My NSR has siezed..
ncrn
PostPosted: 20:12 - 10 Sep 2006    Post subject: My NSR has siezed.. Reply with quote
So I need as much help as I can get really, the bike siezed up while I was riding it (that was not a fun experience)
my dad came and rescued me about an hour after I'd stopped, we managed to get the piston moving again, but it doesnt sound or feel right, and the bike doesnt seem to be mixing any oil with the fuel at all, we put some oil into the tank and mixed it up, and ran it that way.
So basically I need to know what do I need to buy to rebuild the top end of the engine, and any ideas on where to buy the parts from.
Also if anyone could shed some light as to why my oil pump has stopped mixing the 2 stroke oil in, that would be appriciated.
many thanks,
daveyb
PostPosted: 20:37 - 10 Sep 2006    Post subject: first thing's first Reply with quote
You Will have to strip the engine fully to see what you need and take the oil pump off to see if it's goosed. then ring around for prices also try to look for donor engine
hope that helps Dave
ncrn
PostPosted: 20:38 - 10 Sep 2006    Post subject: Reply with quote
that sounds pricey, i had feared it would make a large dent in my bank account.
im just wondering where im gonna find time to take my engine apart,
THCi
PostPosted: 20:55 - 10 Sep 2006    Post subject: Reply with quote
You could always pay someone to do it for you, but at atleast £45/hour it aint gonna be cheap at all!
Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
"We're not gonna die. We can't die, Bendis. You know why? Because we are so...very...pretty. We are just too pretty for God to let us die."
alains
PostPosted: 20:58 - 10 Sep 2006    Post subject: Reply with quote
no , dont trust him . generally seized engine will go again with a top-end rebuild . it's only in case of worn crank (gearing or big end) that you need to take engine off . the workshop manual is avaiable here https://www.geneva-racing.com/~alains/NSRmanualDOC.zip (64 Mo)
then your spares https://www.davidsilverspares.co.uk or phone to TIM 01728833020 . a list is joined here
ncrn
PostPosted: 21:30 - 10 Sep 2006    Post subject: Reply with quote
you seem to know everything about the nsr alains, thank you Thumbs Up
i will go through that zip file, find out what i need doing, hope this doesnt take to much, i dont have a lot of time free
alains
PostPosted: 22:19 - 10 Sep 2006    Post subject: Reply with quote
it will take you double time than a professional (i guess 6H) . if you are going to DIY , and if you need a guide , send me a PM with your mail and i will answer .
ncrn
PostPosted: 22:40 - 10 Sep 2006    Post subject: Reply with quote
I'll bear that in mind thanks, I've forwarded that file onto my dad, whos going to pick out the bits im going to need (it is handy having an engineer dad Razz)
but if theres anything i cant figure out i'll ask you, thank you Smile
alains
PostPosted: 22:58 - 10 Sep 2006    Post subject: Reply with quote
just a little thing to know : when you will dismount the valves , the nut on the valves shaft is a left thread (undo clockwise) and break easily if you force too much (the shaft cost £18)
ncrn
PostPosted: 23:44 - 10 Sep 2006    Post subject: Reply with quote
aha that could have gone wrong, i'm quite bad when it comes to tough screws, i try to force them so i think you may have just saved me £18 there Thumbs Up
THE MESSIAH
PostPosted: 00:46 - 11 Sep 2006    Post subject: Reply with quote
This might help Wink
https://cgi.ebay.co.uk/HONDA-NSR-125-FOXEYE-MODEL-YEAR-2000-TWO-STROKE-PUMP_W0QQitemZ170027448332QQihZ007QQcategoryZ10460QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The more you ram the better she likes it
https://i160.photobucket.com/albums/t168/scod_2007/07_r1_intakestack.gif
alains
PostPosted: 01:26 - 11 Sep 2006    Post subject: Reply with quote
a new oil pump is quite expensive (£60-70) ref 15100 KY4 904 , but i will not trust ,as i rebuild top-engine, a second hand one . this part break very rarely , but ..........
i suggest you take it out and check if the pinions work . to check if the oil goes through , undo the pipe (at the pump) going to the carb run 2-3 mn with oil mixed and see if the oil pour . if yes check if the entry in the carb is not blocked .
but if you've used your usual oil , what has happened is normal . you require mixing oil at 3% . most of seizure come from a lean mixture , lack of oil surely , quality of oil sometimes
ncrn
PostPosted: 23:43 - 11 Sep 2006    Post subject: Reply with quote
I will do those checks on the oil pump, thanks for finding the oil pump, but its the wrong type for my bike i dont have a foxeye (i think anyways..)
I've discovered i've been running semi-synth, thats gone in the bin and ive bought some fully synth, castrol gt stuff,
by having a look at the oil pump there seems to be a screw attached to the throttle cable that determins how much fuel/oil is allowed through, and this has shaken itself loose in a way that oil flow has been restricted, so there should be hope for the pump yet,
safe to say after this i will be checking everything on my bike once a week
alains
PostPosted: 00:28 - 12 Sep 2006    Post subject: Reply with quote
the oil pump is quite easy to adjust . open pump cover , you will see a plate with a cable . on this plate it's a mark , in the pump is a projection . turn your right handle at maximum acceleration (engine off) and look if the mark is on line with the projection . if not use the adjuster on the cable entry
ncrn
PostPosted: 21:35 - 12 Sep 2006    Post subject: Reply with quote
i've lined the pump up properly, it looks like it will work fine now,
your manual has been a great source of help i cant thank you enough for it!
i got my piston out, it appears to have tried to weld itself to the barrel (think thats what its called), lots of large gauges and scrapes down it, so im getting a new one and a new barrle, the crank is fine as is the rest of the bike, so this shouldnt be too expensive a rebuild hopefully.
although my piston rings snapped :/
alains
PostPosted: 21:56 - 12 Sep 2006    Post subject: Reply with quote
did you check the conrod side play (look on the manual) and at anytime work with a rag covering the bottom engine (any fall inside is desastrous !
ncrn
PostPosted: 08:49 - 13 Sep 2006    Post subject: Reply with quote
yep, and yes I have, Also covered it with a bag so rain cant get in (no room in garage) and now I have put a cover over the bike, so hopefully it all should be fine.
Im just waiting on David Silver spares to send me the parts, if im lucky they'll be here on friday Praying Praying
£160 isnt bad (inc p&p and tax),
Im just going to repaint my exhaust in the mean time (Ive got some high temp paint), to give me something to do Razz
alains
PostPosted: 09:03 - 13 Sep 2006    Post subject: Reply with quote
it's not my manual , but you can also download https://www.geneva-racing.com/~alains/NSRtips.doc
did you take off valves & shaft ? if not , you must , to put back on your new barrel and they must be cleaned as new (mind the shaft nut which is a left-hand thread , undo clockwise)
ncrn
PostPosted: 20:38 - 13 Sep 2006    Post subject: Reply with quote
no I havent done that yet, I will do though, just not tonight got some school stuff to do, I'll do it tomorrow evening,
alains
PostPosted: 21:46 - 13 Sep 2006    Post subject: Reply with quote
ok ,
take off cable guide cover , dismount cables
introduce a diameter 6 rod in the notch on the guide plate and in the hole on the base guide in order to block the plate turning . undo the nut clockwise , take out the plate .undo the 2 bolts which hold the base guide on the barrel , then take the base guide out . take off the oil seal (you can destroy it because it's hard to take off and you'll have an other one) . put back the shaft nut to protect the thread , then pull firmly the shaft off the barrel (can be hardly stocked sometimes) and now your valves will fall and a cleaning work in prospect
DevilDex666
PostPosted: 17:47 - 14 Sep 2006    Post subject: Reply with quote
check this site out -
https://www.stanstephens.com/125sports.htm
"But I being poor, have only my dreams, I spread my dreams under your feet, tread softly because you tread on my dreams." ("He Wishes for the Cloths of Heaven" - W.B. Yeats)
ncrn
PostPosted: 00:26 - 15 Sep 2006    Post subject: Reply with quote
DevilDex666 wrote:
thanks that site is good, however i have an nsr125r not the rr, and, as i have found out before, the parts are very different.
but thanks for your help it is appricated Thumbs Up
code guru
PostPosted: 06:57 - 15 Sep 2006    Post subject: Reply with quote
nsr r and rr is is the same but i think the rr is an import but they still call the uk model rr for some reason.
ncrn
PostPosted: 10:34 - 15 Sep 2006    Post subject: Reply with quote
some of the parts are different between then, for instance i bought an nsr125rr rear sprocket thinking they'd be the same, but the nsr125r uses bolts, where as the nsr125rr is just pushed into the wheel without any bolts.
alains
PostPosted: 11:14 - 15 Sep 2006    Post subject: Reply with quote
i do not understand what you mean , all sprockets bolts fixing are the same since the RK (1989) until the last R1 (2001) . only size of sprockets has change
The last post was made 20 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 135.54 Kb
