| Louise |
 Louise World Chat Champion
| Johnny GSX-R |
 Johnny GSX-R World Chat Champion
| firefox |
 firefox World Chat Champion
| Louise |
| Cillit-BANG |
 Cillit-BANG World Chat Champion
 Posted: 18:17 - 31 Jul 2006 Post subject: |
If it's a rattle can job then make sure you keep petrol away from it, especially in this good sunlight we've been having. Would hate to see your good work to to waste  |
| Louise |
 Posted: 18:20 - 31 Jul 2006 Post subject: |
Yup I will do. Just a few panels to go.
The way I see it, if it dose go wrong its not a lot of money thats gone to waste and a lesson to be lernt  |
| craigs23 |
 craigs23 Mr Muscle
 Posted: 18:28 - 31 Jul 2006 Post subject: |
Looks like it still needs a bit of finishing. Good base coats though. I'd either rub down with wet'n'dry (12 or 1500 as already mentioned), or get the rubbing compound out. It'll come up like a blue mirror once the paint's deep enough.
| Jack_Cheese |
 Jack_Cheese World Chat Champion
 Posted: 18:36 - 31 Jul 2006 Post subject: |
lacquer is needed first, that is an unlacquered finish, unless you've done a cack job
Jack ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!" |
| Louise |
| daz|n00by |
 daz|n00by The Internet
 Posted: 23:04 - 31 Jul 2006 Post subject: |
what they are trying to tell you is the finish you have know is unprotected and may have a slight orange peel effect to the surface, what they want you to do is rub the blue down lightly so as not to remove all the paint but to take the shine completly off it and remove any defects that you have in the paint finish, then you will need to get a clearcoat(also known as cklear laquer).
you then need to spray your dulled down surface leaving to dry between coats and giving a light smooth down before applying the nex coat of clear.
then when you have finished maybe 3 /4 coats you need to leave it to harden then cut back the finish with a T Cut or smooth rubbing compound before buffing with a wax polish.
or you could just spray t with clear coat and leave it at that and enjoy what you have done an take a bit of pride for having a go. ____________________ "Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class.  |
| Stu_666 |
 Stu_666 Brolly Dolly
| Jack_Cheese |
 Posted: 23:10 - 31 Jul 2006 Post subject: |
Have you used lacquer on it? ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
| Louise |
| Johnny GSX-R |
 Posted: 00:45 - 01 Aug 2006 Post subject: |
Iys not orange peel as dazlnooby says, yours is dry finish, caused by applying the paint from too great a distance at too fast a rate..
Stand the can of laquer in a warm place, maybe in a plastic bag inside a bowl of luke warm water to liven up the accelerants in the tin.
Practice practice practice to get the smooth finish, it can be done with rattlers but its harder than using a Devilbis gun
If you lightly flat the surface prior to the next coat then it will help prevent uneven build up.
Do NOT let it dry between coats as you had been advised!!!
Let it go go tacky, its called 'Flash off' this procedure allows the chemicals inthe fresh coat time to disperse and evaporate prior to the new coat, if the last one dries b4 the new one then it won't bond the same.
Its an art, i've been doing it for many years, cellulose is by far the best for a novice. 2k is the best for instant results but its more harmfull to use however you can get an aerosol made up at an auto re-finishers such as 'colour tone'.
I use synthetic base metallics / pearls and then a 2k hardened laquer for a swimming pool deep shine.
Louise, stick to Halfords tins but give it heavier coats of clear laquer with a warmer tin to boost the nozzle pressure slightly. |
| ZRX61 |
 ZRX61 Victor Meldrew
| Jack_Cheese |
 Posted: 17:59 - 01 Aug 2006 Post subject: |
Shouldn't you paint on a 6-800 grit finish as the paint won't stick to anything smoother? The advice i had was to not sand metallic colours on the topcoat. Then just flat and buff the lacquer when that's been applied.
| Jammy-R6 |
 Jammy-R6 Scooby Slapper
| ZRX61 |
| Johnny GSX-R |
| Louise |
 Posted: 12:07 - 02 Aug 2006 Post subject: |
Ill be off to grab some more today and have another go.
Was pretty ill yesterday so bewarned there is a bugg going around.
The bathroom was my best friend for most of tuesday day!  |
| Johnny GSX-R |
| Louise |
 Posted: 14:56 - 02 Aug 2006 Post subject: |
This is the top part done. Its alot shinyer now. Pic dosnt show the goodness of the peice  |
The last post was made 20 years, 60 days ago. Instead of replying here, would creating a new thread be more useful? |
