| G |
 G The Voice of Reason
| finpos |
 finpos World Chat Champion
 Posted: 11:31 - 05 Aug 2006 Post subject: |
Backfiring is more likely to be caused by an electrical misfire - have a closer look at that horribly exposed from ht lead / cap / plug before you go tearing the carb to bits
finpos. |
| G |
 Posted: 11:35 - 05 Aug 2006 Post subject: |
Already torn the carb to bits .
Well, the front one at least, which looked clean and in ok condition.
Did seem quite a bit of petrol in it, one of the reasons I wondered about the float height.
Someone who had a similar problem had a problem with the low tension lead for the coil, so will check that, the HT lead seems to be ok. |
| the grim reaper |
 the grim reaper World Chat Champion
| finpos |
| G |
| mr.z |
 mr.z World Chat Champion
 Posted: 15:37 - 07 Aug 2006 Post subject: |
I'd have thought an air leak (both these wont take 3 minutes so worth a try to elminate them, may be wrong)
on a cold engine (have an extinguisher standing by just in case) try spraying a little easystart/wd40 arround the inlet rubbers, if the revs rise at any point theres your leak..
also when its warmed, put a rag over the end of the exhaust, if it stops your exhaust is leak free, i had a previous bike pop and fart on occasions when there was a leaky exhaust on it (even crush washers worth a try).
Maybe valve adjustments?
Good luck fixing it, i hate niggley stuff thats difficult to pin down like this.. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 17:02 - 07 Aug 2006 Post subject: |
I'd run a compression test, this will show up a valve problem.
I was also going to suggest an air leak on the inlet side (as mentioned above) between carb and head.
Does it ever miss on tickover?
You might just find that your carbs need a bit of a clean, more so the pilot jet(s). Main jets are not really used until higher up the rev range (further than you'd expect). ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| G |
 Posted: 17:04 - 07 Aug 2006 Post subject: |
Thought I mentioned, but seems not - had a look in the carbs and all looked pretty clean.
Don't have a compression tester, though an excuse to get one .
It misfires on tickover a bit as well. |
| Barry_M2 |
 Posted: 17:12 - 07 Aug 2006 Post subject: |
When you say 'looked clean', did you remove any jets and check?
What I'd do is, get a can of carb cleaner, drain petrol, remove carbs, take off float bowls, remove jets, spray through the jets, and spray into every single hole and crevis you can see in the carb. Also remove the float and be carefully not to loose the float needle and check that too.
It could also be an electrical problem, but if it dissapears after a certain rpm, I'm not so sure, I'd expect it to be consistant.
| bish777 |
 bish777 World Chat Champion
| the grim reaper |
 Posted: 14:12 - 08 Aug 2006 Post subject: |
If you know about the front piston problem, I take it you have re-routed the petrol cap drain hose as well? If not, the hose can become kinked round the tank hinge and then collects water when it rains, eventually the tube fills up and then you get water sitting round the petrol cap, when you open the cap, water gets into the tank.
If it's not this, I would also check the carb mounting rubbers, SVs can push their carbs off over time, exoecially if they backfire a lot (due to the front cylinder problem - DOH).
Cheers and good luck.
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
| G |
| Barry_M2 |
| G |
| mr.z |
 Posted: 15:32 - 08 Aug 2006 Post subject: |
| FreshAL |
 FreshAL Sir Crashalot
 Posted: 15:51 - 08 Aug 2006 Post subject: |
| the grim reaper wrote: | If you know about the front piston problem, I take it you have re-routed the petrol cap drain hose as well? If not, the hose can become kinked round the tank hinge and then collects water when it rains, eventually the tube fills up and then you get water sitting round the petrol cap, when you open the cap, water gets into the tank.
Grim |
Yup, that happened to my old one.
Took 3 garage vists to figure that one out.
Drained the tank and carbs, unkinked the hose and was fine after that. Well, till it got wrecked anyway |
| G |
The last post was made 20 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
