Booger
McJamweasel
BCF Junkie
PostPosted: 20:54 - 07 Jul 2003    Post subject: Booger Reply with quote
Right then. Picture the scene, I've just left work and I'm buzzing along quite happily. Then I notice something a little odd. I'm accelerating slowly yet my tacho is jumping wildly - going a few k rpm up then settling down then up agin etc...
Although slightly perturbed, after I've made a mental note to sort it later I think nothing more of it and carry on my merry way home.
Then the bike seems to splutter and jump. A feeling accross between running out of petrol and when my front sprocket decided to turn itself to a racing slick a while back. Odd. Very odd. So I nurse it back home noticing that its only really misbehaving while accelerating @ higher revs.
So, I check the tacho cable - dammit - electronic tacho so it doesn't have one. I check the plug for the misfire - looks ok ish. Although it's brown on one side and oily on the other. And its been leaking a bit. So, I presume, it was a little loose. No biggie.
So I clean said plug and refit and take her for a spin. Booger.
The misfire/splutter got a bit worse....
It's decided to do it while holding steady @ around 6k. Erk...
So, is it: a)Buggered CDI?
b)Buggered coil
or c)A Bonfire?
Robby
Dirty Old Man
PostPosted: 21:27 - 07 Jul 2003    Post subject: Reply with quote
get a new plug first and see, make sure the oil feed isn't obstructed. my 50 acted a bit like that when it was blowing up.
Kris
PostPosted: 23:51 - 07 Jul 2003    Post subject: Reply with quote
what bike is it again? Razz
www.prisonplanet.com
PostPosted: 23:55 - 07 Jul 2003    Post subject: Reply with quote
NSR125 F
McJamweasel
BCF Junkie
PostPosted: 22:35 - 08 Jul 2003    Post subject: Reply with quote
Well, it seems like it may just be the coil. Measured restistance is around .6 ohm, it should be 0.1 to 0.3 ohm.
So, I'll get a coil tomorrow and then when it still doesn't work see what else I can try...
The last post was made 23 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 44.11 Kb
