quote
Jack
Or titanium Razz
Remember a DIC ally exhaust I saw on an NC30 Sick
MattEMulsion
PostPosted: 12:23 - 21 Jul 2006    Post subject: Reply with quote
Would an aluminium exhaust just not melt into a pile on the floor?
Yamaha YZF-R6
Jack_Cheese
PostPosted: 19:44 - 21 Jul 2006    Post subject: Reply with quote
Not at all, aluminium does have decent heat resistance, it does soften under heat, and would probably oxidise extremely rapidly, as it normally does on contact with air, but the heat causing expansion of the metal would cause deep oxidisation. Therefore it'd be like having the aluminium anodised. Lovely and white! Very Happy
extreme3d
PostPosted: 19:51 - 21 Jul 2006    Post subject: Reply with quote
It does have remarkably good heat resistance yes but in order to make an aluminium exhaust with the same strength as a steel one it would need to be a lot thicker. Remember the exhaust is right in the firing line for stones etc kicked up from the front wheel. So much thicker in fact that it wouldn't weigh much less than a steel one. Then theres cost... aluminum isn't cheap.
Jack_Cheese
PostPosted: 19:56 - 21 Jul 2006    Post subject: Reply with quote
I'd already highlighted the softness and cost, you must be getting distracted by my avatar again Very Happy
Twisted Evil
proximity
PostPosted: 23:26 - 21 Jul 2006    Post subject: Reply with quote
I believe the main reason for not using aluminium is it conducts heat too well and the idea is to keep the gasses as hot as possible until they reach the outlet.
2004 Aprilia Tuono
Jack_Cheese
PostPosted: 14:46 - 22 Jul 2006    Post subject: Reply with quote
Proximity up yonder is correct, hadn't thought of that. Thinking
The last post was made 20 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.41 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 94.86 Kb
