Help! :(
ProXimaCore
Dougal
PostPosted: 11:18 - 05 Jul 2003    Post subject: Help! :( Reply with quote
I was riding down a road last night on my NSR when I'm assuming my bike ran out of fuel. (the reserve doesnt seem to work, but that's a seperate problem). Biker stopped by and took me to a garage to get more, so we refueled the bike and now it wont start. A couple of car drivers stopped by to help also. We tried bump starting and we tried using jump leads from the car battery. But nothing worked. It doesnt sound like it's struggling to start. It's making all the right sounds but the engine just wont engage.
Currently my bike is stranded about 15 miles away in some strangers garden. I'm now trying to find a van to get it home, but that's not looking so good either. Anyone got any ideas i can try on the bike? Crying or Very sad
PostPosted: 11:46 - 05 Jul 2003    Post subject: Reply with quote
What kind of noise is it making? Is the engine turning over or is just the starter motor turning over (this would make a whizzing sound).
However I would suspect you have another problem given that the engine died. Check whether you are getting a spark. If you are check it is in the right place (Scottys bike had a plug that was shorting out and although it appeared to be sparking, the spark was actually between the plug and the engine when there was a small gap rather than between the 2 electrodes). Check your kill switch is in the run position. If you have run the bike out of petrol a few times then you might have blocked any fuel filters in the system
If after trying to start it for a while you take the plug out and it is still dry then the engine isn't getting any fuel. In which case either the filter is blocked, the jets are blocked or the floats are stuck. Tapping the float bowl of the carb (use something like the handle of a screw driver) may well free off the floats.
ProXimaCore
Dougal
PostPosted: 11:59 - 05 Jul 2003    Post subject: Reply with quote
It's just the starter motor turning over. Making that whizzing sound. Mind you it started to sound a little more 'normal' after about 30 minutes of trying this. I dont know if that means we cleared something out. But it still wont go.
Thanks for the help, I'll try what you suggested when I get it back.
Smile
PostPosted: 12:05 - 05 Jul 2003    Post subject: Reply with quote
If it is just the starter motor turning without the engine turning over then it is probably the starter "clutch" sticking. As such take off the alternator cover and examine it. Hopefully it just needs cleaning up and will work fine again
ProXimaCore
Dougal
PostPosted: 13:51 - 07 Aug 2003    Post subject: Reply with quote
Well everyone my bike is still at the mechanics getting fixed. That's been over a month now. It was the barrel that was knackered. I've read posts about others having this same difficulty with low compression and problems with their barrel which sound identical. Unfortunatly I don't have a clue how to sort it myself so taking it to a garage was my only other choice. Cost will be roughly £350. Crying or Very sad
I can't believe it's been a whole month and they still haven't got it ready for me. Apparently they are still waiting for the barrel to come back from wherever they have sent it.
TGE125NSR This post is not being displayed because the poster is banned. Unhide this post / all posts.
ProXimaCore
Dougal
PostPosted: 14:20 - 07 Aug 2003    Post subject: Reply with quote
Well it needs a new piston and gasket too. I don't really have a clue what costs what. I seen a post somewhere (cant find it now) someone had the same problem and it cost them roughly the same.
From what the mechanic said, it had pretty much eaten a hole in itself.
Lee
PostPosted: 14:25 - 07 Aug 2003    Post subject: Re: ? Reply with quote
TGE125NSR wrote:
I wonder when mine is going to need a rebuild? currently at 31,110kms.
Any ideas? Confused
Tomorrow?
Taking bets.......2 to 1 on tomorrow Very Happy
ProXimaCore
Dougal
PostPosted: 14:37 - 07 Aug 2003    Post subject: Reply with quote
Can anyone tell me how this could have happened? Am I doing something I shouldn't be doing? Or is it something that needs to be done after a certain time? The bike is a '97 model and has done 14,500 Miles.
Kris
PostPosted: 16:22 - 07 Aug 2003    Post subject: Reply with quote
What happened to your bike sounds identical to what happened to mine (although at 17K rather than 14K miles). It felt like it ran out of petrol...clutch in I coasted to the kerb. Tried to start it on reserve but no joy. Tried bumping it but nothing Confused
Calle dthe garage and the guy said it was either the spark plug or it was something more serious. Guess what? Yup, mucho dollars later (£300+) I had a new barrel and piston rings fitted. The bike had 'eaten' itself much like yours.
Get used to it - it's a 2-stroke after all. Very Happy It's the price you pay for performance from smaller engines.
Oh and one more thing...the bike will need running in when you get it back.
Kristof
www.prisonplanet.com
ProXimaCore
Dougal
PostPosted: 16:27 - 07 Aug 2003    Post subject: Reply with quote
Yup, that's exactly the way it happend. I can't wait to get it back. How much of a running in should I give it? I take it I shouldn't thrash it around for a while then?
What's worse on top of all this, my car has had 3 things wrong with it in the space of this month my bike has been away. So between the two of them this month it's been about £1000 of repairs. Crying or Very sad
I'm going to sell my car so I can get myself sorted out. The bike is much more fun anyway. Plus I can always just borrow the parents car if I need to.
Kris
PostPosted: 16:31 - 07 Aug 2003    Post subject: Reply with quote
Well the 'safe' thing to do would be to run it in about 450-500 miles Very Happy 'Running in' means keeping it below around 7K on the tacho and not labouring the gears etc.
I think I lasted about 200 or so before I thought "Fuck this lark" and nailed it Mr. Green It's up to you really - as long as you warm the bike up properly before riding off I can't see any harm in just riding normally BUT taking it easy for the first few hundred miles.
Good luck with the bike.
Kristof
The last post was made 23 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 86.75 Kb
