peugeot speedfight wont start
infestedheale...
PostPosted: 18:07 - 12 Sep 2006    Post subject: peugeot speedfight wont start Reply with quote
hi, my speedfight started to run out of oil a few days back, anyway, yesterday, the light was flickering every second on and off, and was riding down the street, and suddenly the engine died, so i pulled over, and tried to start, turned off, tried again, still no sucess, the petrol gage wont move like it normally does, or the indicators etc, and the electric start wont work, however, the imobilisor light is still flashing, i cant seem to kickstart it either, so today, after a day of leaving it, i turned the key, and the petrol gage started to move up, and after 2seconds it went down again, any ideas? is my engine ruined?! its the kickstart i dont understand.
cheers all
infestedheale...
PostPosted: 12:06 - 13 Sep 2006    Post subject: Reply with quote
e
finpos
PostPosted: 12:22 - 13 Sep 2006    Post subject: Reply with quote
eh?
"i cant seem to kickstart it either"
The kickstart is jammed?
The kickstart turns the engine, but the engine does not fire?
"the imobilisor light is still flashing"
does it ever stop flashing?
does the starter motor work when the immobiliser light is not flashing?
"the petrol gage wont move like it normally does, or the indicators etc"
So none of the lights on the work at all?
finpos.
infestedheale...
PostPosted: 13:34 - 13 Sep 2006    Post subject: Reply with quote
possibly, but as much as i know, it kicks all the way down, and it did work before, however, i use the elctric start 99% of the time, so im not 100% sure
i dont actully know how i would know, i smell a distinct smell when i kickstart it for a minute or so
"does it ever stop flashing?"
no, the imobilisor is at its standard, once a second or so sequence
"does the starter motor work when the immobiliser light is not flashing?"
as far as i know, suposibly the imobilisor kicks in when someone tries to break into, or fiddles with the electric, or, like i had a problem before, the fuse broke on the battery
"So none of the lights on the work at all?"
it doesnt look like it, normally the indicators, or brake light go on when the engine is not on
MANY thanks
finpos
PostPosted: 14:01 - 13 Sep 2006    Post subject: Reply with quote
Sounds to me like you've got a bad connection somewhere very near the battery (the battery terminals or the fuse), and this is stopping your bike from getting any electrical power.
The immobiliser has detected this, and has decided it's been attacked so is not allowing the engine to run (either from the kickstart or the starter motor). That's it's job Smile .
The fact that the starter motor won't turn could be due to the general lack of electrical power, or the immobiliser may be deliberately stopping it to protect the bike from being nicked.
If the kickstart is moving, it suggests the engine is ok. The smell is probably just unburnt fuel getting pumped out of the exhaust.
You say you've had a similar problem before?
finpos.
infestedheale...
PostPosted: 14:09 - 13 Sep 2006    Post subject: Reply with quote
yes, before, i had a broken fuse, the imobilisor light stopped flashing (indicating that it had kicked in) and i replaced the fuse for it to work fine, im pretty sure the light is supposed to go off when its kicked in, not sure tho, what is why i dont understand why the electrics have maybe got a fault, and also, it stopped while i was traveling, nothing for the electrics to do, thats where im confused, it jus died as i was going, and the electrics dont need to be working for the engine to continue working surely.
finpos
PostPosted: 14:18 - 13 Sep 2006    Post subject: Reply with quote
On a small bike, sometimes the engine ignition electrics will run independently of the secondary electrics (lights, horn etc.), but that is not always the case. Just depends on how the ignition system is set up - I don't know the answer for one way or the other on your type of bike.
The bigger problem would be the immobiliser deciding something was wrong and deliberately shutting down the engine. I'm sorry, but I still can't tell from your description if the immobiliser is active or not.
Either way, you need to figure out why you have lost electrical power first, it's the one obvious problem that you do have. And it could explain why your starter motor will not run.
finpos.
infestedheale...
PostPosted: 14:28 - 13 Sep 2006    Post subject: Reply with quote
maybe the battery is dead? run out? is that likely, that being the fact of i turned it on after 24hours and the dials moved for 5seconds? maybe it was a tenny bit of electric left, although this doesnt explain the fact why it stopped during riding in the first place
finpos
PostPosted: 14:32 - 13 Sep 2006    Post subject: Reply with quote
It's possible the battery is old and tired, but the sudden failure while riding would seem to indicate a connection problem. The fact that everything has stopped working would point towards something very simple (e.g. loose battery terminal)
good luck!
finpos.
critical_technique
PostPosted: 15:34 - 03 Oct 2006    Post subject: Reply with quote
irving
PostPosted: 20:08 - 03 Oct 2006    Post subject: Re: peugeot speedfight wont start Reply with quote
Rob-B
PostPosted: 21:02 - 03 Oct 2006    Post subject: Reply with quote
Did you put some more oil in?
zorgman
PostPosted: 21:28 - 04 Oct 2006    Post subject: Reply with quote
ah the sf electrics
right then u say theres no indicators
does horn work
if no norm eletrikicy its the stupid joint in the loom.
take off the full front panel.
theres a big taped coverd cable running down the steering column.
its awarked but remove the 2 metal cable wraps that keep the cable fastened and pull the cable out to get a bit room on it.
disconnect battery .
now then carefully cut the tape and look for red wire half way down theres a insulated crimp with 3 or 4 wires crimped into it, give each wire a tug see if it parts company and look for "green" staining on the wire. if it pulls away theres the fault very common on these scoots be it 50 or 100 sf1 or sf2.
dont be tempted to use a scotchlock or anything that crimps the wire far better to cut the wires off the crimp and remake the connections with solder, theres just enough slack to do this.
hope it helps if not tell me what is live and what is dead
There is a gap of 298 days between these two posts...
storton12345
PostPosted: 12:00 - 30 Jul 2007    Post subject: peugeot speedfight Reply with quote
hi
i have a peugeot speedfight and the other day i left it in the garage overnight. i woke up and he electric start wouldent work. the imobiliser does stop flashing when i turn the key but all i can her when i press the electic start is one small click noise each time i press it. it was all working fine before.
please someone help!!!
thanks
There is a gap of 233 days between these two posts...
joshua1905
PostPosted: 18:03 - 19 Mar 2008    Post subject: Re: peugeot speedfight Reply with quote
storton12345 wrote:
hi
thanks
I have the same problem, its the starter motor mate. Took it off mine and some of the brushes inside have burnt out. I have another problem though, i am getting no spark from the spark plug but when i try the spark plug on another bike there is a spark. What do you think it could be? the HT lead? the HT coil?
If you could get back to me asap it would be greatly appreciated
Cigaro
PostPosted: 18:16 - 19 Mar 2008    Post subject: Re: peugeot speedfight Reply with quote
CDI unit, HT lead, could be anything.
prawny1
PostPosted: 18:23 - 19 Mar 2008    Post subject: Reply with quote
sounds like a combination of a flat battery (imobiliser needs some power to work), and probably a brake switch/connection problem which will effect the starter inhibitor,
Is yoour battery bulged out at the sides or low on acid if so to safe to say its fubar.
thats assuming that you don't just need a new piston and ring set hence the cutting out whilst riding!
regyhenry
PostPosted: 02:51 - 12 Jul 2008    Post subject: hey fellas Reply with quote
I from the grenada in the caribbean an im no techncian but for the person with the speedfigther let them check the ignittion module. i had a similar problem ( my peugot 306 just cut of with me) what is happenin is that because the vehicle is in motion ( tryn to kickstart or rollin) the engine sounds like if it is running but its not ur guage will move (evrythin like if the vehicle is wrkin ) but wen the vehicle isnt in motion u wont get no response from the vehicle also u wont get anythin fire in the spark plugs. ignition module sends current to where it has to go (i dont kno). it is located next to the distributor (on my car) dont no bout urs. gope all goes well[/b]
Faraz
PostPosted: 10:33 - 12 Jul 2008    Post subject: Reply with quote
Im guessing hes fixed it by now.
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
regyhenry
PostPosted: 22:00 - 13 Jul 2008    Post subject: hey Reply with quote
does any1 know how the brushs for a puegot 306 starting motor looks like? hola bac
There is a gap of 1 year, 146 days between these two posts...
lewisb01
PostPosted: 22:40 - 06 Dec 2009    Post subject: Reply with quote
hi ive got a speedfight 02 and when i have the light switch turned on the bike runs perfect but no lights turn on. althought if i turned the switch off the bike runs crap and wont move engine start popping (or whatever) i knew my front bulb had gone ages ago so when i replaced it with the switch on the engine ran crap so now i have to ride with the front lights unplugged and switch on. no lights work still. ive been told its a electical problem so any ideas will help alot ??
lewisb01
The last post was made 16 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 113.14 Kb
