Changing body jewellery.
MementoMori
PostPosted: 03:52 - 20 Aug 2006    Post subject: Changing body jewellery. Reply with quote
I currently have a piercing with a ball closure ring though I want to change this to a barbell as I plan on getting the surrounding area tattooed.
Is going from a curve to a straight thing going to hurt or aggrevate the piercing or do I need to get a curved barbell?
Cheers.
The tiger who came for a pint
bazza
PostPosted: 08:53 - 20 Aug 2006    Post subject: Reply with quote
Provided it's properly healed, you shouldn't have any problem.
Dazbo666
PostPosted: 09:37 - 20 Aug 2006    Post subject: Reply with quote
...and we're also interested in finding out where this "surrounding area" is ?? with pics?? Wink
Word of the day : DILLIGAF
Andy C
Tree Seeking Missile
PostPosted: 11:18 - 20 Aug 2006    Post subject: Reply with quote
it depends where it is. Ive changed my Anti-tragus from ring to bar and hurt big time and it started acting like it was newly pierced. Though my others have been fine when ive changed the rings
map
Mr Calendar
PostPosted: 11:20 - 20 Aug 2006    Post subject: Reply with quote
Should be ok. Make sure you go for the same size bar. When removing make sure lubricated. I'm sure you already know the Savlon spray is your friend for cleaning piercings Thumbs Up Very Happy.
byke95
PostPosted: 12:41 - 20 Aug 2006    Post subject: Reply with quote
As mentioned, if it site has healed (and is the sort of piercing that doesn't flair up for no reason) changing it over shouldn't be a problem, but those odds would be improved by going from a ring to curved barbell rather than from a ring to straight barbell. Is there any reason why you want to go to a straight bar?
If it's a nipple piercing, barbells are pretty well suited to them.
map wrote:
I'm sure you already know the Savlon spray is your friend for cleaning piercings .
Great stuff, but if it's a sensitive area then weak salted water is always another good option.
MementoMori
PostPosted: 18:40 - 21 Aug 2006    Post subject: Reply with quote
Thanks for the advice.
I think it'd look tidier with a straight bar, especially if I did get a small tattoo around it.
Also the ring can catch sometimes and can be unpleasant. Thumbs Down Neutral
I just thought a curved bar would be more suited to it as it's never had something straight in it before.
I dunno... probably don't know as much as I should about these things.
And yeh, that Savlon Spray is awesome.
Thanks again, I think I'll try it and hope for the best but it should be alright as it is healed and behaves.
MementoMori
PostPosted: 18:42 - 21 Aug 2006    Post subject: Reply with quote
One more thing, would the spray do that job?
Thanks.
map
Mr Calendar
PostPosted: 10:56 - 22 Aug 2006    Post subject: Reply with quote
MementoMori wrote:
map wrote:
...make sure lubricated.
...would the spray do that job?
FWIW it works for me.
I don't want to be introducing any foreign bodies or other stuff for infection so make sure I give a good clean first. That's both the old and the new.
HTH Thumbs Up
Whosthedaddy
PostPosted: 10:58 - 22 Aug 2006    Post subject: Reply with quote
I used to clean my tongue bar in my contact lens sodium peroxide solution for a while to get rid of any debirs that may have built up and then rinse well under the tap.
The last post was made 20 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 67.91 Kb
