Exhaust baffle in, exhaust baffle out...and back in again.
byke95
PostPosted: 11:06 - 11 Aug 2006    Post subject: Exhaust baffle in, exhaust baffle out...and back in again. Reply with quote
I live in a block of flats and work in a hospital so during the commute to work I put my exhaust baffle in. When I finish work, and want to go for a ride, I quite often take the baffle out (like many, it gives me an inflated feeling of going fast, when I'm probably not). So, on any given day the baffle will be going in and and out quite a bit.
I'm aware I'll be gaining (?) and losing some BHP depending on if the baffle in or not but, by taking it in and out a lot, will it have any adverse affect on my engine?
Cheers,
Phil
Whosthedaddy
PostPosted: 11:08 - 11 Aug 2006    Post subject: Reply with quote
My understanding that the baffles are for sound deadening.
byke95
PostPosted: 11:20 - 11 Aug 2006    Post subject: Reply with quote
This would also be my understanding.
I'm wondering - as Akrapovic state that by taking my baffle out I gain a few more bhp (and therefore having some affect on the engine) - if by taking it in and out a lot there could be some sort of damage to the engine, in the long term?
Whosthedaddy
PostPosted: 11:35 - 11 Aug 2006    Post subject: Reply with quote
A sports exhaust just allows the combusted gases to exit the bike more efficenetly that the standard can, by removing the baffles you may make it a little bit easier for the gases to escape hence a few more bhp.
To be honest, I'd just leave it as one or the other. It seems a messy or pointless exercise to be removing and replacing the baffles. Long term damage to these may occur with the constant handling and refitting.
edd
PostPosted: 13:01 - 11 Aug 2006    Post subject: Reply with quote
By having a less restrictive exhuast system (baffle out) your bike will flow more air, making it run slightly leaner. If the bike is jetted for the can with the baffle out then putting it in will make it run on the rich side, no big problem really. The above presumes you have a carbed bike, (it does always help to say what bike you are talking about) If you have EFI then for a difference as small as baffle removal it should adjust itself. I doubt taking the baffle in and out would damage the engine, but baffles arent designed to be taken in and out that often so I'd be more concerned about physical damge like stripping the threads out of the baffle. If I were you I'd either ride with it out all the time, and just pootle along at low revs approaching your home and place of work, or put up with it being in place all the time.
Bluespark Automotive - Diesel Tuning for Performance and Economy
byke95
PostPosted: 15:11 - 11 Aug 2006    Post subject: Reply with quote
Good point, it's regarding a Z750...
Thanks for the help!Thumbs Up
The last post was made 20 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 49.86 Kb
