M.O.T Failure: Steering Movement 'notchy'
blamchez
PostPosted: 18:35 - 10 Aug 2006    Post subject: M.O.T Failure: Steering Movement 'notchy' Reply with quote
hi all
Im after some advise if possible on my NSR125 which has just failed its M.O.T.
Reason for failure:
1. Steering movement excessively 'notchy' with the weight on the lower bearing[2.2.1a]
the same garage has quoted epprox £130 - £150 to change the steering bearings stating that it could take up to two hours labour + £35 for the replacement bearings.
Is this a fair quote? could i attempt the job myself? or should i hand it over to the pros?
your thoughts please Thumbs Up
50cc honda ---> CG125 ---> 125cc jap scooter ---> NSR125 ---> NC30 ---> CB500 ---> ZX7R
Whosthedaddy
PostPosted: 18:46 - 10 Aug 2006    Post subject: Reply with quote
Easy job to do, just a time consuming to remove various parts just to get to the steering bearings
Gradog
PostPosted: 18:52 - 10 Aug 2006    Post subject: Reply with quote
It should be relatively easy. do it yourself.
Grey haired bikers don't get that way from pure luck. Only a biker knows why a dog sticks his head out of the car window.
Whosthedaddy
PostPosted: 18:57 - 10 Aug 2006    Post subject: Reply with quote
The only 'tool' that you may need to complete the job is a wrench that looks somthing like this one:
https://www.mgcycle.com/SteeringHeadToolSS.JPG
PostPosted: 19:00 - 10 Aug 2006    Post subject: Reply with quote
And a drift. No use fannying about with an old screwdriver or bolt to drive the old races out. An angle grinder is handy to get the bottom race off the stem.
It's a bit of a pain in the arse of a job, not complex but time consuming and frustrating at times.
The price seems about right.
Whosthedaddy
PostPosted: 19:02 - 10 Aug 2006    Post subject: Reply with quote
When I removed my steering head on the FZR it virtually fell apart in my hands, sod getting an angle grinder out Shocked
blamchez
PostPosted: 19:11 - 10 Aug 2006    Post subject: Reply with quote
rightiho, ill give it a go.
any tips or guides that i can access on the net?
what is that tool called?
PostPosted: 19:14 - 10 Aug 2006    Post subject: Reply with quote
It's a C-spanner. They are made of pure unobtanium if my attempts to buy one to adjust my shock are anything to go by.
Whosthedaddy
PostPosted: 19:16 - 10 Aug 2006    Post subject: Reply with quote
I was fortunate to have one in my dads old tool box.
It was slightly adjustable like this one:
https://cgi.ebay.co.uk/Large-BRITOOL-C-Spanner_W0QQitemZ140013947326QQihZ004QQcategoryZ31347QQrdZ1QQcmdZViewItem
Arrow WD40
Arrow Socket set
Arrow Closed end spanners
Arrow Hammer
Thats about it really.
https://www.nsr125.com/schem19t.jpg
https://www.nsr125.com/schem20t.jpg
They, along with others can be found at https://www.nsr125.com/schem.htm
PostPosted: 20:31 - 10 Aug 2006    Post subject: Reply with quote
Bit of a pig of a job, just due to the amount of rubbish hanging off them normally (unfaired bikes tend to be worse, with the clocks / headlights / wiring having off them). Getting the old ones out can be a nightmare, but think the NSR is OK for this (think there are small cutouts under the bearing to enable you to get a punch under the bearing race).
And make sure you put them in the right way up. Yes, I really have seen a lower steering head bearing in the wrong way round, which explained why adjusting them was useless.
blamchez
PostPosted: 23:50 - 10 Aug 2006    Post subject: Reply with quote
thanks to you all for your speedy replies filled with great advise.
i have ordered the bearings...
https://shop.wemoto.com/pictures.dyn?u=/pictures/bearings/taper2.jpg&i=1913532&a=25618
i have downloaded the shematics...
and im looking for a c spanner as i type.
will keep you updated with any progress!
cheers Thumbs Up
bish777
PostPosted: 04:16 - 11 Aug 2006    Post subject: Reply with quote
a great way to install the new races into the steering head involves a long threaded M12 rod, two very large washers and two M12 nuts.
Gather the parts and it becomes obvious Wink
GSXR1100J
The last post was made 20 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 76.68 Kb
