URGENT ADIVCE REQUIRED A.S.A.P power valve assay
befdelta7
PostPosted: 15:49 - 30 Aug 2006    Post subject: URGENT ADIVCE REQUIRED A.S.A.P power valve assay Reply with quote
take a look at the TOP 2 photos below. they are taken from my cagiva super city 125.
firstly the power valve housing seems to be broken at the collar! is it ok to put this back into the engine or can i repair it with quick steel?
also what can i use to gap the distance between the piston and pv slide as i cant find my feeler gauges?
also just though id upload the rest of my pic's as i have noticed that the cylinder head and transfer ports are very clean for a 26,000 km engine!!
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
drew8869
PostPosted: 15:52 - 30 Aug 2006    Post subject: Reply with quote
no dont put it back in like that if im lookin correct if it snaps the powervalve will slide into the piston which is not good
befdelta7
PostPosted: 16:01 - 30 Aug 2006    Post subject: Reply with quote
just had a look and the collar cant slide in to the piston there is restriction in the size of the hole so it cant silde anyfurther than its suppose to. might just repair it with quick steel. what do you think good or bad idea -- bearing in mind im broke at the mo Crying or Very sad
drew8869
PostPosted: 16:34 - 30 Aug 2006    Post subject: Reply with quote
ahh well it should be fine but get a new one as soon as you can mate
befdelta7
PostPosted: 16:46 - 30 Aug 2006    Post subject: Reply with quote
yer should be ok. been offered a swap for a cagiva mito full power with an arrow exhaust. owner(my cusion) says its too fast for him. hes only 17 and its it first geared bike! what do you rekon... keep the super city(j-reg 26,000km) of swap for the mito(k-reg 50(odd),000km)???
drew8869
PostPosted: 16:54 - 30 Aug 2006    Post subject: Reply with quote
keep the supercity mate i wish i nevre sold mine now
element
PostPosted: 17:05 - 30 Aug 2006    Post subject: Reply with quote
keep the supercity definatly. You'll regret it if you swap it for a 30k, sports 125. I bet its been ragged to shit like most are since people dont keep up with the maintence.
Not only that at least you can sell the supercity later. Noone wants an old, high mileage and abused sports 125.
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
cagiva gezzer
PostPosted: 17:23 - 30 Aug 2006    Post subject: Reply with quote
I'd buy a new PV housing, but i'd also check to see if that collar is held by the cylinder. IIRC it's only a bush and superglue* would hold it in there....
The stop that prevents the PV sliding in too far is on the outer housing so having a mashed collar won't make much difference.
How about having one "i'm ripping apart my supercity" thread and not the five that are running together about the same subject?
*use superglue at you're own peril as no one should recommend fixing engine components with it...
The last post was made 19 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 55.48 Kb
