Spread sheets
mr.z
PostPosted: 23:59 - 04 Sep 2006    Post subject: Spread sheets Reply with quote
Never really had call to use one till now, had always managed to avoid it..
What i need to do is have colums C x D all the way down the page more or less, and the answer to sprout up in E
Can manage it for one row (left to right)
=c1*d1
but doing it in a big lump i can't work out :/
+ how to total a column?
Getting there Neutral but can anyone off some basic spreadsheety tips? (useing open office btw)
veeeffarr
PostPosted: 00:05 - 05 Sep 2006    Post subject: Reply with quote
If you want totals of Col. C in Column E, you need:
=SUM(C1:C100) in Cell E1
Basically means add up all date in rows 1 to 100.
That should be enough to get you started.
veeeffarr
PostPosted: 00:07 - 05 Sep 2006    Post subject: Reply with quote
Sorry, was on the wrong track.
If you click the answer in E1, you can drag it down using the handle in the bottom right corner of the selected cell.
Code:
_______
l______+
Click and drag where the + is Smile[/code]
mr.z
PostPosted: 00:23 - 05 Sep 2006    Post subject: Reply with quote
Ahh thanks for that, get the total thing now Smile
Attached the offending article as i'm not manageing to explain what i'm doing right Neutral
veeeffarr
PostPosted: 00:37 - 05 Sep 2006    Post subject: Reply with quote
Like this?
mr.z
PostPosted: 00:55 - 05 Sep 2006    Post subject: Reply with quote
Basicly what i want to be able to do is put in the length and width and for it to automaticly give the answer in the area colum, but the whole length down.. (not haveing toput the c1*d1 in each box :/) if that makes sense..
binge
Emo Kiddy
PostPosted: 01:01 - 05 Sep 2006    Post subject: Reply with quote
Write the formula in the top box (eg. C1). and the bottom right of the box is a small square, when you hover across it you will see.
Click the square
and drag it
Down
Until you are far enough down...
If that makes any sense?
veeeffarr
PostPosted: 01:07 - 05 Sep 2006    Post subject: Reply with quote
Rar
mr.z
PostPosted: 01:33 - 05 Sep 2006    Post subject: Reply with quote
Aaaaaaaaaahhhhh i see now Laughing
Blimeh, simple isn't it..
Tis one of them things i've just never done on a pc is useing a spread sheet, silly really, it shold save a bit of hassle though (theres only 6 on the example but there could be somehting like 200 odd on future ones, the current one goes up to 32..)
Thanks for that, very very much appreciated Thumbs Up
The last post was made 20 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 60.9 Kb
