| sagiliam |
 sagiliam Could Be A Chat Bot
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 09:45 - 21 Aug 2006 Post subject: |
6 volt electrics! Ouch!
If your rear brake light doesn't work it will fail. Indicators need to flash and be visable, or again, it will fail.
How you crimp your wires together is not an issue, as long as it works. But for the sake of a few pence for some connectors, i'd get it sorted. Or at least solder it and tape over if you must.
Just be honest with yourself, look over the bike and think, is it roadworthy!?.... Brakes, steering, suspension, exhaust, ELECTRICS. Take 15 mins and check it over, it will save you £30 odd quid for a re-test!  ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| sagiliam |
| Barry_M2 |
 Posted: 09:57 - 21 Aug 2006 Post subject: |
Sorry, yes, same applies for front brake.
Sounds like it will be fine.
With the exhaust, it need to be in good condition, no blowing, secure and with noise, should be no louder than a standard one. Althouh I think it all depends on the person testing it.
| doggone |
 doggone World Chat Champion
The things that catch you out are ususally less obvious like wheel bearings or steering head.
From your list of problems it's the front brake not triggering the brake light most likely to fail you.
You might just convince them that they were all like that from new
A 'friendly' back street bike shop might be more inclined to give a little leeway bearing in mind you aren't going to be thrashing up the motorway at 90mph. |
| sagiliam |
| garth |
 garth World Chat Champion
| stinkwheel |
 Posted: 10:23 - 21 Aug 2006 Post subject: |
As it was made in 1981, you only need to have the brake light coming on with the rear brake. BUT if there is a switch on the front brake lever, it must work.
If the flashers don't work convincingly enough, take them off or tape them up, again, on a 1981 moped, there is no requirement for flashers. Most places are aware that you need to rev these things up in order for the flashers to work.
Not familiar with an FR50, is it that one that looks like a Honda cub? If so, I bet they also copied the silly pressed steel frame. Have a good check up under the back mudguard where it meets the petrol tank for corrosion, this is a common MOT fail on the Hondas.
Tap round all the spokes on the wheels with a spanner. If any of them make a dull noise instead of a musical ping, it needs tightening. |
| Richard1987 |
 Richard1987 Scooby Slapper
 Posted: 10:58 - 21 Aug 2006 Post subject: |
Your lights and flashers should be fine, you can get brilliant lights from 6v and they will know that.
Mine just passed on its 2nd time as the headlight alignment wasnt set right and my rear brake light sticks on sometimes due to sloack front brake lever.
Some places are just picky. i knew the guy who would be testing the bike before it went in so i knew it would fail  ____________________ add me to your msn messenger contacts : rip307@msn.com |
| sagiliam |
| Marci |
 Marci Brolly Dolly
The last post was made 19 years, 135 days ago. Instead of replying here, would creating a new thread be more useful? |
