polishing carburetors
befdelta7
PostPosted: 20:13 - 28 Aug 2006    Post subject: polishing carburetors Reply with quote
has anyone used a dremel or similar kind of sanding tool to polish the throat and slide of their carburetor? i mean really polishing it up making it as smooth as a mirror (getting rid of those really small divots in the throat) and looking like a mirror or a new shinny 50p peice, iv done it twice to 2 of my scooters i have owned (i own a cagiva super city 125 6-speed now) and i thought i could feel a difference in throttle response!
has anyone herd of this being done before with increases in performance? Thinking as im tempted to do it to my 34mm carb for my cagiva. Thinking
james
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
0ddball
PostPosted: 20:19 - 28 Aug 2006    Post subject: Reply with quote
Negligable gain, you'd get bigger gains from oiling your chain. Polishing downstream of the venturi can even lose power in theory.
xxxrated
PostPosted: 20:25 - 28 Aug 2006    Post subject: Reply with quote
air filter side you can make as shiny as you want, ive been told by an engineer not to go any higher than 400 grit really once the fuels added as it can possibly reduce drag as the fuel sticks to mirrored surfaces which will also possibly interfere with the atomisation.
gains will be minimal although theres no reason not to do it
Walloper
PostPosted: 23:30 - 29 Aug 2006    Post subject: Reply with quote
The air-fuel mixture entering a carburetted engine benefits from the turbulence created by the uneven surfaces of the inlet manifold.
It helps disperse atomised fuel evenly across the air stream which contributes to better combustion.
If you must whittle away at a manifold, do the inside of the exhaust.
But then you may even upset OEM designed airflow characterisics.
And 'Tuning' is always a balance of effort in to effort out.
Or go to the pub.
Ride your bike some where nice.
Chill Laughing Karma
The last post was made 20 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 40.01 Kb
