 ..... Quote Me Happy
 Posted: 11:24 - 19 Aug 2006 Post subject: I'm getting old - I want one of these |
https://www.motorcycledaily.com/081806_top.jpg
https://www.motorcycledaily.com/081806_middle.jpg
Would really like one of these as a second bike - or as my main bike really and my Ninja as a weekend/track toy.
Taken from https://www.motorcycledaily.com
The R1200 GS has been a huge success for BMW, and the time was right to introduce the Adventure version in 2006. People seem desperate for a little adventure of their own after seeing 'the Long way Around' TV series that featured actors Ewan McGregor and Charley Boorman on BMW R 1150 GS Adventure bikes travelling the world. BMW sold something like 1,400 R1200 GS in the UK in 2005, following the media circus surrounding the GS in its various forms. So the UK was then chosen by BMW-Motorrad as the place to launch the new Adventure, featuring the 1200 Boxer engine. On the new 1200, everything got bigger and better, but at the same time lighter, compared to the 1150. When it comes to global endurance riding, the GS Adventure stands virtually unchallenged, and it remains the first choice for globetrotters on two wheels.
With a 33 litre fuel tank as the single most outstanding feature over any other bike, the Adventure has calculated a 465 mile (750km) cruising range! This capacity is three litres more than the old R1150 GS Adventure. The handling difference between a full fuel tank and an empty one is a bit like Dr. Jekyll and Mr. Hyde, as you have to get used to two different bikes basically. The Adventure's massive range is sort of like BMW's own challenge to owners - go ahead, try to find somewhere remote enough that you'll run out of fuel before you come across a gas station!
Compared to the standard GS, the Adventure is a big beast of a motorcycle, mainly due to the size of the fuel tank, and the taller seat height. It certainly does not present itself as the ideal enduro bike, and it isn't. Due to better ground clearance and knobby tires, it can handle much more varied terrain than the standard GS. But only the very brave or very stupid would try to follow a dedicated enduro bike on any kind of dirt path. Some capability is there, designed for emergency use in Mongolia or the forgotten regions of the former Soviet Union. It would work in the Middle East too - certainly better than a camel, although you'll have to rely on your own balance rather than your mount's!
A large windscreen is standard for all those freeway miles that are inevitable if you want to go anywhere from anywhere. When wearing an offroad helmet, the air seems to catch in exactly the wrong place, causing significant buffeting. If I had been a bit shorter, let's say like Ewan McGregor, I would have been fine, well tucked in behind the screen. I missed my full face helmet a lot, and raising the adjustable windscreen to its highest position didn't help much. If you do go offroad remember to put the windscreen down to its lowest position, as it is downright scary not being able to see the ground ahead of the front wheel through the screen.
The wheel travel is the maximum available from the Tele/Paralever system, but it is not as capable as the superb suspension on the HP2 Enduro. The tank, engine and valve protectors make sure you can deal with a couple of spills on rocky ground before you need to call AAA. With the seat adjusted to its highest position, mainly for offroad duties, but also for a panoramic view over the surrounding traffic on the road, I found myself sitting 36 inches (915mm) above the ground. That is almost as high as the 36.25 inches (920mm) on the HP2 Enduro. You can also adjust back down to 35.25 inches (895mm), by means of a simple tool-less operation under the seat. Stand up riding is really comfortable, and both the handlebar and foot brake lever are adjustable.
The hand guards protect your hands from rocks and the levers during a wipe out. As it happens, I managed to crash the Adventure, and apart from a broken Paralever, the bike would have been perfectly rideable after the crash. All levers and pedals were still intact even after the heavy impact with a stone wall. This is evidence of the rugged and solid construction, and in most scenarios (with normal riders, rather than a journalist, at the controls), the GS would be categorized as unbreakable.
The Adventure is not as manageable as the HP2 due to the sheer weight and size of the thing. The HP2 Enduro is a completely different kettle of fish, however - a much more exciting ride, with unlimited amounts of torque available at all times in a lightweight chassis. On the move, though, you only get a 70-80 mile range on the HP2 - whilst the Adventure keeps on going almost an additional 400 miles. So no competition really, but interesting, and I would recommend that anyone considering the Adventure have a go on the HP2 as well, to see how BMW also makes proper offroad bikes with the big Boxer engine.
Offroad, the R1200 GS Adventure is not so confidence inspiring, as you keep thinking about all that weight that can come down - crushing your legs, despite wearing offroad boots. Slow speed manoeuvres off the beaten track are awkward, and the Adventure works best on wider dirt fire roads, where you can keep speed and momentum going. It performs just as well on a well maintained gravel road. If you get bogged down in the mud on a tight trail, you might never get out on your own. So keep it real.
The ABS brakes work well on the tarmac, but you just can't get the same confidence on the road with knobbies. With the knobbies, everything feels a bit looser, and the rear wheel spins up too often when the massive torque grabs hold of the knobby rear tire. This can be controlled, and will allow you to make every tight bend entertaining, but at the expense of excessive rear tire wear.
The test bike was fitted with fog lights, and they do their job of providing extra light when the night is dark and the fog thick. The mirrors stay clear most of the time, despite the big thumping twin.
The R 1200 GS Adventure is not a motorcycle that suits everyone. For some it will just be physically oversized and awkward to live with. But considering its size and weight when fully fuelled up, it handles really well. If you want a 450 mile range for mammoth touring duties, there is nothing else on the market that can compete. For me, the biggest sales points would be the titanic fuel capacity and the rugged, macho looks. |
| Pte1643 |
 Pte1643 Nearly there...
 Posted: 11:26 - 19 Aug 2006 Post subject: |
Yep!
Sure sign your getting old.  |
| Luke_Retrofly |
 Luke_Retrofly Silly Lesbian
 Posted: 11:59 - 19 Aug 2006 Post subject: |
Hmm must be getting old too, because i have a secret love for the BMW adventure bikes
Luke ____________________ Flounced - Long overdue
Fuck you bitch I'm in the top 10 list I can do the what the fuck I want! |
| quacker_boy |
 quacker_boy Cuddle Bitch
 Posted: 12:46 - 19 Aug 2006 Post subject: |
Doesn't mean you're getting old Joe!
Wait...yeh it does, my old man had his when he was 50! It was the smaller brother though, the F650.
I did an Adventure motorcycling day out with BMW in Dubai and we were taugh how to really use for serious off roading..climbing the highest moutain, forwading every stream. Shit like that.
Stuipidly powerful bikes with great torque BUT they weight nothing short of a ton!  ____________________ wizzzard wrote: Imagine God just stopping by, tidying your front room up and then quietly letting himself out again. Statisticly more likely to happen than Korn being on here. |
| extreme3d |
 extreme3d World Chat Champion
 Posted: 13:05 - 19 Aug 2006 Post subject: |
You are only 'old' if you just ride it around the UK dressed like the long way around and look down on anyone else on a sportsbike.
If however you take it on serious rough terrain tours like the guy in the top pic, dress in your own bad arse styling and use forums like this https://www.advrider.com/forums/ then it's cool  |
| Finglonga |
 Finglonga World Chat Champion
| MRX Steve |
 MRX Steve Could Be A Chat Bot
 Posted: 13:44 - 19 Aug 2006 Post subject: |
I really like that adventure version, looks like a beast
Looks great fun for a bit of offroading too  ____________________ Rieju MRX 50 Castrol Edition |
| Nb |
 Nb World Chat Champion
I wouldnt mind a gs, but first id have to buy a small ladder to get on it.  ____________________ Cbr1100xx blackbird gone, mk4 golf gt tdi chav now
Columbus travel insurance are crap!! Do not use! |
| Cannon |
 Cannon Trackday Trickster
 Posted: 14:09 - 19 Aug 2006 Post subject: |
I don't like that, but I must admit I love the new r1200s sports bike  ____________________ Staffs Riders Forum |
| brooky |
 brooky Brolly Dolly
 Posted: 14:18 - 19 Aug 2006 Post subject: |
I dont think its got anything to be with getting old mate
, I would love to have a go on one. And after watching them on LWR they look like an awesome bit of kit.
I think I like them becuase they'd be great fun off road and thats how I started on a bike.
In a few years time maybe...  ____________________ Suzuki GSX-R 750 K6. |
| kawakid |
 kawakid World Chat Champion
| Fastgut |
 Fastgut Trackday Trickster
 Posted: 15:54 - 19 Aug 2006 Post subject: |
McGregor and Boorman have a lot to answer for  ____________________ Was a driving instructor now working in Insurance
Bikes:2005 Speed Triple and 2004 FZ6 Fazer (now the other half's) |
| TheShaggyDA |
 TheShaggyDA Repost Police
 Posted: 16:04 - 19 Aug 2006 Post subject: |
You're getting old when you look at one of these and think "Woo, that looks comfy! And all that storage space, too!"
https://www.phmotorcycles.co.uk/bikes/images/suzuki/Burgman-650-Executive.jpg ____________________ Current: CB500 Previous: CB100N, CB250RS, XJ900F, GT550, GPZ750R/1000RX, AJS M16, R100RT, Enfield Bullet
[i:6e3bfc7581]But still I fear and still I dare not laugh at the madman...[/i:6e3bfc7581] |
| Yoshi |
 Yoshi Traffic Copper
 Posted: 17:59 - 19 Aug 2006 Post subject: |
They're cool, but only if you use it for it's intended purpose - going round the world Love to do this one day, well I'm going to!  ____________________ Present: GS650 Katana - Getting ready for summer touring!
Past: TS50, RS50, ZXR400, LT80, TS250 |
| michael j |
 michael j World Chat Champion
 Posted: 18:13 - 19 Aug 2006 Post subject: |
I didn't realise that your last birthday was your 60th  ____________________ Ducati 996 |
| banzai |
 banzai Two Stroke Sniffer
 Posted: 19:05 - 19 Aug 2006 Post subject: |
you think its good of road ?, wait till you try it on road, i know it aint pretty but its an excelent road bike, sticks to the road like shit to a blanket and more fun than my 996.  |
| Pte1643 |
 Posted: 21:45 - 19 Aug 2006 Post subject: |
That seat looks like it'd be comfy for the old Piles.  |
| TheShaggyDA |
 Posted: 21:54 - 19 Aug 2006 Post subject: |
Indeedy. Me chalfs would love that nice, plush armchair  ____________________ Current: CB500 Previous: CB100N, CB250RS, XJ900F, GT550, GPZ750R/1000RX, AJS M16, R100RT, Enfield Bullet
| dodsi |
 dodsi Dirty Carny
| Jackyboy |
 Jackyboy Scooby Slapper
| Pte1643 |
 Posted: 23:44 - 19 Aug 2006 Post subject: |
No, but you do have to be seen IN a Rover 75.
I hired out a car last year, turned out to be a Rover 75 on the day (it wasn't what I asked for).
Proper "Old Gets" car. |
| dodsi |
 dodsi Dirty Carny
| bazza |
 bazza World Chat Champion
| colin1 |
 colin1 Captain Safety
 Posted: 06:06 - 20 Aug 2006 Post subject: |
ive got the original maxi scooter the yp250. bit smaller and cheaper than that one. They are excellent sensible, comfortable transport for in town and on motorways and quite nice for cruising along country roads too.
the bmw beast is basically a range rover.
I wdnt mind a go on one but I think they are too heavy for offroad. Im reminded of the bit in LWR where the swiss bloke realises his little 250 replacement is better offroad than the bmw he crashed. For onroad touring id think id probably prefer to have a pan european or blackbird or vfr800/vr750. ____________________ colin1 is officially faster than god |
| narb |
 narb Borekit Bruiser
The last post was made 20 years, 48 days ago. Instead of replying here, would creating a new thread be more useful? |
