Idea to further boost fuel economy
Milo
PostPosted: 14:53 - 24 Jun 2004    Post subject: Idea to further boost fuel economy Reply with quote
I've never heard of this being done but I wonder if it will work?
You've heard of electric cars and bikes but what if they had a built in generator? This engine does not directly power the vehicle but instead runs at it's peak revs/power/efficiency to charge the batteries until full and only cuts in again when the levels run low.
I know because of the whole conversion to electricity and stuff it'd lower the efficiency but surely it'd still be pretty darn good?
Also a much smaller engine would be needed to power the vehicle as the acceleration is provided by the motors - a 250cc engine for a car version would surely be enough?
I've been thinking about this for ages and in a few years I'd like to build a concept - but I'd need the money, garage and knowhow first!
Any thoughts on this?
Ads
Shaft drives rule. Razz
Ninja
Caption Abuser
PostPosted: 14:55 - 24 Jun 2004    Post subject: Reply with quote
Thats generally how turbine powered cars run - not directly by the turbine, but by an electric motor taking power from a turbine powered dynamo . . . .
James
4 wheels transport the Body ... 2 wheels transport the SOUL
Mr C
PostPosted: 15:03 - 24 Jun 2004    Post subject: Reply with quote
I think that the problem is probably battery technology and the fact that 100hp electric motor is quite a hefty chunk of copper wiring.
It would be too heavy (in a bike) for any appreciable power to weight ratio
is my first guess without really thinking about it and would have another cycle of losses into it so would actually be less fuel efficient
edit
also, since acceleration is generally governed by torque and high torque motors are even bigger and draw HUGE current so your wiring has to be mighty chunky as well
187.3bhp = 201mph
PostPosted: 15:18 - 24 Jun 2004    Post subject: Reply with quote
Basically how diesel electric trains work, and there are hybrid cars around which use a similar system.
However there are problems. You would certainly need more than a 250cc engine. The electric motors weigh a ton (although you can play with the eletrics and also use them as brakes which generate power as you slow down). The batteries weigh a ton.
Also, how do you fancy sitting at traffic lights with an engine screaming away under the bonnet?
Mr C
PostPosted: 15:26 - 24 Jun 2004    Post subject: Reply with quote
it's also the way ships are going
basically thumpy old diesels are not environmentally friendly or noise freindly any more so more ships are powered by turbines
the problem with turbines is that it's better to remove them to overhaul them than do it in the ship
so it would be better if they were mounted nearer the deck than the keel
the answer - a power station on the deck and electric thrusters for propulsion and steering
it's coming soon
187.3bhp = 201mph
Milo
PostPosted: 16:36 - 24 Jun 2004    Post subject: Reply with quote
So not ideal for bikes then.
How about a few dynamo's on the tyres to power some electric motors and do away with the engine and battery's altogether? Just need a small run-start in the mornings and if you stop at the lights. Rolling Eyes
Mr C
PostPosted: 00:51 - 25 Jun 2004    Post subject: Reply with quote
nope sorry
that's perpetual motion and it's not allowed
each dynamo will have horrendous losses
even if it's 90% efficient, it will still only converty 90% of the rolling energy into electricity
then if you assume the same of the motor then you only end up with 81% of the power you put in
it wouldn't go very far
187.3bhp = 201mph
Flip
PostPosted: 01:11 - 25 Jun 2004    Post subject: Reply with quote
A better idea for fuel ecomony would be to steal fuel Shifty Very Happy
clemsta
PostPosted: 02:22 - 25 Jun 2004    Post subject: Reply with quote
They make diesel trains like this, because if the wheels turned straight off the engine then the gearbox would be the size of a carrage. It would probably be too big for a bike though. Battery would need to be alot bigger, also you'd need a motor plus the engine. I think it would probably be pretty slow as well.
Frost
PostPosted: 05:22 - 25 Jun 2004    Post subject: Reply with quote
such things have been done in cars in the past, where the engine cuts out when its being inefficient and an eletric motor kicks in running off batteries charged off the engine.
in theory what you say could/would work. where by the engine premenantly runs at peak efficiency charging a batterie which then powers the wheels. however if the engine was not powerful enough then when the driving is inefficient(traffic) then battery power is going to drain as the motor is using more power than the engine will produce. similarly when the motor is running efficiently, the engine will be producing more power than neccicary.
Such a system could possibly be built and used in a car however as it uses petrol still, the improvement in efficinetcy would not be as high as if it were a pure electric car or a fuel cell car.
Such a design could not be implemented on a bike as the weight of batteries, generators and eletric motors would make the bike so heavy as to cancel out any increase in efficiency.
nice idea though Smile
mchaggis
PostPosted: 05:44 - 25 Jun 2004    Post subject: Reply with quote
I personally prefer electrically driven supercharged smaller capacity engines. Get the same power as a 1.8 from a 1.0. No turbo lag, lower bsfc (brake specific fuel consumption), variable boost etc etc etc.. That or a compression ignition engine running on powdered charcoal. Very Happy Though I'd rather use biomass for fuel when the petrol goes awol.
As far as using smaller engines for hybrid cars, you still have to produce the power, and still burn the same fuel. Though obviously anything which will let it burn at it's peak efficiency is better. Electric motors might be as efficient as 90%, but with 90% of 20-35% isn't an improvement.
Almost 5am isn't my best time for thinking about these things though. Confused
Milo
PostPosted: 10:22 - 25 Jun 2004    Post subject: Reply with quote
Mr C wrote:
nope sorry
No $hit - I was joking! Razz
There is a gap of 2 years, 35 days between these two posts...
Milo
PostPosted: 12:51 - 30 Jul 2006    Post subject: Reply with quote
Well darn it...someone's gone and done it.
I was at the Motor Show yesterday and there was a new Mini with 4 hub-centre motors and a 240cc twin cylinder generator - this was all that was enough to keep it juiced up...and it was 250BHP+ according to the specs.
Can't remember the company and can't find it on Google - did anyone else see it there?
Told you it would work! Razz / Mr. Green / Neutral / Crying or Very sad
0ddball
PostPosted: 13:23 - 30 Jul 2006    Post subject: Reply with quote
Look on the bright side, if you could have done it you'd have needed about £1m just to build the concept. It has more circuit boards then a branch of Dixons.
Bit of info on it here, actually 640bhp.
https://carscoop.blogspot.com/2006/07/electric-powered-mini-qed-concept-with.html
Though something doesn't seem quite right about it. All that energy from a tiny 250cc ICE as the primary source. Thinking I think there may be a few skeletons in the cupboards that they aren't mentioning.
Zimbo
PostPosted: 15:40 - 30 Jul 2006    Post subject: Reply with quote
There's a Dutch firm called Star Twin making a 1200cc TDi sportsbike, based on a modified VW Lupo TDi engine mated to an FJ1200 gearbox.
The bike weighs around 220kg, puts out around 120bhp and an eye watering 250 foot pounds of torque in performance trim(that's more than a Triumph Rocket 3, for comparison a Gixxer thou puts out about 80 foot pounds) and returns around 150mpg.
https://www.gizmag.co.uk/go/4273/1/
https://i71.photobucket.com/albums/i148/zimbo16/DSCF4200.jpg
PostPosted: 17:17 - 30 Jul 2006    Post subject: Reply with quote
Hybrid bike has already been done. Uses electric power up to about 30mph then transferrs over to the engine. A claimed 180mpg. Sorry.
https://www.hybrid-vehicles.net/images/eCycle/ecycle-hybrid-motorcycle.jpg
https://www.hybrid-vehicles.net/ecycle-hybrid-motorcycles.htm
instigator
PostPosted: 17:38 - 30 Jul 2006    Post subject: Reply with quote
You mean an electric motor in the wheel?
The dutch have busses with this in them, not sure if the idea ever took off or not but don't see why it shouldn't. But the benefits were very clear.
Milo
PostPosted: 19:38 - 30 Jul 2006    Post subject: Reply with quote
Nope - using a generator to power a fully electric vehicle so it doesn't need recharging. You've been able to get hub-center motors for a while now.
Other designs have used a combination of engine and/or electricity to power the vehicle, therefore adding to the overall weight and complexity of the design.
Raffles_Gentleman Thug
PostPosted: 19:22 - 31 Jul 2006    Post subject: Reply with quote
Except that if it's got a generator it isn't fully electric....
There's not much point using a petrol motor to turn a dynamo - you'll get losses at every stage - might as well just use a bloody petrol motor attatched to the wheels.
"Is sir addressing me or is he masticating on a house brick? Because either way sir loses his teeth."
Milo
PostPosted: 20:51 - 31 Jul 2006    Post subject: Reply with quote
You knew what I meant...it saves having two systems side by side (like normal hybrid designs) and lashing them together with electronics.
AND...it obviously works if they've done it using a 240cc engine to keep it running.
I look forward to seeing the finished product.
PostPosted: 20:53 - 31 Jul 2006    Post subject: Reply with quote
There are advantages. Means you can run the engine at a constant RPM which equates to peak efficiency.
But you still get the massive losses you mention. Rule of thumb is (from vague memory) 30% efficiency changing energy from one form to another, so rather than 30% efficiency converting chemical energy to motion, you get 30% efficiency changing from chemical energy to electricity and then 30% of that from electricity to motion.
Itchy
PostPosted: 14:26 - 01 Aug 2006    Post subject: Reply with quote
and the fact that electrical motors don't need clutches, diesel electric trains would probably be more efficient (since there are less conversions) with the diesel engine running the wheels , but considering a 20 ton lorry needs a clutch almost as big as its wheels (and much wider too) , a 5000 ton train is going to need an awfully big clutch.
PostPosted: 22:00 - 01 Aug 2006    Post subject: Reply with quote
Good point, and I think that is one of the reasons trains use diesel electric engines.
extreme3d
PostPosted: 22:20 - 01 Aug 2006    Post subject: Reply with quote
A decent diesel electric can only produce around 30 - 40% of the power of an electric locomotive of the same weight. Thats why electric high speed passenger trains only have 1 motor car (and the other being a dummy). A Diesel electric needs 2, one at each end.
colin1
Captain Safety
PostPosted: 03:03 - 02 Aug 2006    Post subject: Reply with quote
id love to have a 'star twin' and run it on filtered chip oil
The last post was made 20 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 134.34 Kb
