| Keir |
 Keir World Chat Champion
| T1z3R |
 T1z3R World Chat Champion
 Posted: 15:34 - 09 Aug 2006 Post subject: |
if it is the starter cover and the area's not subject to high internal compression then you can make your own gasket from carboard or similar.
i make a water pump gasket for my CRM from a weetabix box. never had problems with it since  ____________________ duck my sick! |
| Keir |
| T1z3R |
| Keir |
| Keir |
 Posted: 13:06 - 11 Aug 2006 Post subject: |
updated:
Its this....
https://img.photobucket.com/albums/v383/keir_compact/engine.jpg
Leaking from the bottom slightly so i need a new gasket as oil is slowly leaking out the bottom of my fairing. not good.
1) Whats the name for this part
2) where can i get a gasket for it? (net/mail order if poss as i dont have time to get to shops often)
3) how do i change it. is it just undo bolts, re-do bolts?
Thanks |
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 13:11 - 11 Aug 2006 Post subject: |
Is that the crank cover?
It shoud be a simple job of undoing the bolts (they may be as hard as nails to move), get covered in oil, replace the gasket and tighten bolts again.
Most dealers should have the part ready and waiting if its a new bike.
I managed without changing my gasket (its gonna bite me in the end I know), it was quite hard to explain what I wanted over the phone as all parts are ordered by its part number. Get the wrong number, get the wrong part and start all over again. ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| Keir |
 Posted: 13:19 - 11 Aug 2006 Post subject: |
yeah possibly.
ive found https://www.wemoto.com/ which does all parts mail order so when i find what it it for definate i can order it.
Anyone care to name that part for definate? |
| Whosthedaddy |
 Posted: 13:27 - 11 Aug 2006 Post subject: |
| Keir |
| Whosthedaddy |
 Posted: 15:08 - 11 Aug 2006 Post subject: |
Pass.
None of these have a centre peice missing either, unless its covered by the actual cover?
https://gsxrzone.com/enginecovers.html ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| Keir |
| Keir |
 Posted: 17:15 - 11 Aug 2006 Post subject: |
woohoo, its a starter clutch cover. There are 2 gaskets, an inner and an outer. both 7.45 each. both ordered from https://www.sparesdirect.co.uk who were very knowledgeable and specialise in suzuki. They even went through the fitting procedure etc.
Thanks for the responses whosthedaddy and T1z3R, i'll come back when ive messed up the fitting! |
| finpos |
 finpos World Chat Champion
| Keir |
| finpos |
| Whosthedaddy |
 Posted: 17:59 - 11 Aug 2006 Post subject: |
They are done up tight and took a bit to persistant pulling and pushing to loosen them. Just be nice and gentle when you remove the casing and things should nt fall or ping out.
I bought a set of keys for the hefty sum of £3.99 from Halfords and promptly bent them up You get what you pay for  ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| finpos |
 Posted: 18:01 - 11 Aug 2006 Post subject: |
sorry, I meant 4 quid for ONE key!
finpos. |
| Whosthedaddy |
| T1z3R |
 Posted: 04:11 - 12 Aug 2006 Post subject: |
doh!
just read the word "clutch"...assumed it was the starter motor cover  ____________________ duck my sick! |
The last post was made 20 years, 21 days ago. Instead of replying here, would creating a new thread be more useful? |
