places to get my bike dyno'ed
code guru
PostPosted: 02:23 - 15 Sep 2006    Post subject: places to get my bike dyno'ed Reply with quote
does any one know any places in london were i can get my bike dyno'ed? all i whant is somethink to prove the bhp of the bike (maybe when i get a 33bhp bike as well), dont whant it set up or anythink.
thanks
johnsilva
PostPosted: 08:37 - 15 Sep 2006    Post subject: Reply with quote
banjax in hackney 02073776333
been there, they know what they are doing
Current Bikes: ZX7R P5; KR1S C2; GPX250R F3
Previously: CBR400RR-R; YQ50 Aerox
code guru
PostPosted: 16:38 - 15 Sep 2006    Post subject: Reply with quote
thanks mate will give them a call
sickpup
Old Timer
PostPosted: 17:29 - 15 Sep 2006    Post subject: Reply with quote
And how long have they had their Dyno? Razz
Also they're not in Hackney they are in Tower Hamlets.
PostPosted: 18:00 - 15 Sep 2006    Post subject: Reply with quote
I think they've had their DJ250 just over a year. I'd reccomend them too Smile
They're in Shoreditch Very Happy
Edit: thinking about it - it could have actually been 2 years ago. I remember them having it installed, and they got this super-powerful cooling fan that they had to send back because it was either too noisy or too windy.
sickpup
Old Timer
PostPosted: 19:53 - 15 Sep 2006    Post subject: Reply with quote
Good to know another person doesn't know their way around London. Rolling Eyes
Over 2 years and still learning.
Saying that a Dyno cannot replicate road conditions fully anyway.
PostPosted: 20:48 - 15 Sep 2006    Post subject: Reply with quote
That's true. My good friend went to pick up his bike and though it ran-up smoothly on the dyno it was completely unrideable at low-throttle settings one on the road. The tuner never road-tested it, and would never have known of the problem had he not insisted on a road-test before taking it away.
I'm told that in real terms, loading an engine on the dyno will put it under approximately 40% of the stress it would experience on the road, at the same power output.
sickpup
Old Timer
PostPosted: 21:32 - 15 Sep 2006    Post subject: Reply with quote
Thats not really the problem though. Start thinking air pressure and you may get to the answer. Wink
Might be time for a couple of manometers to be strapped to a bike to demonstrate this.
PostPosted: 21:42 - 15 Sep 2006    Post subject: Reply with quote
Air pressure was actually his problem - his bike was supercharged Very Happy
sickpup
Old Timer
PostPosted: 21:53 - 15 Sep 2006    Post subject: Reply with quote
I know I read the thread. The air pressure in the dyno room was really his problem multiplied by the compression of the supercharger.
The thread didn't actually say what the problem was though.
PostPosted: 22:16 - 15 Sep 2006    Post subject: Reply with quote
The reason given for the inability to map the low-down running at the time was that the PC2 didn't have the range of adjustment to map it with the larger-capacity injectors. The actual charger system fitted was a very early developmental one (mind you aren't they all so far) which had been mapped with a PC3/PC3r on the original bike and didn't suffer the same problems. The "cure" at the time was to fit stock injectors back in and use the PC2 to map it, and keep the big injectors for top-speed runs and race fuel. Stock injectors were fitted, and the bike ran better but not perfectly and there were other mechanical problems with the setup making diagnosis difficult.
code guru
PostPosted: 22:41 - 15 Sep 2006    Post subject: Reply with quote
ok would they be able 2 set my bike up if i gave them a 30mm carb and a k&n airfilter? as i wouldnt know wot jet 2 go for if i fitted a 30mm carb. and how will they know its the correct jet? as im on a scooter forum and people say they got there carb set up by useing a dyno Question
thanks
PostPosted: 22:55 - 15 Sep 2006    Post subject: Reply with quote
Your best bet is to find someone on the scooter forum who is using the same 30mm carb on the same model bke as you, and find out what jets they have and their needle settings and float height. That will get you pretty close then you could take it to a dyno and have them check the air/fuel ratio, but beware dyno time tends to work out very expensive, and you could easily blow a few hundred quid by the end of it. You could get good reslts taking plug readings and it's free.
code guru
PostPosted: 22:58 - 15 Sep 2006    Post subject: Reply with quote
yer thanks im only keeping the nsr for 3 more months before i get a 400 so i dont know if its worth it or not ect
PostPosted: 23:05 - 15 Sep 2006    Post subject: Reply with quote
I thought the NSR's were restricted electronically, or is that not the case?
code guru
PostPosted: 23:07 - 15 Sep 2006    Post subject: Reply with quote
only the import ones r resticted. i think the uk and italian ones r not resticted in the electrics only inlet manifold and reedblock
divuk83
PostPosted: 23:09 - 15 Sep 2006    Post subject: Reply with quote
I have a 28mm Delorto Carb (same as used on an NSR) on one of my scooters. Don't think the jetting would help you. I was sold it by a guy who had a similar bike. The jets fitted when I bought it were way off when I had it fitted and first dynoed. I reckon an hour or two on the dyno to get things spot on is worth the cash. Make sure you take it to somewhere that has experience with 2 strokes on dyno's and has a decent supply of spare jets etc for you carb to swap around. I reckon you will gain a horsey or two from having it set up right and the bike will ride much better. You will notice an improvement.
Just my Penny Coin Penny Coin
Dave
LUXY DJ
PostPosted: 04:06 - 16 Sep 2006    Post subject: Reply with quote
how much this place in hackney/TH/shorditch charge?
GSXR750
code guru
PostPosted: 04:09 - 16 Sep 2006    Post subject: Reply with quote
dont know , shox knows the place and he said they r ok there i think thats wot he said. y u whant 2 c how much bhp yoir bike has? lol
gona put my bike on ebay on sunday as its free listing day and im gona put a high reserve (1500 maybe) Laughing and if it meets it ill let the bike go and buy a cbr400 with the money or wot ever comes up but if i dont sell it i might most prob still dyno the nsr ect
LUXY DJ
PostPosted: 05:20 - 16 Sep 2006    Post subject: Reply with quote
AYE Cool but just to make sure its all setup right Twisted Evil
what do they set up tho? cause iv balanced carbs do they go as far as re jetting,etc or what? or do they just put it on put it thro paces & say here you go thats your BHP?
i know im touching around 100bhp
GSXR750
johnsilva
PostPosted: 21:06 - 16 Sep 2006    Post subject: Reply with quote
£35 for a power run
then £35 for every hour spent tuning
can't say fairer than that
code guru
PostPosted: 21:42 - 16 Sep 2006    Post subject: Reply with quote
thats not bad for £35
thanks
JGY6000
PostPosted: 23:37 - 16 Sep 2006    Post subject: Reply with quote
Southern Cross Motorcycles in kilburn, did me just a normal power run on the bandit with a print out showing th BHP for £10, or free if i had let them fit my C&S, so i paid the tenner and left with my printout
The last post was made 20 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 121.32 Kb
