Oil pump check, nsr125
ROB_NSR
PostPosted: 23:48 - 12 Aug 2006    Post subject: Oil pump check, nsr125 Reply with quote
How can I check to see if the oil pump on my '92 nsr125 is working properly? I've never had it running yet but judging by the state of the piston/rings that could have been the problem and I dont want it happening again!
Thanks
Rob
alains
PostPosted: 11:53 - 13 Aug 2006    Post subject: Reply with quote
first of all , open the pump cover . then turn your right handle at maximum . on the cable guide and on the pump body you see 2 notches , they must be on line . if not , where the cable get in , you have an adjuster , untighten the counter-nut then tighten or untighten the adjuster to put these notches on line , when ok tighten the counter-nut . the normal oil consumption is about 1L for 5-6 full tank (as your tank is 10 L) , so note how much miles you've done when you need to refill the oil bottle , if something wrong , change oil pump
ROB_NSR
PostPosted: 12:46 - 13 Aug 2006    Post subject: Reply with quote
Thanks for that, I'll have a look at it if it stops raining today!
Thanks
Rob
The last post was made 20 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 35.18 Kb
