| GearboxGeezer |
 GearboxGeezer World Chat Champion
| Itchy |
 Itchy Super Spammer
 Posted: 21:18 - 30 Jul 2006 Post subject: |
nitrus oxide? , whats that got to do with it , N02 is just a substitute for air , air being 5% o2 , Nox being about 20ish %, and surely a remote control car would not use that (and its not mixed directly in the fuel tank anyway), and there are issues with burining more 02 heat issues, its why bikes can't be set too lean.
2 smoke oil , maybe? ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| hazza |
 hazza World Chat Champion
| ram_doom |
 ram_doom World Chat Champion
| sickpup |
 sickpup Old Timer
| Jebus |
 Jebus Brolly Dolly
 Posted: 21:55 - 30 Jul 2006 Post subject: |
yeah, its nitro methonal you can bung a little little bit in your tank and will absorb all the water and it will really kill weeds as well. ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
| 2Smoke |
 2Smoke Crazy Courier
 Posted: 22:07 - 30 Jul 2006 Post subject: |
| hazza wrote: | yes it will makle it faster and it isnt nitrous oxide, its nitro methane....my dad used to have friend in the RAF, and he used to steal aircraft fuel for my dad to put in his old lambretta 200, it lasted a few days until it went bang....although it went like shite of a shovel.....i would imagine your mates moped will come to the same sorry end |
no, will it fuck. If its a/c fuel its either avtur (kerosene) or avgas (high octane petrol) neither will make an engine go like shite or blow it up.
Nitromethane is whats used in the car oils, and seeing as its 20% nitro, 20% castor oil and 60% of the other stuff I doubt it'll make it run better ____________________ Currently in the stable.. '89 TDR250, 86 NSR250 '79 350LC, '79 DT175MX, 82, Pasola, '98 R1, '95 Speed Triple.. all of them total sheds.. |
| beatnck |
 beatnck Could Be A Chat Bot
 Posted: 22:22 - 30 Jul 2006 Post subject: |
dont know what it would do in a bike, but my r/c car shifts...its bloody good de-greaser too, it'll shift anything  |
| beatnck |
 Posted: 22:26 - 30 Jul 2006 Post subject: |
| Type_Mo |
 Type_Mo World Chat Champion
| hazza |
| hazza |
| mrchips |
 mrchips World Chat Champion
 Posted: 23:27 - 30 Jul 2006 Post subject: |
The nitro used to run RC cars is basically aircraft fuel. It will give you a considerable boost in performace as it runs much higher octane (not exactly sure how much) than your standard petrol pump. ____________________ Northern Irish? www.nibikers.com |
| T1z3R |
 T1z3R World Chat Champion
 Posted: 23:30 - 30 Jul 2006 Post subject: |
its not very econimical though...not sure what the average cost is but i've got 1 gallon here and it cost me £15  ____________________ duck my sick! |
| extreme3d |
 extreme3d World Chat Champion
| stinkwheel |
| Adam_P |
 Adam_P World Chat Champion
| stinkwheel |
| lilredmachine |
 lilredmachine World Chat Champion
 Posted: 13:58 - 31 Jul 2006 Post subject: |
Hence why a lot of Jap cars only accept 98 octane, they rely on pulling a lot of power out of a relatively small capacity at high compression ratio. The fact that most of the high end cars are turbo charged contributes to this. As stinkwheel said, whilst running higher octane fuel may not give a noticeable boost in performance, it does provide a widened avenue for tuning. Being able to run more boost in a turbo car without detonation for example.
Putting it in his scooter shouldn't really make a difference, depending on the mixture of nitromethane compared to conventional petrol.
Car nitro fuel is of different composition to aircraft nitro fuel though, an aero 2 stroke may only produce 1.0 hp at 15,000 RPM and never see over 12,000 RPM anyway, as well as seeing much use at a particular throttle setting. A car nitro motor could be producing up to 2.0 hp from the same capacity and have a rev range from 3,000 RPM to 35,000 RPM, being totally constantly varied. As such car fuel may only have 3-5% caster oil in it, out of a total 12-18% oil. The higher quality fuels also contain anti-wear agents, anti-foaming agents, lubrication additives, and rust and corrosion inhibitors, so his scooter should be nice and clean inside depending on what he has used.  ____________________ Bikes: too many, too much for one man to maintain anyway. |
| extreme3d |
 Posted: 20:27 - 31 Jul 2006 Post subject: |
| lilredmachine wrote: | Car nitro fuel is of different composition to aircraft nitro fuel though, an aero 2 stroke may only produce 1.0 hp at 15,000 RPM and never see over 12,000 RPM anyway, as well as seeing much use at a particular throttle setting. A car nitro motor could be producing up to 2.0 hp from the same capacity and have a rev range from 3,000 RPM to 35,000 RPM, being totally constantly varied. As such car fuel may only have 3-5% caster oil in it, out of a total 12-18% oil. The higher quality fuels also contain anti-wear agents, anti-foaming agents, lubrication additives, and rust and corrosion inhibitors, so his scooter should be nice and clean inside depending on what he has used.  |
Be careful in your use of the word aircraft above. Aircraft covers any 'craft' that flies including helicopters. There is a good deal of prejudice between model heli pilots and aeroplane pilots and those who fly helis wouldn't want to be assoiciated with them!!
So use the word Aeroplane there in future , as model heli fuels are just as advanced as model car fuels. Being caged in a geared plastic/carbon fibre frame like a car they require a good deal more from their fuel than any simple, basic, old 1950's thinking plank flier would require from his engine sticking up in the breeze just having to spin a plastic propeller!
A model helicopter engine is required to run at a constant rpm with more power being supplied to the rotorblades when high blade pitches are required - without actually increasing the speed of the engine and hence that rotor disk - quite a feat to accomplish. Torque as you can imagine is immense and what is sought after.
(Contrary to popular belief the rotor disk stays at a constant rpm and to go up/down blade pitch is changed)
| Itchy |
 Itchy Super Spammer
 Posted: 20:32 - 31 Jul 2006 Post subject: |
thats strange my dad always regales me with tales about 6 star petrol which he says you could buy at the pump which was supposedly kerosine,
my dad however is not particularly reliable as a source of information and never honours bets . ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Jebus |
 Jebus Brolly Dolly
 Posted: 20:46 - 31 Jul 2006 Post subject: |
menthol is meant to be werid stuff, gets called "liquid intercooler" no need for cooling with it ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
| lilredmachine |
| extreme3d |
| 2Smoke |
The last post was made 20 years, 55 days ago. Instead of replying here, would creating a new thread be more useful? |
