Problem With NC30
Force_Vee_Four
PostPosted: 01:50 - 01 Jul 2006    Post subject: Problem With NC30 Reply with quote
I was riding my VFR and When I whacked the throttle, it promptly died and since then simply refused to start. I have no idea what the problem could be! Knackered CDI? or could it be something smaller? Please Help!
sickpup
Old Timer
PostPosted: 02:53 - 01 Jul 2006    Post subject: Reply with quote
Not really giving us much to go on are you.
Finglonga
PostPosted: 10:46 - 01 Jul 2006    Post subject: Reply with quote
Perhapt the throttles broke after you whacked it. Shocked
Andy Sez....
F.Y.Y.F.F.
Force_Vee_Four
PostPosted: 12:56 - 01 Jul 2006    Post subject: Reply with quote
Well I've taken out one of the spark plugs to see if its working. and there was no spark at all. and all the throttle cables are intact
Honda VFR 400R NC30 K-Model
Force_Vee_Four
PostPosted: 17:23 - 12 Aug 2006    Post subject: Reply with quote
I used a workshop manual and tested the whole electric system and ignition and there is no problem there. But there is still no spark. the coils, leads, plugs and all the fuses are okay.
mr jamez
PostPosted: 17:30 - 12 Aug 2006    Post subject: Reply with quote
List the components you have tested.
Scorpius
PostPosted: 17:35 - 12 Aug 2006    Post subject: Reply with quote
Remember you need petrol for your bike to move lol. Seriously though you'll need to give more info, how long were you riding for when it died? Did you try bumping it? What happens when you press the starter key? Does the engine turn over or is there no sound?
Cagiva Mito 125 (sold)
Honda CBR400RR NC23 (sold)
Currently riding: Honda CBR600F
finpos
PostPosted: 17:37 - 12 Aug 2006    Post subject: Reply with quote
No spark on all 4 plugs? suspect a problem in the low tension side of the electrics.
Have you looked at the various ignition kill circuits (kill switch, sidestand switch...)
finpos.
Force_Vee_Four
PostPosted: 17:39 - 12 Aug 2006    Post subject: Reply with quote
The motor turns over but there is no spark. I tested the Coils, spark plugs, plug leads, Pulse generator, even the neutral switch and it all works
Force_Vee_Four
PostPosted: 17:41 - 12 Aug 2006    Post subject: Reply with quote
all the switches work fine. I've checked them all aswell.
finpos
PostPosted: 18:04 - 12 Aug 2006    Post subject: Reply with quote
Right, rewind a bit:
Using a car battery with jump leads and a new plug, you get no spark on all 4?
You tested the switches, did you test the wiring connected to the switches?
finpos.
Force_Vee_Four
PostPosted: 19:18 - 12 Aug 2006    Post subject: Reply with quote
ive tested the whole electric system. the wires all of it. But there is no spark
Force_Vee_Four
PostPosted: 19:47 - 12 Aug 2006    Post subject: Reply with quote
Can anyone help?
finpos
PostPosted: 19:55 - 12 Aug 2006    Post subject: Reply with quote
I'm not wanting to be harsh here, but you've clearly missed something Smile.
How did you test the battery? With a multimeter?
finpos.
Force_Vee_Four
PostPosted: 20:03 - 12 Aug 2006    Post subject: Reply with quote
yes i did it with a multimeter and the battery is fully charged
finpos
PostPosted: 20:10 - 12 Aug 2006    Post subject: Reply with quote
Well, there's your first mistake right there. You can't test a battery under full load (as it is when the starter is running) with a multimeter. You've only tested it with little or no load which tells you diddly squat.
And it gets worse: Being fully charged means that the battery is holding as much charge as it's capabale of holding. If the battery is on it's last legs, that's not necessarily enough to actually start the bike.
So car battery, jump leads and a new plug. Tell us how you get on.
finpos.
The last post was made 20 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 83.19 Kb
