Suzuki Starting Problems
Lonieg3
PostPosted: 05:28 - 13 Aug 2006    Post subject: Suzuki Starting Problems Reply with quote
My cousin just sold me his 94 Suzuki gs500e. Its been sittin up for @ 2 years and Im having trouble getting it fired up. It only has Around 6000 miles on it so to me it fairly new right? I bought a new battery and plugs as well but it still wont turn over.When i turn it on I get all the lights as if all is good but when I push the stat button with the engine in the on position I get nothing.
suzi_bandit
PostPosted: 09:10 - 13 Aug 2006    Post subject: Reply with quote
I expect someone will be along shortly to point you in the right direction.
It's a process of elimination.
I had exactly the same problem with my bike. All the lights would come on but it wouldn't fire up. Fortunately for me the problem was simple and cheap to fix. I needed to replace a little saftey switch that allows the bike to start when the clutch is pulled in and it had become stiff with age. I did just put the wires together while I was waiting for the switch to arrive so that I could still use the bike.
Hopefully your problem is just as simple.
Good luck.
I want a big boys bike, preferably a Speed Triple. To date I have ?7:42p stashed away to put towards one. Need to get it in the bank & earning interest asap.
ram_doom
PostPosted: 10:02 - 13 Aug 2006    Post subject: Re: Suzuki Starting Problems Reply with quote
Killswitch? Wink Razz Kidding, try tugging on all the wiring Thumbs Up
TL1000s, KDX200
Ichy
PostPosted: 10:46 - 13 Aug 2006    Post subject: Reply with quote
Its a personal thing but before you do anything else I would take the spark plugs out and put a bit of oil in each cylinder. If its got one put the bike on the center stand, knock it into gear and just turn the back wheel slowly by hand. Like I said, its not something you have to do, I just like to know that the engine will turn without putting it under too much stress after sitting for a couple of years.
All kind of generic but should help to start tracking the problem.
Is there any sounds from the bike when you press the starter button? If you hear a click then the circuit is fine but the starter is knackered in some way.
Turn the headlight on and press the starter, does the headlight dim? Yes, then its possible theres a short in the starter circuit or the starter motor has failed. No, a broken wire or bad connection or a switch in the starter circuit isn't working.
All the fuses ok? Sometimes the starter will have its own seperate one.
Find a wiring diagram.
Test the starter button with a multimeter. Same for the kill switch, make sure both turn on and off.
Is the neutral light on? Try changing to first then back to neutral.
Try with the side stand up and down, test the continuity of the side stand switch, does it turn on off?
Try with clutch in and out? Test the continuity of the switch if fitted.
If all those pass ok then you need to check power is getting to the starter relay. If power is getting there but nothing is happening then the fault is either with the relay or the starter.
If you wanted to you could connect the live wire from the battery directly to the switched side of the starter relay (the wire that goes to the starter motor) just to check the starter will turn. MAKE SURE YOU HAVE THE RIGHT CONNECTIONS!!
Lonieg3
PostPosted: 18:53 - 13 Aug 2006    Post subject: Reply with quote
Thanx 4 the info iLL go to my bike and start checking off. do all bikes hgave a kill swith ? and where are my fuses located ?
Clanger
Stirrer
PostPosted: 18:57 - 13 Aug 2006    Post subject: Reply with quote
The GS does have a reputation for corrosion problems, so I would check all the wiring for corrosion or loose links.
Davo
Davo To The Rescue!
PostPosted: 19:30 - 13 Aug 2006    Post subject: Reply with quote
Have the kill switchs have been checked out?
Is the bike in neutral?
Also does the GS500 the same as other Suzuki's where you have to hold in the clutch lever when you press the starter button?
Whosthedaddy
PostPosted: 19:31 - 13 Aug 2006    Post subject: Re: Suzuki Starting Problems Reply with quote
Yes the kill switch Shifty Been caught out by that little fella a few times Embarassed Laughing
Method
PostPosted: 20:42 - 13 Aug 2006    Post subject: Re: Suzuki Starting Problems Reply with quote
Retard.
Just to answer a few questions:
No the GS5 does not have a clutch switch, it does have a sidestand switch though Laughing
Your fuses are located behind the right hand side tail panel, towards the tank end. Pop your seat and undo the bolt at the top (on the seat lock mechanism holder) and undo the screw holding the tail panel to the mid tail peice. Give it a tug, its off. Fuses are now easy to get to.
Is there a noise when you hit the starter motor? Do you hear a click and then nothing, do you head the bike turning over and it just doesnt fire?
Have you got petrol - if its been standing for years, the odds are it wont have been left with petrol in it, and if it has - its going to be useless.
Answer those questions and we will be able to help you further!
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
ZZR Girl
PostPosted: 21:08 - 13 Aug 2006    Post subject: Reply with quote
Are you trying to start it whilst the side stand is down? My GS500 had a cut out so that the engine would stop if you put the side stand down. It might be the same that if the side stand was down, it might not start? Just a thought.
Keep it shiny!
Pte1643
PostPosted: 00:58 - 14 Aug 2006    Post subject: Reply with quote
Surely the side stand switch only works if it's in gear. Wink
suzi_bandit
PostPosted: 08:49 - 14 Aug 2006    Post subject: Reply with quote
Not if the switch is faulty.
Lonieg3
PostPosted: 09:14 - 14 Aug 2006    Post subject: Follow up on my gs500 Reply with quote
cleaned battery terminals as well as battery cockpit. Did see some corrosion not much though. Ran into some fuses bue not the main fuse box yey I changed out the ones on yjr rt side next 2 the battery terminals. Placed gas in tank but did not mpy out fuel that wuz left in . Called myself checking the connections . still wouldnt turn over light did not dim when I pushed the starter button.Where are the kill swithched on the gs ???
ram_doom
PostPosted: 10:03 - 14 Aug 2006    Post subject: Re: Suzuki Starting Problems Reply with quote
Method wrote:
Retard.
That was a perfectly resonable and quick way of checking for dodgy connections you numpty Rolling Eyes
TL1000s, KDX200
Method
PostPosted: 10:03 - 14 Aug 2006    Post subject: Reply with quote
Killswitch is on the right hand bar, right at the top.
Its the red switch and it needs to be down at the bottom - thats the on position.
Also even if the sidestand switch is faulty, it will start in neutral Thumbs Up
Does the engine turn over? Do you hear a click when u press the button to start? what happens exactly
Ichy
PostPosted: 13:58 - 14 Aug 2006    Post subject: Re: Suzuki Starting Problems Reply with quote
There you go Method, it does nothing.
If your struggling to find the kill switch I can only suggest you get someone with a bit more knowledge. to take a look
Method
PostPosted: 16:05 - 14 Aug 2006    Post subject: Re: Suzuki Starting Problems Reply with quote
Yeah, especially if one is loose and earths on you...
Just wanted to make sure he means that he gets nothing at all, compared to just cranking over and "getting nothing" etc...
Definately sounds like a killswitch thing mate. The killswitch stops the engine from even turning over on a GS5, so would the sidestand - but if its in neutral then it doesnt matter.
TheDonUK
PostPosted: 17:41 - 14 Aug 2006    Post subject: Reply with quote
Another silly but maybe not obvious question, when you changed the spark plugs you did put the connectors back on the plugs.... i have ridden off on one cylender due to that one Embarassed
The last post was made 20 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 104.73 Kb
