Help! Bike electrical problem!
Scorpius
PostPosted: 00:35 - 31 Jul 2006    Post subject: Help! Bike electrical problem! Reply with quote
OK was on a rideout to Wales yesterday, had been doing a lot of motorway/A road riding when suddenly the bike starts losing power and I notice the tacho drops to 0 which was wrong cos the engine was still turning! I stopped the bike, and turned the engine off. Turned the bike on again but didnt fire up the engine and there was a weird buzzing noise coming from the front of the bike. The Speedo immmediately went up on its own. We could also smell a burning smell coming from the front of the bike (might have been from the fusebox). Now at this point the engine wouldnt start not even the starter. Dashboard lights still worked however. AA man arrived (got roadside cover) but the battery had gone flat. WHen he connected the bike directly it fired up however the bike couldnt start on its own and he didnt really seem to understand the situation. I've now had to leave the bike on the welsh border Evil or Very Mad Does anyone have any idea what these weird symptoms might be from?
Cagiva Mito 125 (sold)
Honda CBR400RR NC23 (sold)
Currently riding: Honda CBR600F
PostPosted: 00:45 - 31 Jul 2006    Post subject: Reply with quote
Now at this point the engine wouldnt start not even the starter. Dashboard lights still worked however. AA man arrived (got roadside cover) but the battery had gone flat. When he connected the bike directly it fired up however the bike couldnt start on its own
Well, that bit sounds like it stopped charging the battery. Being a modern Honda, the most likely thing is a fried reg/rec.
Low voltage could cause problems with the instruments.
A burning smell however implies a short circuit, which you would want to find before going any further as you wouldn't want your bike to catch fire. Inspect the wiring for any signs of melting. Check the fuesbox (wires shouldn't melt, the fuse should blow first, that's why they are there).
krebsy
PostPosted: 12:52 - 31 Jul 2006    Post subject: Reply with quote
Had exactly the same symptoms on an old feista of mine. Was the engine management chip that had fried and it too knocked out the rev counter and speedo like that...
K.
1280 x 1024.
GSXFire
PostPosted: 13:25 - 31 Jul 2006    Post subject: Reply with quote
I had a Virago years ago that did the same thing, though at first i had run out of fuel, then noticed the burning smell and found it had boiled the battery dry due to a shot regulator, fitted new regulator filled the battery with tap water and away it went first try.
Check battery level, get it running and check battery voltage, it shouldn't be above 15volts, if it is it's over charging and you need a new regulator.
Fire by name Firefighter by nature.
My old bikes. https://www.bikepics.com/members/firefighter1/
Sephiroth
PostPosted: 13:46 - 31 Jul 2006    Post subject: Reply with quote
I have sort of the same problem, but no one knows what it is Confused
finpos
PostPosted: 03:18 - 01 Aug 2006    Post subject: Reply with quote
Yes, Smelling/Buzzing hints to a short, that must be attended to first.
Other problems may then just go away on their own, if you are lucky.
finpos.
Scorpius
PostPosted: 02:54 - 05 Aug 2006    Post subject: Reply with quote
Thanks for the responses guys. Thumbs Up I've finally got the bike back home tonight so will give the electricals a full checkover tomorrow and update you on the situation.
Scorpius
PostPosted: 10:31 - 10 Aug 2006    Post subject: Reply with quote
OK sorted out the main problem simply changed the reg/rec and the battery. Now using one of those aftermarket Japanese reg/recs with the fins on em. So most is ok HOWEVER..... Now my dipped beam and rear light arent working!!!! My full beam works fine and my brake light comes on when I hit the brakes too just no dipped beam or rear light when u turn the lights on. The AA man when I initially broke down was fiddling about with some of the wiring at the front of the bike so hope he didnt pull anything.
> Checked the fuses, doesnt appear to be a fuse
> Wouldnt have thought it was a bulb either since the rear light isnt working either unless they both went together. Confused
BTW its a CBR600F ('95)
GSXFire
PostPosted: 10:57 - 10 Aug 2006    Post subject: Reply with quote
It could be both bulbs, if the regulator was gone and your lights were on, it's the dip beam and tail light that take most of the power, sometimes every other bulb that gets switched on blows aswell, could be about 17v going through them, easy job to take them out and check, not such a big bill to fix compared with the regulator.
Scorpius
PostPosted: 11:13 - 10 Aug 2006    Post subject: Reply with quote
OK mate cheers, I'll check em first anyway and go from there.
The last post was made 20 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 66.72 Kb
