NSR 125R service
Blunet600
PostPosted: 23:20 - 10 Aug 2006    Post subject: NSR 125R service Reply with quote
Ok, my bike is due a service now (actually 200 miles ago.lol) but i just do not have enough money for a full service. What are peoples opinions on full services, and delaying its service date. I am currently about 200 miles or more over its recommended Service, and it will probabely be another 500 or so before it actually gets one because i dont have the money at the moment.
What damage am i doing by doing this? what are other peoples views who also own an NSR on the matter? Cheers
alains
PostPosted: 23:40 - 10 Aug 2006    Post subject: Reply with quote
except the first service (for your garantee) you can DIY all services and maintain your bike yourself . lube your chain at least once a week , check chain tension once a month , check your pads once a month , change gearbox oil every 3000 miles , change forks oil every 5000 miles or 2 years . clean air filter foam twice a year , carb every 2 years . watch time to time your sparkplug , clean & adjust gap (except irridium plugs) , change it if necessary .
the join doc will show what to do if you want to repect honda's schedule
Blunet600
PostPosted: 17:03 - 11 Aug 2006    Post subject: Reply with quote
isnt this for just a basic service? What does a full service look at?
or is this wat a full service is? becasuse i thought the full service would check the piston, etc?
alains
PostPosted: 18:01 - 11 Aug 2006    Post subject: Reply with quote
they never check the piston , all the services related on this picture are basics and can be DIY . the things that you cannot DIY if you dont know mechanic are :
- de-carbonization (with piston or rings or barrel change)
- oil forks change
everything else is easy , even it's sometimes bowring
Blunet600
PostPosted: 01:07 - 12 Aug 2006    Post subject: Reply with quote
whats de-carbonisation? very curious now.
alains
PostPosted: 10:24 - 12 Aug 2006    Post subject: Reply with quote
a part of oil is burn in the barrel & head and a more or less thick (depense on the time running) deposit occur , you loose performance on your bike with a temperature hotter . so honda recommand to clean this every 12000 kms (7500 miles) . as you must dismount your top-end , you replace as schedule :
- 7500 miles piston rings
- 15000 miles piston+rings
- 22500 miles top-end rebuild
Blunet600
PostPosted: 14:58 - 12 Aug 2006    Post subject: Reply with quote
yeh your right there is no way i could do that. But if i took it for a full service at the 7500 mark would they repleace the rings? or would i need to tell them?
alains
PostPosted: 22:04 - 12 Aug 2006    Post subject: Reply with quote
yes , tell them you want de-carbonizing , rings change with small end bearing , piston pin and clips . rings+ spares named and seals+gasket is about £60 plus 2 Hours works
The last post was made 20 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 55.85 Kb
