| phantomtek |
 phantomtek Lil Joe Tek
 Posted: 16:38 - 16 Sep 2006 Post subject: Here's one I made earlier... |
Due to my bike being 'The WORM' and it's diet consisting of my registration plates, (3 so far), I decided I'm no longer going to put up with it's expensive dining habits.
https://www.bikechatforums.com/files/dscf0016_671.jpg
I took to making a new numberplate and writing a guide, to do this you will need:
* A pair of scissors (Always have an adult present whilst using these, and don't run with them.)
* A ringbinder folder (If Mummy or Daddy is the office type, they will probably have one you can borrow)
* A yellow separator (Look inside the folder)
* A marker pen (Be careful not to miss and draw on the walls)
* Some sticky tape.
* A biro
* A sandwich bag (Make sure it is empty before use)
* Neil Buchanan's favourite, PVA glue.
Now to do this, you will need to cut a plate sized rectangle from the ringbinder folder, be careful with the scissors as they are pointy and sharp. Then, take your yellow separator and cut the same size shape out in that, and mount it onto the binder using PVA glue. Use the scissors to make a set of holes in the plate template at the desired widths.
Then, use a biro to mark out the outlines of your letters and numbers, and use the marker pen to fill them in. Make sure to colour inside the edges, and don't use the marker pen for too long or the fumes will cause you to get high, and the last thing you want is to be tripping with scissors nearby. Trust me.
Finally, take your sandwich bag and put the plate inside it, folding down the edges to make it flush with the plate, and use the tape to tape it down on the back, as shown in the picture.
Congratulations! You now have a fully functional numberplate, which is also waterproof too!
https://www.bikechatforums.com/files/dscf0014_109.jpg
https://www.bikechatforums.com/files/dscf0015_116.jpg
Revel in your latest invention, as the police pull you over and do you for it. Tell them that you made it yourself and you should be applauded, not arrested. Question their decision to sanction you under the mental health act, and prove to them that you are a sane and safe member of society by showing them your 'List of people I wanna kill someday and stuff.'
Have a nice day
DISCLAIMER: If you do happen to follow my guide and get pulled/sanctioned I will in no way be held responsible. |
| -Savage- |
 -Savage- World Chat Champion
| phantomtek |
 Posted: 16:48 - 16 Sep 2006 Post subject: |
Hi,
That plate is for the rear of the motorcycle, I think you have confused bikes with cars, bikes don't have plates on the front usually, it's an easy mistake to make.
If you wanted your reg on the front, I think you could take the marker pen and write it on the mudguard.
Hope this helps.  |
| -Savage- |
 Posted: 17:06 - 16 Sep 2006 Post subject: |
| phantomtek wrote: |
If you wanted your reg on the front, I think you could take the marker pen and write it on the mudguard. |
This is causing me some problems im afraid, my mudguard is black, and the only marker pen i have is also black, perhaps i might write it on my windscreen, or even my visor. I may spray my visor yellow to give the lettering more definition. ____________________ My Bikes - - - Royal Enfield 500 with sidecar, VFR800, CBR600FX,
Peugeot Speedfight 100, Kymco Hipster 125, GSXR750K5, Jawa TS 350 |
| phantomtek |
| -Savage- |
 Posted: 17:35 - 16 Sep 2006 Post subject: |
| phantomtek wrote: |
to protect it from the blast of the afterburners on '98 R1s.
| = nice
| phantomtek wrote: |
You could use tippex on the mudguard, but I'm not sure you want to because it gives a 50bhp increase on some bikes, I think the F-Sport is included unfortunately.
I have an after market power band installed, and red rimtape too, will this compensate for the tip-x-effect? I was actually thinking of tip-x, but seeing as it is a controlled substance in this country and is in short supply (every 3rd kerbstone is tip-x'ed white) i believe tip-x is not the way to go. its good to be back. ____________________ My Bikes - - - Royal Enfield 500 with sidecar, VFR800, CBR600FX,
| phantomtek |
| Andy C |
 Andy C Tree Seeking Missile
| kat250 |
 kat250 World Chat Champion
| phantomtek |
| kat250 |
 Posted: 21:28 - 17 Sep 2006 Post subject: |
How badly is your undertray damaged for a cheap option what i took mine off, just got some thin ish steel and pop rivet if to bothpieces. I guarentee without even seeing it that ist broken just abit back from the indicators Am i right close  ____________________ in the famous word of jimmy pop "would you F*ck me for blow"
In the words of banditshigh "would you blow me to f*ck" |
| phantomtek |
The last post was made 19 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
