| infestedheale... |
 infestedheale... Derestricted Danger
 Posted: 18:07 - 12 Sep 2006 Post subject: peugeot speedfight wont start |
hi, my speedfight started to run out of oil a few days back, anyway, yesterday, the light was flickering every second on and off, and was riding down the street, and suddenly the engine died, so i pulled over, and tried to start, turned off, tried again, still no sucess, the petrol gage wont move like it normally does, or the indicators etc, and the electric start wont work, however, the imobilisor light is still flashing, i cant seem to kickstart it either, so today, after a day of leaving it, i turned the key, and the petrol gage started to move up, and after 2seconds it went down again, any ideas? is my engine ruined?! its the kickstart i dont understand.
cheers all |
| infestedheale... |
| finpos |
 finpos World Chat Champion
| infestedheale... |
 Posted: 13:34 - 13 Sep 2006 Post subject: |
The kickstart is jammed?
possibly, but as much as i know, it kicks all the way down, and it did work before, however, i use the elctric start 99% of the time, so im not 100% sure
The kickstart turns the engine, but the engine does not fire?
i dont actully know how i would know, i smell a distinct smell when i kickstart it for a minute or so
"does it ever stop flashing?"
no, the imobilisor is at its standard, once a second or so sequence
"does the starter motor work when the immobiliser light is not flashing?"
as far as i know, suposibly the imobilisor kicks in when someone tries to break into, or fiddles with the electric, or, like i had a problem before, the fuse broke on the battery
"So none of the lights on the work at all?"
it doesnt look like it, normally the indicators, or brake light go on when the engine is not on
MANY thanks |
| finpos |
 Posted: 14:01 - 13 Sep 2006 Post subject: |
Sounds to me like you've got a bad connection somewhere very near the battery (the battery terminals or the fuse), and this is stopping your bike from getting any electrical power.
The immobiliser has detected this, and has decided it's been attacked so is not allowing the engine to run (either from the kickstart or the starter motor). That's it's job .
The fact that the starter motor won't turn could be due to the general lack of electrical power, or the immobiliser may be deliberately stopping it to protect the bike from being nicked.
If the kickstart is moving, it suggests the engine is ok. The smell is probably just unburnt fuel getting pumped out of the exhaust.
You say you've had a similar problem before?
finpos. |
| infestedheale... |
 Posted: 14:09 - 13 Sep 2006 Post subject: |
yes, before, i had a broken fuse, the imobilisor light stopped flashing (indicating that it had kicked in) and i replaced the fuse for it to work fine, im pretty sure the light is supposed to go off when its kicked in, not sure tho, what is why i dont understand why the electrics have maybe got a fault, and also, it stopped while i was traveling, nothing for the electrics to do, thats where im confused, it jus died as i was going, and the electrics dont need to be working for the engine to continue working surely. |
| finpos |
| infestedheale... |
| finpos |
| critical_technique |
 critical_technique Nova Slayer
| irving |
 irving Traffic Copper
| Rob-B |
 Rob-B Trackday Trickster
| zorgman |
 zorgman Nova Slayer
There is a gap of 298 days between these two posts... |
| storton12345 |
 storton12345 L Plate Warrior
There is a gap of 233 days between these two posts... |
| joshua1905 |
 joshua1905 L Plate Warrior
| Cigaro |
 Cigaro World Chat Champion
| prawny1 |
 prawny1 World Chat Champion
| regyhenry |
 regyhenry L Plate Warrior
| Faraz |
 Faraz Nearly there...
| regyhenry |
There is a gap of 1 year, 146 days between these two posts... |
| lewisb01 |
 lewisb01 L Plate Warrior
| lewisb01 |
The last post was made 16 years, 300 days ago. Instead of replying here, would creating a new thread be more useful? |
