Meta M357tV2 key conversion version?
short1uk
PostPosted: 14:13 - 29 Aug 2006    Post subject: Meta M357tV2 key conversion version? Reply with quote
How do i convert the alarm fob to a key it says it possible.
Catherine
sickpup
Old Timer
PostPosted: 14:24 - 29 Aug 2006    Post subject: Reply with quote
Using the key conversion kit that comes with the alarm. It has full instructions as well.
short1uk
PostPosted: 15:52 - 29 Aug 2006    Post subject: Reply with quote
I have just had the alarm fitted on my new bike. It came with a small key fob and another key fob that can be converted into a key fob but that was all that came with it there was no conversion kit??
sickpup
Old Timer
PostPosted: 16:32 - 29 Aug 2006    Post subject: Reply with quote
Go talk to your dealer then.
Wooly R6
PostPosted: 18:02 - 29 Aug 2006    Post subject: Reply with quote
i asked my dealer last time i was there about this - but my key was not compatible, for a Yamaha R6 2003 anyway - has immobiliser chip in the key, and therefore cannot be done
R6 has been sold - 2004 Honda VFR VTEC now sold too - no bike at the moment
short1uk
PostPosted: 19:03 - 29 Aug 2006    Post subject: Reply with quote
The key fob can be converted but i am not sure how tbh. I think I need a spare key then get it cut then stick it in side the fob. Dont think I will bother now as its ok the way it is.
sickpup
Old Timer
PostPosted: 19:42 - 29 Aug 2006    Post subject: Reply with quote
In the alarm box you get a couple of extra alarm fob casings. You then cut up your key to fit inside, gut the original fog and put the innards in the new fob. Find the new fob falls apart when you twist it to turn the key so take it apart and superglue it together. Then the battery dies so you break the fob case, put the innards back in the original case if you still have it and your left with the stub of a key. Simple Wink
short1uk
PostPosted: 20:09 - 29 Aug 2006    Post subject: Reply with quote
hee
ok defo not arsing building an all in one key then!
oh and i found the make ur own key bits wondered wtf they where
cheers guys
MattEMulsion
PostPosted: 21:54 - 29 Aug 2006    Post subject: Reply with quote
You need to make sure that the key conversion will work okay with your ignition switch first. My bike, which is a 2003 R6 won't accept the key conversion. I don't want to dispute what Wooly R6 posted above, but because of the shape of the ignition switch on the R6, ie the key slot is recessed down inside the outer casing, the Meta key conversion won't work because the Meta casing is physically too chunky to fit down into the recess. Apart from that I understand that there is a slot inside the meta fob to put the immobiliser chip in from your original key, so that shouldn't be a problem.
Yamaha YZF-R6
BigChris
PostPosted: 22:21 - 29 Aug 2006    Post subject: Re: Meta M357tV2 key conversion version? Reply with quote
Catherine
DONT DO IT!
(it aint funny when you find the fucking thing falling to bits in yer hand and you cant get a good enough grip to turn the key out of the ignition) Thumbs Down
sickpup
Old Timer
PostPosted: 00:01 - 30 Aug 2006    Post subject: Reply with quote
Hold on chaps no ones said I'm being less than honest because I fit Datatools Shocked You all ill or something? Confused
MattEMulsion
PostPosted: 00:10 - 30 Aug 2006    Post subject: Reply with quote
Hey sickpup, do you get this sense of deja vou? Lets not go down the Meta vs Datatool road again! Rolling Eyes Very Happy
Yamaha YZF-R6
sickpup
Old Timer
PostPosted: 00:25 - 30 Aug 2006    Post subject: Reply with quote
I wasn't trying just amazed after the last thread that no one has tried to impugne my good character again.
Seriously am surprised. Cool
MattEMulsion
PostPosted: 00:33 - 30 Aug 2006    Post subject: Reply with quote
So then sickpup, do the Datatool's do key conversions as well as the Meta's? I'll let you into a little secret, one of my mates who has his Meta has also got the key conversion. I must admit that I wasn't too impressed with the key conversion on the Meta, the key never seemed very secure or tightly fitted in the Meta fob and didn't inspire confidence in it. On the other hand it was more convenient, ie you didn't have to have the extra alarm fob dangling on your keyring as well as your ignition key.
Yamaha YZF-R6
sickpup
Old Timer
PostPosted: 00:44 - 30 Aug 2006    Post subject: Reply with quote
I think it might be you trying to initiate dejá vu.
No datatool don't do a key conversion. The give you a nice quality lanyard to hang around your neck so the fob doesn't get damaged.
You shouldn't ever have the fob on your key ring as it may get damaged by vibration and small impacts.
firefox
PostPosted: 01:32 - 30 Aug 2006    Post subject: Reply with quote
sickup the new data tool system 4 comes with this sort of thing, i think you got to get the key cut though.
sickpup
Old Timer
PostPosted: 01:36 - 30 Aug 2006    Post subject: Reply with quote
I'll look and check. Thumbs Up
firefox
PostPosted: 01:52 - 30 Aug 2006    Post subject: Reply with quote
unless the ebay people are filling me full of fudge again Embarassed
PsychoHippy
Jammy Git
PostPosted: 04:10 - 30 Aug 2006    Post subject: Reply with quote
Is it just me that thinks having your alarm fob and key on the same key ring is a bad idea?
If someone swipes it, they have your bike with no problems - seperate key rings for each is the way to go!
I spend all my money on bikes and beer, the rest I simply waste!
BigChris
PostPosted: 22:14 - 30 Aug 2006    Post subject: Reply with quote
You're a liar, a cheat and a thief. Do I get my tenner now? Laughing
MattEMulsion
PostPosted: 00:47 - 31 Aug 2006    Post subject: Reply with quote
Personally I never seperate my alarm fob from my bike key, I always have visions of losing the alarm fob and being well and truely f**ked. I have heard stories before of people with their fob seperate to their key who have disarmed their alarm, started their bike and disappeared off out on a rideout without realising that they have left their alarm fob on the shelf in the garage etc. This problem then only becomes apparant when you need to disarm your alarm/immobilser 50 miles away from home, only to realise that you have forgotton your alarm fob. Shocked
Also whilst we are on the subject, I picked up a tip a few years back about a handy way to 'secure' your alarm fob whilst attached to your bike key to stop it from getting battered about. Basically you attach a small piece of velcro to the underside of the alarm fob and attach another small piece of velcro to the yoke of your bike adjacent to the ignition. Thus you can place your fob on the yoke securely whilst riding and it won't get knocked about. I also figure that they must be waterproof so I don't see too much of a problem. Just to illustrate it I have found you a picture of my yoke/ignition (the picture was actually taken to show the steering damper), with its bit of velcro stuck on.
https://i2.photobucket.com/albums/y29/mattemulsion/R6ohlins2.jpg
Yamaha YZF-R6
sickpup
Old Timer
PostPosted: 02:20 - 31 Aug 2006    Post subject: Reply with quote
Pssst. Thats why you program a Pin on a Datatool. Shocked
No your fob isn't water or vibration proof.
short1uk
PostPosted: 09:23 - 31 Aug 2006    Post subject: Reply with quote
thanks for the velcro tip dude!
And mine is water proof!
Mines been going on about a pin as well I think I need to read up on that bit just incase i lose the fob while out and about Thumbs Up
sickpup
Old Timer
PostPosted: 13:55 - 31 Aug 2006    Post subject: Reply with quote
I wouldn't bet my life on it.
Thats the big red card.
short1uk
PostPosted: 14:22 - 31 Aug 2006    Post subject: Reply with quote
ahhh the big red card!
I will have a look at this when I get home Thumbs Up
The last post was made 19 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 126.05 Kb
