| ram_doom |
 ram_doom World Chat Champion
 Posted: 15:03 - 04 Aug 2006 Post subject: Can cylinder block metal be welded in situ? |
Havent had my CBR600fk long, and the other day decided to change the oil and filter etc. Whilst doing this I noticed that on the right side of the engine (when viewed from a seated position), where the stud goes into the block, the metal had broken away with the stud screwed into it
Hmm, its sealing up alright with one stud holding that downpipe in, but its bugging me. Can it be welded without dismantling the engine, or removing it from the bike? I dont want to replace the cylinder head  ____________________ TL1000s, KDX200 |
| Gradog |
 Gradog Nitrous Nuisance
| Paddy Blake |
 Posted: 17:16 - 04 Aug 2006 Post subject: Cbr600fk |
I`m not sure where you are talking about but i have a head of a
hornet if that is the same.  |
| Jubal |
 Jubal Borekit Bruiser
| ram_doom |
 Posted: 18:19 - 04 Aug 2006 Post subject: |
Thanks for advice, I've been a bit concerned about it, but your right, if it isnt causing problems, then its best left alone for now
I'll try and get a pic to show what I mean.
Paddy, I think the motor from the hornet is pretty much the same as the mid 90's CBR6, but mine will be too old (1989). Thanks anyway  ____________________ TL1000s, KDX200 |
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 10:38 - 05 Aug 2006 Post subject: |
This happened to me when I tried to remove the headers my exhaust headers. The nut was unsrewing then to my amazement the stud also started coming out as the nut had seized tight .
The nut and stud seemed to screw in nice and tight, so if its not blowing then leave it alone.
It just goes to prove that the old girls dont like being touched too much  ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| cheekythomas |
 cheekythomas Crazy Courier
| Jubal |
 Posted: 23:33 - 06 Aug 2006 Post subject: |
 Posted: 00:05 - 07 Aug 2006 Post subject: |
Which is 260C.
I reckon an exhaust stud gets hotter, a lot hotter. Header pipes can glow red which happens at about 600C. The header is connected to the studs using steel collets which would readily transmit heat. |
| GearboxGeezer |
 GearboxGeezer World Chat Champion
| edd |
 edd Nearly there...
| Jubal |
 Posted: 01:44 - 07 Aug 2006 Post subject: |
| stinkwheel wrote: |
Which is 260C.
Possibly, but most of the heat is conducted down the pipe, whereas the head has water galleries passing around the exhaust tracts. So who knows what the real temperature is in this area? |
| flame220 |
 flame220 Banned
 Posted: 23:23 - 07 Aug 2006 Post subject: JB Weld & Araldite ! |
The great motorcycling bodges.
You could get the lug welded in situ if you can find someone willing to MIG alloy (make sure you disconnect the battery first though, I would unplug the igniter, regularor / rectifier & any ECU's before they start though), it could then be ground to shape / drilled & tapped.
Good as new  ____________________ What a bunch of cunts on BCF |
| Big Pete |
 Big Pete Spanner Monkey
| ram_doom |
 Posted: 19:18 - 08 Aug 2006 Post subject: |
Some fantastic advice in here, thanks a lot everyone who posted will give everybody karma when I get some. I'm going to leave it be until I have major engine work done. I'm going to print this page for when the time comes  ____________________ TL1000s, KDX200 |
| Jebus |
 Jebus Brolly Dolly
 Posted: 19:23 - 08 Aug 2006 Post subject: |
Hiya, i am a sorta welder, only at college at the moment but i go with GearboxGeezer on this one, you would have to take the engine out or at least strip a lot of the bike away and spend a lot of time degreaseing and cleaning all around the bike, all the electrics would have to be removed and and thing that wont like heat needs to be out of the way. It would have to be tig welded and even then you will need a good welder to do it ally is horriable stuff to weld. Another option you have is to have it brazed on that should be ok reguards to the heat, and far less risk of damage to the engine.
Not sure if this a sutiable solution but it worth a go.
I may of missed the point but cant you drill it out rethread and fit a slighty bigger stud? ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
| sickpup |
 sickpup Old Timer
| flame220 |
 flame220 Banned
 Posted: 21:25 - 08 Aug 2006 Post subject: |
The surface of the ally needs to be ground back to virgin metal before attempting to build it up because ally oxidises almost immediately it comes into contact with air.
I would be prepared to have a go at MIG'ing it ... come to that I have gas welded ally in the dim & distant past ( am I really that old? ) ____________________ What a bunch of cunts on BCF |
The last post was made 20 years, 46 days ago. Instead of replying here, would creating a new thread be more useful? |
