indicators are being strange??
skelly
PostPosted: 01:09 - 01 Aug 2006    Post subject: indicators are being strange?? Reply with quote
i have recently bought an rx50. when i start the engine and put an indicators on it flashes. but when i put on the brakes it stops flashing and stays amber untill i release the brake. can anybody give me ideas or know what it is about ?
thanks karl
k.skelly....aprilia RX50 (stolen) Sad | fzr 400 1988. Razz restricted Sad | Bandit 600 | Gsxr 750 SRAD, 1999.
Biker Boy
PostPosted: 01:12 - 01 Aug 2006    Post subject: Reply with quote
sounds to me like either dodgy wiring, or just a loose connection. I've seen cars on the road with that similar problem. When they break their indicators do funny things and vice versa. Sorry that's not much help but all I can think of is the wiring. If you know what you're doing with electrics look in the manual at the wiring diagram usually in the back. Might help, if not take it to the trusty garage Very Happy
"but like any bike it will comfortably see off anything on four wheels at the traffic light GP"
My Ninja Video!
Rubix
PostPosted: 01:15 - 01 Aug 2006    Post subject: Reply with quote
Its your 'indicator flash relay switch' .
Could be a few things , either the cables are
not earthed properly , or your may need a new switch.
Its ok , they are pretty cheap. Thumbs Up
Zxr250R import / 2001 CR125 / YZF R6 2007 work done.
https://www.youtube.com/watch?v=25rNTRHH6mI
https://www.youtube.com/watch?v=dYnOSzqolig
rizlabob This post is not being displayed because the poster is banned. Unhide this post / all posts.
finpos
PostPosted: 05:33 - 01 Aug 2006    Post subject: Reply with quote
None of the above. Your battery is probably knackered. Have a go charging it, if it fixes it, great. If it starts acting funny again within a couple of hours, replace the battery.
finpos.
skelly
PostPosted: 10:54 - 01 Aug 2006    Post subject: Reply with quote
[/quote]
ive charged the battery and the problem just keeps occuring. ill try to get a new one and see what happens.
thanks
doggone
PostPosted: 11:05 - 01 Aug 2006    Post subject: Reply with quote
Bad earth is strong possibility.
NSR Mick
PostPosted: 11:20 - 01 Aug 2006    Post subject: Reply with quote
Another vote for a bad earth.
Dark
PostPosted: 11:56 - 01 Aug 2006    Post subject: Reply with quote
I've seen this before and it was a bad earth
My Bikes in order:- Yamaha RXS100 / Suzuki X7 250 / Yamaha RD350LC / Kawasaki
KR1S 250 / Kawasaki ZXR750 H2 / Honda C50 / Kawasaki ZX7R P5 / Kawasaki ZX10R / Suzuki GSXR 400 / Honda CBR1100 Blackbird & Yamaha FZR 600
skelly
PostPosted: 12:03 - 01 Aug 2006    Post subject: Reply with quote
i have found something else out, when the engine is running and i give it some revs the indicators flashes again ? i am getting really confused. im going to try my friends battery to se what happens.
Dark
PostPosted: 12:05 - 01 Aug 2006    Post subject: Reply with quote
Can i change my mind and say battery now? Razz
MRX Steve
PostPosted: 12:31 - 01 Aug 2006    Post subject: Reply with quote
My indicators some time lock up and stay on amber when I am stationary with idling revs, have to rev it a bit to get them to flash again. ( I don’t have a battery on my bike)
Rieju MRX 50 Castrol Edition
lee125
PostPosted: 13:16 - 01 Aug 2006    Post subject: Reply with quote
i have the same problem on my nsr when i have my lights on low sometimes the indicator will just stick and not flash but if i turn the lights off it starts flashing and also fixes the problem when i rev the bike a bit could this be the same (bad earth) as i have checked my battery and its got a good charge? cheers Thumbs Up
cbt passed Smile 01/07/2006 bike:92 dt 125 and 96 honda cr 250
theory:PASSED! A2 test:PASSED 08/11/2006 restricted to 33bhp for 2 years
NSR Mick
PostPosted: 13:20 - 01 Aug 2006    Post subject: Reply with quote
No you cant. Laughing
It might be the battery
Jack_Cheese
PostPosted: 13:21 - 01 Aug 2006    Post subject: Reply with quote
rizlabob wrote:
as rubix said solunds like a bad earth. check all the points where your harness bolts to the frame.
Got my vote!
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
Dark
PostPosted: 13:29 - 01 Aug 2006    Post subject: Reply with quote
In that case, it has to be a spark plug issue, i suggest a nice new iridium plug as a replacement Laughing
fuzz
PostPosted: 16:52 - 01 Aug 2006    Post subject: Reply with quote
Check the indicator bulbs power rating. I had the exact same problem with my NSR. It was caused by the charging circuits not being strong enough to cope with head/brake lights aswell as indicators if they are rated too high. I had 21w bulbs in mine, they should have been 10w. I found that I could vary the rate of flash by varying the revs when stopped at lights, or keep them constant by turning off the headlight. Sound familiar?
skelly
PostPosted: 22:36 - 01 Aug 2006    Post subject: Reply with quote
Sound familiar?[/quote]
yes it does, i can change the rate of indication with the revs. ill try the bulbs
thanks karl
finpos
PostPosted: 02:48 - 02 Aug 2006    Post subject: Reply with quote
Yeek.
Everyone missed the important clue there: if it was a bad earth, the indicators would go OFF and stay off when the brake light came on. Also, you'd get the brake light flashing with the indicators. The fact that the indicators would work normally otherwise also suggests not fundamental wiring or component problems.
Indicators working ok with revs confirms it's a weak battery. If the battery itself is ok, then the charging circuit may not be doing it's job. Which could indeed be caused by pimping your bulbs. However, going on balance of probablilities: it's the battery.
Charging the battery is all well and good. But if it's knackered, it won't hold its charge very long and you'll very quickly be back to where you started. Only solution is to have your battery tested by somebody who knows how and has the tools (No, poundstretcher multimeter does not do the job) or to substitute it for one that you know works. Once you have eliminated the battery as a problem, then you can start looking at other things.
finpos.
Dragonfly
PostPosted: 10:44 - 02 Aug 2006    Post subject: Reply with quote
very helpful this thread as had the same problem with my indicators for ages. i just trashed the bikes on the back roads and they fixed themselves. connections probably. but will know next time from reading this. my horn is the same it works only after the back roads.
All the breast.
Muzza on Binge:
finpos
PostPosted: 11:19 - 02 Aug 2006    Post subject: Reply with quote
<shoots self through head in despair> Neutral
IT'S YOUR BATTERY. IT IS DEAD/DYING. BUY NEW ONE!
<sulks off>
finpos.
fuzz
PostPosted: 11:47 - 02 Aug 2006    Post subject: Reply with quote
<sulks off>
finpos.
It certainly wasn't my battery when the exact same thing happenned to me....see above.
If he bought it recently, the person who owned it before could have put aftermarket indicators on. Just make sure you know what rating the bulbs should be as standard, otherwise there's no way to check if this is causing the problem.
The last post was made 20 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 116.96 Kb
