my lc
Craig
PostPosted: 11:49 - 24 Jun 2003    Post subject: my lc Reply with quote
Can anyone give me advice on any way of improoving the cooling system on my 350lc fans etc as imusing my bike reg and doin long dist i dont want to fry it all suggestions app
TiN
Pocket Tin
PostPosted: 11:55 - 24 Jun 2003    Post subject: Reply with quote
Mate, it would be a easier to read your posts (and reduce your chances of getting ignored/flamed) if you typed all of your words fully....and using spaces...
So is your bike actually overheating at the moment? What kind of journeys do you make? If you get stuck in traffic often then your bike is bound to get warm...I often switch the ignition off if I expect to wait a while.
TiN
dotgems.net
Craig
PostPosted: 12:01 - 24 Jun 2003    Post subject: Reply with quote
to be fair i use it as my main transport and run around with bigger bikes although i don t struggle to keep up with them i do have to stop to cool down usual trips are matlock from stoke or blackpool i just wonderd if there was any modifications possible
JimboJ
Manc Pikey
PostPosted: 12:04 - 24 Jun 2003    Post subject: Reply with quote
The bike shouldnt overheat, check you have enough liquid in it and that the cooling fan is actually working etc.
[00:42] <NSR-Andy> which one's the missionary position
[00:42] <NSR-Andy> i've heard it's good
[9:42pm] <Shaun> you came first mike | <Shaun> yes gav, because I really want to fuck you
Craig
PostPosted: 12:07 - 24 Jun 2003    Post subject: Reply with quote
Thanks for that
TiN
Pocket Tin
Yeah, check your coolant level and mixture. The fan shouldn't kick in until a certain temperature anyway, but you can probably modify it to stay on all of the time (or make a switch etc).
TiN
dotgems.net
Craig
PostPosted: 12:22 - 24 Jun 2003    Post subject: Reply with quote
HOPEFULLY THAT WILL SORT IT OUT CHEERS FOR THE ADVICE I LL GO AND CHECK EVERYTHING
PostPosted: 13:49 - 24 Jun 2003    Post subject: Reply with quote
Don't think an LC should have cooling problems unless it has had a fair bit of tuning, and most bikes only have overheating problems at low speed.
The old LC didn't have any cooling fans, but if you do loads of round town miles one might help. However at high speed it probably wouldn't help as it would screw up the airflow through the radiator.
Is the bike standard or heavily tuned?
Might be worth flushing the radiator through and checking the water pump works.
Dr Nick
PostPosted: 13:53 - 24 Jun 2003    Post subject: Re: my lc Reply with quote
On my little suzuki katana moped. We put 2 computer fans just over the radiator. I suppose you could put them underneath to draw air through but hey it looks cool. And everyone asks what that little switch was for. I said it was for my advanced cooling system. The fans are about 10 quid each from any decent computer retailer. They're case fans and are bout 8 inches long but you can get them in different sizes.
is that it
Guest
PostPosted: 15:19 - 24 Jun 2003    Post subject: Re: my lc Reply with quote
But did it work?
andrew
Mister Road Rage
PostPosted: 15:26 - 24 Jun 2003    Post subject: Reply with quote
I cant imagine computer fans doing too much to help with overheating. Try something like a low voltage shower extraction fan?? I know you can get ones with flat motors that shouldnt take much room up at all. Failing that get yourself a new bike that doesnt overheat Very Happy
kev
I Hump Things
PostPosted: 19:23 - 24 Jun 2003    Post subject: Reply with quote
just take the thermostat out
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
Guest
PostPosted: 22:34 - 24 Jun 2003    Post subject: Reply with quote
Thanks for all the advice boys had a mess and it seems ok well we ll see on route to matlock sunday lol Very Happy
Dr Nick
PostPosted: 23:15 - 24 Jun 2003    Post subject: Re: my lc Reply with quote
Anonymous wrote:
But did it work?
Well i didn't really need it, it was just for show and G will probably call it tarting Razz . Though we put it on really proffesionally, with a couple of timing switches so you didn't leave it on all night and drained your battery. I've seen a few on Aprilia rsv's but i think there standard.
is that it
craigT19
Jolly Green Giant
PostPosted: 14:38 - 28 Jun 2003    Post subject: Reply with quote
oi only room for one craig in here mate lol
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
matlock marrauder
Guest
PostPosted: 20:33 - 03 Jul 2003    Post subject: my name Reply with quote
just for u i have changed my name lots of lov .......... lol
The last post was made 23 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 85.44 Kb
