Can cylinder block metal be welded in situ?
ram_doom
PostPosted: 15:03 - 04 Aug 2006    Post subject: Can cylinder block metal be welded in situ? Reply with quote
Havent had my CBR600fk long, and the other day decided to change the oil and filter etc. Whilst doing this I noticed that on the right side of the engine (when viewed from a seated position), where the stud goes into the block, the metal had broken away with the stud screwed into it Shocked Laughing
Hmm, its sealing up alright with one stud holding that downpipe in, but its bugging me. Can it be welded without dismantling the engine, or removing it from the bike? I dont want to replace the cylinder head Confused
TL1000s, KDX200
Gradog
PostPosted: 17:02 - 04 Aug 2006    Post subject: Reply with quote
To be honest if it is not blowing I would leave well alone. Trying to weld cast alloy is a pain at any time. The fact that the stud is out means that you would not get any strength out of it without re tapping, and that you would struggle to do in situ.
Keep an eye out for a 2nd hand head going cheap on ebay and hold on to it just in case.
Grey haired bikers don't get that way from pure luck. Only a biker knows why a dog sticks his head out of the car window.
Paddy Blake
PostPosted: 17:16 - 04 Aug 2006    Post subject: Cbr600fk Reply with quote
I`m not sure where you are talking about but i have a head of a
hornet if that is the same. Idea
Jubal
PostPosted: 17:58 - 04 Aug 2006    Post subject: Reply with quote
Sounds to risky to me, way too much heat involved with plenty of things around that could be damaged.
You could clean it up well with degreaser and repair the damage with some JB weld, after painting if you do a good job you won't see the repair and it will hold the stud sufficiently to be used.
ram_doom
PostPosted: 18:19 - 04 Aug 2006    Post subject: Reply with quote
Thanks for advice, I've been a bit concerned about it, but your right, if it isnt causing problems, then its best left alone for now Laughing
Karma I'll try and get a pic to show what I mean.
Paddy, I think the motor from the hornet is pretty much the same as the mid 90's CBR6, but mine will be too old (1989). Thanks anyway Thumbs Up
TL1000s, KDX200
Whosthedaddy
PostPosted: 10:38 - 05 Aug 2006    Post subject: Reply with quote
This happened to me when I tried to remove the headers my exhaust headers. The nut was unsrewing then to my amazement the stud also started coming out as the nut had seized tight Crying or Very sad .
The nut and stud seemed to screw in nice and tight, so if its not blowing then leave it alone.
It just goes to prove that the old girls dont like being touched too much Laughing
cheekythomas
PostPosted: 22:18 - 06 Aug 2006    Post subject: Reply with quote
It is possible to do it in-situ if careful, they also need to be very good with a TIG set as like has been said, the alloy melts very fast indeed!
The option of JB weld is good, especially on something that age.
PostPosted: 22:23 - 06 Aug 2006    Post subject: Reply with quote
JB weld is amazing stuff but I wonder if the heat involved with an exhaust stud is asking a bit much of it.
Jubal
PostPosted: 23:33 - 06 Aug 2006    Post subject: Reply with quote
500f according to their web site-
https://jbweld.net/products/jbweld.php
PostPosted: 00:05 - 07 Aug 2006    Post subject: Reply with quote
Which is 260C.
I reckon an exhaust stud gets hotter, a lot hotter. Header pipes can glow red which happens at about 600C. The header is connected to the studs using steel collets which would readily transmit heat.
GearboxGeezer
PostPosted: 00:24 - 07 Aug 2006    Post subject: Reply with quote
As a welder ( not very experienced but ive done it for 2 years ) its not really a good idea to weld engine parts whilst still on the bike.. Petrol fumes, oil traces, and all the fancy plastic work is a hazzard for a pretty dangerous situation.
If it ant causeing anything bad to go wrong, then id leave it.
edd
PostPosted: 01:17 - 07 Aug 2006    Post subject: Reply with quote
JB weld definitely melts on exhaust studs, i stripped a thread on one a while back and tried to secure it with JB weld, it melted with 30 seconds of the bike being fired up.
Bluespark Automotive - Diesel Tuning for Performance and Economy
Jubal
PostPosted: 01:44 - 07 Aug 2006    Post subject: Reply with quote
Which is 260C.
Possibly, but most of the heat is conducted down the pipe, whereas the head has water galleries passing around the exhaust tracts. So who knows what the real temperature is in this area?
flame220 This post is not being displayed because the poster is banned. Unhide this post / all posts.
Big Pete
PostPosted: 19:06 - 08 Aug 2006    Post subject: Reply with quote
the lug will need to be TIG welded, MIG will just blow it away. the high silicon content in casting alloys makes them run like water when they melt, which is great for casting but tricky to weld. The lump will need to be drained and the pipes removed, along with the stud. Weld up a blob then drill and retap.
Trust me, I`m an engineer
GarageOfPower.co.uk
ram_doom
PostPosted: 19:18 - 08 Aug 2006    Post subject: Reply with quote
Some fantastic advice in here, thanks a lot everyone who posted Thumbs Up Surprised will give everybody karma when I get some. I'm going to leave it be until I have major engine work done. I'm going to print this page for when the time comes Karma
TL1000s, KDX200
Jebus
PostPosted: 19:23 - 08 Aug 2006    Post subject: Reply with quote
Hiya, i am a sorta welder, only at college at the moment but i go with GearboxGeezer on this one, you would have to take the engine out or at least strip a lot of the bike away and spend a lot of time degreaseing and cleaning all around the bike, all the electrics would have to be removed and and thing that wont like heat needs to be out of the way. It would have to be tig welded and even then you will need a good welder to do it ally is horriable stuff to weld. Another option you have is to have it brazed on that should be ok reguards to the heat, and far less risk of damage to the engine.
Not sure if this a sutiable solution but it worth a go.
I may of missed the point but cant you drill it out rethread and fit a slighty bigger stud?
2nd time around Smile CBT: 8/9/11
125 Varadero
sickpup
Old Timer
PostPosted: 21:05 - 08 Aug 2006    Post subject: Reply with quote
As the man says really. I have done this repair on a B12 lump.
The last post was made 20 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 102.77 Kb
