Using a camcorder on track
mrtEE
PostPosted: 14:11 - 11 Aug 2006    Post subject: Using a camcorder on track Reply with quote
I'd like to use my mini dv camcorder attached to a bulletcam on the track.
However the bike is a 2001 cbr600f and the camcorder doesnt fit under the seat. If i was to obtain a small tail pack and put the dv camera in there, would most trackday organizers be happy for me to use it?
Any other suggestions for "concealing" the mini dv camera?
Bendy
Mrs Sensible
PostPosted: 14:12 - 11 Aug 2006    Post subject: Reply with quote
I wouldn't fancy your chances of many allowing it.
How big's your camcorder? Mine fits under the seat, just.
mrtEE
PostPosted: 14:23 - 11 Aug 2006    Post subject: Reply with quote
I havent actually tried to get the camera under the seat, but hers the dimensions:
Width 6.9 cm
Depth 14.3 cm
Height 9.4 cm
Weight 0.5 kg
how does that compare to your cameras size?
You dont think they will allow a small tailpack on track?
Bendy
Mrs Sensible
PostPosted: 14:27 - 11 Aug 2006    Post subject: Reply with quote
I never thought mine would fit until I actually tried it - give it a go. Shove it right up the back, where the taillight is. Mine's probably bigger than yours, certainly longer with the huge battery pack I've got.
They're not going to allow anything that could fall off, tailpack is definitely in that category.
mrtEE
PostPosted: 14:35 - 11 Aug 2006    Post subject: Reply with quote
cool, ill give it a try. what model of camcorder are you using BTW?
Bendy
Mrs Sensible
PostPosted: 14:52 - 11 Aug 2006    Post subject: Reply with quote
JVC GRD60.
Hotdog
PostPosted: 15:05 - 11 Aug 2006    Post subject: Reply with quote
Hi,
I recently bought an Oregon Scientific ATC-1000 Bulletcam.
https://www2.oregonscientific.com/shop/product.asp?cid=6&scid=14&pid=560
It's completely self contained and records directly to a SD memory card.
Ideal for trackdays and comes with lots of mounting options.
I'd recommend that you get one ASAP (and some decent NiMh batteries).
Hotdog.
He's a gentleman, a scholar, he's an-acrobat, he's the one and only truly original.......
Hotdog....(Defender of the weak, the poor and the innocent)
He's The Ace - He's Amazing...He's the Strongest... He's The Quickest.... He's The Best!
mrtEE
PostPosted: 15:07 - 11 Aug 2006    Post subject: Reply with quote
Hotdog wrote:
Hi,
Hotdog.
meh, sounds crap. Very Happy
PostPosted: 15:09 - 11 Aug 2006    Post subject: Reply with quote
Only does 15fps though, I thought?
From what I've seen I thought it was a bit jerky for decent trackday footage?
Hotdog
PostPosted: 15:49 - 11 Aug 2006    Post subject: Reply with quote
It's got 3 resolution settings and goes up to 20 fps on medium resolution.
I believe PAL standard is only 25 fps.
Hotdog.
Gazdaman
I did a trackday!!!
PostPosted: 16:37 - 11 Aug 2006    Post subject: Reply with quote
I was looking into those on eBay, but turned them down for the low fps rate.
Have you got any track footage from it?
Gaz
mrtEE
PostPosted: 17:28 - 11 Aug 2006    Post subject: Reply with quote
heres some footage from one which i recorded recently. thinking of selling my oregon camera to get a bullet cam as i already have a mini dv camera that i dont use much, jsut need to know if i can get away with using it on track or not.
https://www.badongo.com/vid/181031
Hotdog
PostPosted: 21:46 - 11 Aug 2006    Post subject: Reply with quote
Gaz
Hi,
I'm down to one bike at the moment, CCM R30.
I got the ATC-1000 about a week ago.
It's advantages are simplicity, all in one constructiion and supplied fitting kit.
Disadvantages are that it is very basic quality footage, ok for websites etc.
The only footage I've got is from nutting it through country lanes.
I use a RF Concepts Sony EXCCD bulletcam recording on either my canon minidv camcorder or straight to an Archos AV4100 for quality footage.
I've also got a sony Hi-8 camcorder (with oversize battery) on a tank mount for slapping on other people's bike or for rear facing usage (also a headstock camera mount that accepts any of my cameras).
If you want quality footage, spend the money.
If you want user friendly, cheap and cheerful, buy an ATC-1000.
I don't intend to use the ATC for high quality capture, which is lucky because it doesn't do it (it's very good at what I bought it for though).
Hotdog.
The last post was made 20 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 75.45 Kb
