overtaking
Keen
PostPosted: 13:19 - 15 Apr 2002    Post subject: overtaking Reply with quote
say you were following a car doing 55 and you wanted to overtake, what gear would you use? in the car I use 3rd then go up to 4th at maybe 65. Would I do the same on my bike? I would use the rev counter for gear changing when I finally get it on the road, but it hasn't got one. All I really want to know is how high I can rev it without killing it, so any help would be appreciated.
Oli
PostPosted: 14:17 - 15 Apr 2002    Post subject: Reply with quote
I just rev as high as possible until the acceleration runs out. Then change up.
TiN
Pocket Tin
PostPosted: 15:17 - 15 Apr 2002    Post subject: Reply with quote
Assuming that you're in 6th, you would probably need to change down to 4th...or something...
Tin
Rob
PostPosted: 17:50 - 15 Apr 2002    Post subject: Reply with quote
I wouldn't bother on a nsr it wont go much quicker anyway!!! Very Happy
ONLY JOKING DONT FLAME ME!!!!!
Love is 1050cc Smile
Milo
PostPosted: 19:31 - 15 Apr 2002    Post subject: Reply with quote
If i was cruising in a nice economy gear i'd knock it down a couple to reach the powerbank, then open the throttle all the way to overtake. change gear when you need to (about 10k) and then change up again after. it's not like gear changing takes long so it's not dangerous to do at any time
craigT19
Jolly Green Giant
PostPosted: 19:50 - 15 Apr 2002    Post subject: hmmm Reply with quote
i usually cruse in 5th so id go down to 3rd i hit 65ish at the red line in 3rd plus it gives you the power to pull off in 4th with no lag
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
batman
PostPosted: 02:05 - 16 Apr 2002    Post subject: overtake Reply with quote
depends on speed, but double down shift should see u fly past anything, just make sure u dont hit it when u do!
Keen
PostPosted: 20:49 - 16 Apr 2002    Post subject: Reply with quote
Does bouncing off the rev limiter damage the engine excessively? I was thinking that when you really wanted to accelerate hard you could just rev it till you felt the limiter and then change up, but I wouldn't want to wreck it.
craigT19
Jolly Green Giant
PostPosted: 20:59 - 16 Apr 2002    Post subject: Reply with quote
Keen wrote:
Does bouncing off the rev limiter damage the engine excessively? .
umm yes as you pass the red-line u should hear the engine knocking besides going pst the red line wont help as the nsr hits optimum power at 10,500 rpm
if you dont mind seing you piston flying through the top of the engine then bye all means red line away Confused
Annabella
Like a person, only smaller
PostPosted: 22:01 - 16 Apr 2002    Post subject: Reply with quote
From about 55 if you're following a car, I usually kick down twice from 5th and pull the throttle back just after I've pulled right over (double checking there's no lorries etc coming the other way before you commit) and take it right up to 10500-11000, maybe just blip onto the red line., though you shouldn;t need to. Most cars are that shocked by such a little thing flying past any how there's no time for them to react, then just accelerate as normal, you've got the advantage oer the cars already.
As long as you do it confidently you won;t have a problem, just don't hesitite.
PostPosted: 13:14 - 17 Apr 2002    Post subject: Reply with quote
In theory the red line is where the engine is safe to go to on a regular basis. Going a little into the red will not do much harm, but is generally fairly pointless as the engine will be a long way past peak power, and power will be dropping away rapidly.
One thing to watch out for is whether the rev counter is actually giving you a true reading. Accelerate really rapidly (only first gear really) and I would suspect that the revs will go up faster than the rev counter shows (same with speedos, as you can probably brake very hard and be back accelerating with the speedo still dropping)
The last post was made 24 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 68.42 Kb
