AAARGH HILL STARTS!!!! :@
carlmalibu
PostPosted: 20:06 - 21 Aug 2006    Post subject: AAARGH HILL STARTS!!!! :@ Reply with quote
I finally learnt how to corner today (counter steer lean etc.) and have been going far too fast but my damned little RS has trouble on steep hills Sad
Living in sheffield it's hard to avoid them but does anybody have any tips? the only way I could get up Hagg Hill (one of the steepest roads in the world ever!) was with a push from a friendly van driver, no matter how many revs I tried to give it and how fast/slow I let out the clutch I got nothing but crumbling at about 1.5k revs and being overtaken by irate car drivers.
HELP MeEEEEEE!
Shine on, you crazy diamond
CB500, woop.
Pte1643
PostPosted: 20:16 - 21 Aug 2006    Post subject: Re: AAARGH HILL STARTS!!!! :@ Reply with quote
You need a bigger engine. Wink
Sorry, couldn't resist. Thumbs Up
T1z3R
PostPosted: 20:17 - 21 Aug 2006    Post subject: Reply with quote
apply the rear brake, engage first gear then release the clutch until you get the bite point then give more throttle and slowly release the rear brake.
works for me and we've plenty of steep hills here in scotland.
duck my sick!
dave1rs
practice hill starts...its that simple,an rs will fly up any hill
bikerboy50cc
PostPosted: 20:20 - 21 Aug 2006    Post subject: Reply with quote
i only have a 50cc and there are a few steep roads near me i just keep it in a loew gear first or second that works for me and the way i think of it is you can go as fast or as slow as you want because you have payed your road tax.
https://50cc-bikes.aceboard.com/
Flip
PostPosted: 20:23 - 21 Aug 2006    Post subject: Reply with quote
Personally I'd engage 1st gear before applying the rear brake because you'll fall off. Laughing
Aikman666
Usually redline it while im taking off and compensate with kickass clutch control and rear brake Thumbs Up
Will work for petrol
My Design Blog
0ddball
PostPosted: 20:26 - 21 Aug 2006    Post subject: Reply with quote
Get one of the local ped boys to tow you up.
NSR-Rulez
Just give the bike more revs, as said above
(Assuming you are stopped)
Engage 1st gear
Hold on rear brake
Get the clutch to the biting point
Give the bike more than 1500 revs, you will want around 4-5000 revs
Then release the rear brake.
HTH
Pete
Past: 1985 Suzuki GS 125 + 2002 Honda NSR 125 R-2 + Ford Fusion
Present: Honda CBR 600 RR-5 + Suzuki SV650S-K4 + Mitsubishi FTO GPX
carlmalibu
PostPosted: 20:40 - 21 Aug 2006    Post subject: Reply with quote
the bike needs 5k revs just to start usually Wink What happens is I do the above, rev it high release the clutch and the revs just die. Can't understand what I'm doing wrong.
CB500, woop.
Rejimbo
PostPosted: 20:49 - 21 Aug 2006    Post subject: Reply with quote
your letting the clutch out too quickly, let the clutch out until the bike starts moving and the revs start dropping, then hold the clutch there and start accellerating. Then let the clutch out all the way.
It sounds like your revving, then more or less dumping the clutch so it jumps forward and the revs drop until the bike bogs down
carvell
Scuttler
PostPosted: 21:21 - 21 Aug 2006    Post subject: Reply with quote
You need to ride the clutch, letting it out very slowly, for a fair distance up the hill.
An RS will easily start on any hill, so it's not the bike.
Yamaha TDM 850
Jack_Cheese
PostPosted: 21:36 - 21 Aug 2006    Post subject: Reply with quote
Keep the revs up in the power band Thumbs Up It normally involves horrid noises on 2-strokes. The way back from rivvy has absolutely shit hills on the route, and it's just a matter of nailing the throttle.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
tony532
as written above ride the clutch more... on a very steep hill i used to give the rs about 8000 revs to get it moving.
bikes owned :-
aprilia rs125 - suzuki gsxr400rrsp 1990 - yamaha yzf600r thundercat - honda hornet 6
doggone
PostPosted: 23:48 - 21 Aug 2006    Post subject: Reply with quote
God that sounds scarey.
Simple balance of clutch at biting point and just enough revs is all it takes.
There is no "required " number to see on the noise-o-meter dial.
You just need some practice in a place away from traffic (unless the clutch or something else is about knackered!)
This is something that in time you will do without having to think about it - like putting one foot in front of the other to start walking.
T1z3R
PostPosted: 23:49 - 21 Aug 2006    Post subject: Reply with quote
not the way i do it mate Wink
duck my sick!
Dragonfly
PostPosted: 01:02 - 22 Aug 2006    Post subject: Reply with quote
You will get the hang of it, i had the same prob when i stared on a two stroke. " strokes do your head in on hills though. Just dont give up, know its frustrating. use your back break more so you dont roll down the hill and try not to fall off.
All the breast.
Muzza on Binge:
johnsilva
PostPosted: 13:19 - 23 Aug 2006    Post subject: Reply with quote
redline it,
release clutch
easy
Current Bikes: ZX7R P5; KR1S C2; GPX250R F3
Previously: CBR400RR-R; YQ50 Aerox
Vic
PostPosted: 13:30 - 23 Aug 2006    Post subject: Reply with quote
Practice, practice and practice. I was having a mare doing hill starts on my DAS but my instructor kept making me do em, over and over. Once i nailed it, that was it, no worries now. O, and start on smaller hills, then progress up Very Happy
paulthewitt
PostPosted: 18:26 - 23 Aug 2006    Post subject: Reply with quote
you should be able to pull away on a flat smoothly at about 2000 revs. not easy mind! but practice that. then go onto hills. on a very steep hill you may need to rev as high as 6k to pull away smoothly. but 5k for anything but near vertical should be more than enough.
sounds like you have poor clutch control. try practising letting it out progressively. you are allowed to slip the clutch...it is designed for this.
Paul
The last post was made 20 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 104.41 Kb
