Plumbing help (taps)
primalcarl
PostPosted: 18:23 - 03 Aug 2006    Post subject: Plumbing help (taps) Reply with quote
Does anyone know what the brass coloured units are that are in taps (like when you replace a washer, you take this unit out)
I need to know what to ask for when I buy some tomorrow, current ones have disintegrated
Smile
Ant
PostPosted: 18:47 - 03 Aug 2006    Post subject: Reply with quote
i'd call it the tap body, just ask for the inside brass bit ( i do if i dont know the name) either that or take it with you!
04 ZX10R ~
primalcarl
PostPosted: 20:22 - 03 Aug 2006    Post subject: Reply with quote
Thanks, found out they're called tap valves
it really is that quick
PostPosted: 21:45 - 03 Aug 2006    Post subject: Reply with quote
adapter taps, tap restorers or tap revivers all the same thing goto plumbers merchants as you'll pay a fortune at B & Q and the like
most will be universal in that they 'll fit basin taps (1/2") as is and you use the bushes provided to fit bath taps (3/4")
rob
not just any short of winnah... But a Sahf East Winnah
i dont look like your average hortifuckingculturist
primalcarl
PostPosted: 22:18 - 03 Aug 2006    Post subject: Reply with quote
Nice one, tap revivers seems the most common result on google so I'll ask for that
Teaman
PostPosted: 21:01 - 05 Aug 2006    Post subject: Reply with quote
the little brass things in side taps that chaves might use as wedding rings are oddly called olives
unless there very posh taps you may aswell buy new taps,
or a washer with a smaller hole Smile
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
primalcarl
PostPosted: 23:10 - 05 Aug 2006    Post subject: Reply with quote
Got replacements no problem. Wouldn't have been worth replacing the whole taps, and would have been an absolute nightmare to fit as there's little chance of getting underneath the sink.
I'm all too familiar with olives, from hydraulic braking systems. Often used in plumbing connectors and fittings
daz|n00by
The Internet
PostPosted: 23:51 - 05 Aug 2006    Post subject: Reply with quote
May i politely suggest you either do a bit of research on plumbing or bette still don't give answers to questions that you really have no idea about.
A olive is the ring used in inside a compression fitting to form a water tight seal, once it is used it cannot be reused or replaced with out replacing a piece of copper as well,it is either made of copper or brass.
And just for education purposes The part inside the tap which the OP was asking about is called a valve as was mentioned to him,
Taps come in 2 sizes..... wash basin and sink size is 15mm(1/2inch)
Bath comes in 22mmm(3/4) these are connected to the water supply via either plastic(shit) flexi(good) or copper pipe(the best)
they are joined by a swivel coupler this is were your Olive comes into play, they can can also by joined by a Yorkshire fitting(pre soldered) or a end feed(self solder).
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
Teaman
PostPosted: 10:52 - 06 Aug 2006    Post subject: Reply with quote
yeah I know, I didnt know the part he was on about and as he said the copper bit inside the tap I assumed that he ment the compression fitting at the base, I do have an Idea of what Im on about so get off your high and mighty horse, theres no need for insults, My dad was a plumber so its not like I havnt learnt anything and after spending a fair few years in the building trade
nothing worse that a fuckin train spotter Thumbs Down
Ant
PostPosted: 11:45 - 06 Aug 2006    Post subject: Reply with quote
You can get olive removing tools to save the copper Razz
04 ZX10R ~
daz|n00by
The Internet
PostPosted: 12:44 - 06 Aug 2006    Post subject: Reply with quote
But the copper wll be compressed were the olive was removed making it nogood for a new olive.
Now whos on his high horse?
that was not meant as a knock down and was not meant to insult your vast and mighty knowledge of plumbing.
things change fast in the building trade and a lot may have changed since your dad or you was a plumber.
But in future i will not bother to give people advise and subjects i know about and will leave it to the brains like yourself.
After all i,m sure your "few years" has taught you a lot more about the building trade than my measly 24 years, i bow down to a true expert.
Teaman
PostPosted: 15:50 - 06 Aug 2006    Post subject: Reply with quote
I bow down to your sarcasm, I believe we both touched a nerve
I respect your views as Ive read lots of your posts and have no reason not to respect you, This is just a dissagreement in my eyes,
You must also realise that when people say "my I politely suggest" it usually implys the "I'm right Your wrong full stop" hence the train spotter remark.(bit like the "now I don't believe you wanna do that, you wanna do it this way) (also usually gets a jolly good slap from the person hearing it up here) (not saying i'd be doing that to you Confused )
personally I'm big enough to appologise if I offended you
I offered my help, It was entirely his choice to accept the help,
I don't have a high horse, I try and be open minded and open speaking,
I know things have changed since my dads plumbing days but the basics havn't you have to admit the little copper things are called olives like I said, I just got confused with the part of the tap, simple mistake. If I'm wrong Ill appologise but the trouble with forums is that text can easlyly be missread, theres a slight lack of tone of voice.
Stu,, (Buys daz a virtual pint) Thumbs Up
daz|n00by
The Internet
PostPosted: 16:07 - 06 Aug 2006    Post subject: Reply with quote
Tis ok Tman not a problem from me really,
i was hot and sweaty when i replyed to your post this morning and it may have been a bit OTT, cleaning the car is hot work when the sun is blazing down on you from 7.30 this morning.
Everythings ok and i accept your pint and raise you 2.
lozzypop1
Certified MILF!
PostPosted: 22:15 - 06 Aug 2006    Post subject: Reply with quote
Rolling Eyes Male bonding!!! Rolling Eyes
daz|n00by
The Internet
PostPosted: 22:18 - 06 Aug 2006    Post subject: Reply with quote
Male bonding!!!
I would do some female bonding but they keep saying no Sad
lozzypop1
Certified MILF!
PostPosted: 22:20 - 06 Aug 2006    Post subject: Reply with quote
Want to bond? Wink
queen of string
PostPosted: 22:44 - 06 Aug 2006    Post subject: Reply with quote
group hug ?
"Eat food, not edible, food-like items. Mostly plants."
Flip
PostPosted: 22:46 - 06 Aug 2006    Post subject: Reply with quote
loz2k6 wrote:
Want to bond? Wink
Tart. Razz
lozzypop1
Certified MILF!
PostPosted: 22:53 - 06 Aug 2006    Post subject: Reply with quote
Yeah I Know Wink Laughing Thumbs Up
daz|n00by
The Internet
PostPosted: 23:01 - 06 Aug 2006    Post subject: Reply with quote
loz2k6 wrote:
Want to bond? Wink
Depends if your version of bonding is the same as mine?
Razz Twisted Evil
plugger147
PostPosted: 23:30 - 06 Aug 2006    Post subject: Reply with quote
I doubt it daz your proberly thinking of painting pva on the wall. Laughing
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
daz|n00by
The Internet
PostPosted: 00:36 - 07 Aug 2006    Post subject: Reply with quote
I really had to rate that as funny because i couldnt find the TWAT rating Wink
lozzypop1
Certified MILF!
PostPosted: 19:22 - 07 Aug 2006    Post subject: Reply with quote
Kinky!!! Wink
Ant
PostPosted: 19:25 - 07 Aug 2006    Post subject: Reply with quote
Surprisingly not mate, try one, you'll be impressed! i've used mine for that many rad valve changes and never had a leak (yet)
04 ZX10R ~
The last post was made 20 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 129.85 Kb
