Richening the mixture
Dylan
PostPosted: 19:37 - 16 Apr 2002    Post subject: Richening the mixture Reply with quote
Is there any way to richen the mixture without changeing the jet??? (or is it easiest to change the clip position).
Thanks
Dylan
PostPosted: 20:31 - 16 Apr 2002    Post subject: Reply with quote
Changing the main jet affects the mixture for about the last 1/4 of the throttle opening. The needle (and swapping the it mounts on) affects (or is that effects, never sure, oh well) the 1/4 to 3/4 throttle range. The mixture screw affects the first 1/4 of throttle opening. There is a bit of overlap of course.
Lots of different needles are available to tailor the mixture more carefully.
Dylan
PostPosted: 20:41 - 16 Apr 2002    Post subject: Reply with quote
OK then...... I was just thinking that as it wont redline in top then maybe a bit of extra juice in the last 1/4 turn may help... Need to change the main jet then??
Thanks
Dylan
PostPosted: 13:07 - 17 Apr 2002    Post subject: Reply with quote
Yes, for that last bit of throttle you need to change the main jet. They are fairly cheap. The Dellorto importers are:-
https://www.racecar.co.uk/dellorto/
Give them a ring. For about £10 they also sell a pair of books on carbs which are useful. One is colour and cover the basics of carbs, but is in Italian English, the other is just the sheets explaining the various carb sizes (such as the exact dimensions of all the different carb needles that are available).
I doubt that increasing the main jet size will help you rev out more. If it is running that lean it would have a serious risk of having seized, and most bike makers (for 2 strokes at least) tend to jet slightly rich for safeties sake.
The last post was made 24 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 39.84 Kb
