lighting
drew8869
PostPosted: 15:44 - 30 Aug 2006    Post subject: lighting Reply with quote
could anyone tell me how i go about putting lights onto a kx125 not to keen on running it on a battery if that could be avoided sum how. i know my mate done it on hs cr conversion but hes unfortunately sadly passed away
drew8869
PostPosted: 16:35 - 30 Aug 2006    Post subject: Reply with quote
someone must know
T1z3R
PostPosted: 16:43 - 30 Aug 2006    Post subject: Reply with quote
someone will but they dont all hang about here between 14:44 & 15:35 Thinking
have some patience Exclamation
duck my sick!
Finglonga
PostPosted: 17:39 - 30 Aug 2006    Post subject: Reply with quote
But it will be dark soon. Mr. Green
Andy Sez....
F.Y.Y.F.F.
drew8869
PostPosted: 18:04 - 30 Aug 2006    Post subject: Reply with quote
thats my problem i get stuck in the dark all the time and its hard to ride in pitch black
0ddball
PostPosted: 18:16 - 30 Aug 2006    Post subject: Reply with quote
Strap a candle to the front.
drew8869
PostPosted: 18:28 - 30 Aug 2006    Post subject: Reply with quote
the wind will blow it out
hmmmnz
PostPosted: 19:22 - 30 Aug 2006    Post subject: Reply with quote
right first you need to find the regulator, its connected to the altenator, there are 5 wires at the connector 3 come from the alternator (usually yellow)
and one black one - one red one +
they go to the battery any way (via a fuse)
also to the starter motor and the ignition,
so you have a few choices 1st wire strait from the battery (im assuming you have a battery)
2 wire from the ignition,
make sure you have a on and off switch.
personally i would wire from the ignition switch, that way when you kill the bike the light goes off and you don't end up with a flat battery
hope that helps a bit,
so basically find the wire on the ignition that supplys 12v only when the ignition is on(if you have a battery) or when the bike is running(if you don't have a battery)
break into that wire and join a wire from it to one side of your switch, from the other teminal of the switch wire to one side of the light from the other side put a wire to earth,
thats it
easy peezy lemon squeezy Mr. Green
the humans are dead
I kick arse for the lord
drew8869
PostPosted: 19:36 - 30 Aug 2006    Post subject: Reply with quote
tbh i never looked for a betery i assumed the 1992 kx didnt have one as they just off road use only
hazza
PostPosted: 19:51 - 30 Aug 2006    Post subject: Reply with quote
if its off road only why do you need lights?.....worst comes to the worst do what i did on my old puch maxi (dogey wiring kept blowing bulbs) and fit good bicycle lamps front and rear
hmmmnz
PostPosted: 20:11 - 30 Aug 2006    Post subject: Reply with quote
ok, so it has no key??
if not then you have to do it via the rectifier, which is connected to the alternator, just like i said about the previous hook up but do it with the red and black wires instead of from the ignition,
sweet? chances are that you probly already have wiring in place,
have you got a test light or a multimeter?
if so then start testing the connectors around the yoke area untill you find 12 volts (or your test light comes on)
the bike has to be running for there to be any power Mr. Green Thumbs Up
the humans are dead
The last post was made 19 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 66.95 Kb
